If it's got a sense resitor and a coil it sure sounds like a buck. Tow fets sounds like a synchronous buck, which is kind of cool if that's really the case. I'd be looking for an amp attached to the sense resistor (if it's not built into the buck controller) and then some circuit biasing the amp output. That would be the thing to hijack, the biasing circuit. But it might not work that way.
I made two PD68 lighted tailcap board for my future builds. One will be in the Jaxman E2L triple host. The other maybe in VG10 triple.
Did some lye treatment…
Here I added some better/more pics, maybe someone will be able to spot solution before I release the magic smoke that lives inside the driver
Interesting thing: on the eeprom chip there are 2 pins soldered together (modes were: hi-low-blinky-blinky-sos) when I removed bridge modes were: hi-mid-low-strobe-sos…
Some parts arrived from MtnE yesterday. Bought my first E-SW driver and installd it today. Seems to be some issues with the modes. Ordered it with ML+6 and there are only 5 modes after ML. There is an extra dead Off spot as I need to hit the SW 2X to get it into ML. Anyway the driver is installed and otherwise working and it’s not coming back out.
The second Solarstorm K2 has the E-SW Fet+1 driver piggybacked on the gutted original driver board. Yeah it ended up as a Triple XP-L HI V2 3C. Used a copper X6 spacer and 2 XP32 under the emitter as spacers and All stacked and soldered together.
Some pics of the driver install.
Bypassed tail Spring
Hunter
It is necessary to turn on the strobe. And with a multimeter to look for where the signal is coming from. It is necessary to find a EN signal that allows the DC-DC inverter to work.
I would suggest to add some silicone for heat transfer from the new driver to the old one.
Thanks and appreciated.
Does not work as it should so if it burns out I will make sure to fully test the replacement and thermal silicone that one.
Ld-51 driver and Xhp35 hi e2-3a in a warsun x65
fixed the photo in my previous post. click for some mediocre cellphone beamshots.
Just put together my first S2 triple. I used dedomed XPG2 S4 2B emitters and the carclo 10507 narrow spot optic. Nice large spot; I like it. Almost twice the width of the beam of my S2+ with XPL HI and narrow TIR. With a fresh 30Q it pulls about 9.5A at start and does about 2300 lumens and 26 Kcd.
I’m going to put a rotary dial in the tail to continuously control the brightness, similar my mod here.
Hunter
thanks for the advice, unfortunately I am not that good at electronic, best I was able to do is to activate one FET by connecting Gate pint to Bat + (I measured that it gets same voltage as batt.in while in HI) this give me half amperage that is usually in HI mode, second FET was disconected, but the other FET has 3.3V on Gate pin while in HI mode and that 3.3V is supplied from one of the chips (botom right) and depends from what mode is activated and when I tried powering this second FET with external supply of 3.3V it didn’t work (FET started heating up but no light from LED).
Here is my rough schematics of FETs, maybe someone will see something here but for now this is out of my capabilities…
Hunter
One of the microcircuits sets the modes. I therefore suggested using a strobe. A repeating signal is easier to find with a multimeter.
Those. You have a microcontroller. It sets the operating modes of the inverter.
Modes are low, medium, high. They can be specified via PWM. Or by connecting in the feedback circuit of additional resistors with the help of FET transistors.
If you can find which one of the microcontroller’s feet produces a signal the SOS or strobe. Then you can apply the required voltage instead of the microcontroller (for example, 3.5V).
It should be just a EN signal allowing the operation of the DC-DC converter
I hope I wrote correctly … English is not my native language
i change the emitter of nitecore EC4 to xpl-hi, change the MCPCB to DTP, mod the thermal resistor
too bad, the led was out of center, i may have to reuse the stock mcpcb
some interesting things i found
the driver uses STM32f0 32 bit micro controller, which is quite impressive to me( much more power than attiny 85, or any other 8 Pin Uc)
the driver when open connect has Vbat voltage on the output( which mean i can mod the XM-l2 to XHP50, or even xhp70, whatever you want)
nitecore EC4… the driver uses STM32f0 32 bit micro controller
Interesting. I was just looking at those a few days ago, wondering if they would work in flashlights. It would certainly increase processing power and onboard capabilities, at least, going from 8-bit MCUs to 32-bit. Not that we generally need more processing power, but IIRC it has a bigger instruction set than attiny, which could make some things easier. Like, if it has a usable divide instruction or floating-point, some things could be calculated onboard instead of being precalculated into tables.
This is what I’ve been doing in for the past few days. The mod will have two xpg3 cri 5700 and two nichia 219c 4500 cri. It will be powered by a one of a kind driver. An upgraded version of one of the best three channel drivers available with full thermal regulation. Can you guess what driver?
I don’t find much time to sneak mods in but today I found a few minutes to do this quick & dirty emitter swap on a Thorfire KL02. Even essentially serving as a spare battery holder I found it’s CW tint too harsh. I swapped in a Nichia 119A (3,500k I think?)
Given my time crunch along w/ the fact that my heatgun & dremel cutoff discs are all loaned out I didn’t fashion a good heat path for it. I had initially thought to put in a dual emitter in the light. However I ended up just going into my parts bin & grabbing an emitter pulled from somewhere. As the stock emitter has it’s anode & cathode similar to a luxeon I or III -> it took a little finagling to fit a Nichia 119A in it.
Given that this light will just serve as a battery carrier for me I’m not all that certain that I will spend anymore time on this light.
Here’s a god awful pic (I see that now. Sorry. But take my word for it. It’s tint is very pleasing to the eye.)
ok heres a noob question with the spring bypass is it because of poor contact or an electrical field problem with the coil .
I ask because I am seriously thinking of doing a hi power mod on a c8 just for wow factor I realise that heat will be a problem .
cheers D
cheers D
Spring steal has resistance in it and will cause heat and voltage sag in high power mods:)
