I’ll take (3) 1S 30mm Narsil drivers please!!
And (3) 2S 30mm Narsil LDO drivers too if possible!
Could that it be used in utorch ut2?
Made one , 30mm LDO is the right driver .
Tom E has fixed the LDO low voltage not yet in Narsil triple
in Narsil 2 channel its already implemented
Hhhmmm. Fixed? Depends on the board/usage. I’m using a fully configured “Narsil” 2 channel version (not 3) with a properly configured LVP support for a 360K r1, 47K R2 for 2S, LDO of course, and it’s working great.
It’s in a v1.3 not yet posted though.No, sorry, no R1/R2 support yet in the triple version.
Tom
I am sure it will be in triple soon
I will give this batch some time to get enough people in to get enough to get free shipping from Digikey
Sukoi: KawiBoy1428:What about a 30mm size like these in a 1S with Narsil?
Ok, great thanks.
Have you measured the result and of course, was it worth it?
You don’t need LDO for 1S…… 2-3-4S e-switch of course Zener for mechanical button switch.
I would be in for 5x17mm Bistro at least
Hi Lexel, I would like to buy one 15mm and one 17mm Narsil.
Thanks for offering this for us folks in Europe
I’d be in for 2 x 17mm bistro.
Edit with a long spring.
Awesome!! Thank you for doing this!
I would like:
3 x 17mm Bistro
1 x 30mm, 2S, Narsil (is this what I would use for a L6 mod?)
The 30mm 2S Narsil works with Eswitch and fits the L6
It can be used with Zener Mod, but you need to lock out the light because that has a quite high parasitic drain, the LDO reduces the parasitic drain so no lockout needed
Narsil can be modified so the light gets on at Turbo if you want to use the forward switch tactical, similar to Klarus XT series lights
Please choose which spring you prefer the short or long
Short spring on both 15 and 17mm requested above please
No springs or wires needed, thanks Lexel!
Ill take one 30mm configured for 2S with narsil firmware. No springs needed.
Hi I will take 1x 17mm Bistro long spring.
Forgive my ignorance… I’m not sure what the pros/cons are of the various options. Basically I would like minimal parasitic drain, most efficient low and mid modes, Narsil ramping, and of course FET turbo.
What is your recommendation?
Also, can the tail switch be used for lockout?
Thank you for providing this service.
I’ll be in for two 17mm (short spring) with latest Narsil Triple, looks like Tom E just uploaded v1.4 tonight.
I think the standard mode groups should be fine and 55C sound like a good stepdown.
I plan on putting one in a skilhunt h03 headlight. Would it be possible to operate the indicator led inside the e-switch with this driver?
I did put a 21mm inside my Skilhunt H03
If the driver is configured to enable indicator LED it works adding a 4.7kOhms resistor to pin 7 like this
I can add that resistor already
If you want that I configure the driver add 1$ and instructions
I will take one 30mm LDO 2s with Narsil then
No spring needed
