Caleb
(Caleb)
March 28, 2017, 2:25am
22
Lexel:
The 30mm 2S Narsil works with Eswitch and fits the L6
It can be used with Zener Mod, but you need to lock out the light because that has a quite high parasitic drain, the LDO reduces the parasitic drain so no lockout needed
Narsil can be modified so the light gets on at Turbo if you want to use the forward switch tactical, similar to Klarus XT series lights
Forgive my ignorance… I’m not sure what the pros/cons are of the various options. Basically I would like minimal parasitic drain, most efficient low and mid modes, Narsil ramping, and of course FET turbo.
What is your recommendation?
Also, can the tail switch be used for lockout?
Thank you for providing this service.
I’ll be in for two 17mm (short spring) with latest Narsil Triple, looks like Tom E just uploaded v1.4 tonight.
I think the standard mode groups should be fine and 55C sound like a good stepdown.
I plan on putting one in a skilhunt h03 headlight. Would it be possible to operate the indicator led inside the e-switch with this driver?
Lexel
(Lexel)
March 28, 2017, 8:16am
24
electricjelly:
I did put a 21mm inside my Skilhunt H03
If the driver is configured to enable indicator LED it works adding a 4.7kOhms resistor to pin 7 like this
I can add that resistor already
If you want that I configure the driver add 1$ and instructions
Tjhosan
(Tjhosan)
March 28, 2017, 9:12am
25
I will take one 30mm LDO 2s with Narsil then
No spring needed
X31
(-X3-)
March 28, 2017, 8:32am
26
I’d like one Narsil 20mm with short spring (okay for e-switch, right ? )
I plan to put it in my fried HC30, maybe with a triple 219C.
Lexel:
electricjelly:
Your right, looks like I’ll need 21mm boards. The second driver is for an older skilhunt H02, looks like 21mm board also.
So I’ll take two 21mm boards and yes, please configure one of them with the resistor and instructions.
Are you using the default mode groups in you headlight? If you have any changes in the mode groups that work better for headlight usage please let me know.
Thank you very much.
Lexel
(Lexel)
March 28, 2017, 8:51am
28
I did modify the modegroups a bit so they fit better to the 7135*5+1 I did put in my skilhunt H03
For a fully equipped 7135*7+1 the standard mode groups will be OK
You can look in the Narsil code and tell me changes if you want
As the light has a DTP star you could also get a higher temperature value when the stepdown kicks in, as it dont get too warm holding in your hands
MrJohnny
(MrJohnny)
March 28, 2017, 8:48am
29
Hi Lexel I did requested for 1x 17mm bistro with long spring but i don’t see my name in the list.
Lexel
(Lexel)
March 28, 2017, 8:56am
30
Narsil Triple v1.4 got released some bugs are fixed and temperature management got updated
Ok, v1.4 of the triple is up now. Find the files in my google drive share: drive.google - NarsilTriple v1.4 (link is external)
Let me know if you find it all ok. Can’t recall how familiar you are with it, but a notes.txt was updated. Turns out the “bug” wasn’t really so bad in NarsilTriple, but I did update how temp regulation works now - I think it’s better, dropping amps in lower increments, longer delay between drop adjustments.
The V1.3 manual still applies, accept for section describing temperature regulation - I’ll have to update that part.
Also removed the project folder under NarsilTriple (was a NarsilTriple folder under NarsilTriple), now the project is in the same parent folder as the solution file.
Tom
Lexel:
I will trust your judgment since your familiar with the host and driver. Please change the stepdown temp to what you feel is best. If you can make improvements on the mode groups I’ll trust your judgment on that as well. Otherwise we can keep them stock. Thanks
JasonWW
(JasonWW)
March 28, 2017, 9:07am
32
I’m a noob with drivers, but I would like to get one driver for my Convoy L6:
30mm, 2S, LDO, Narsil, short spring.
I plan to add a clear side switch with an led to indicate when the rear switch is on.
I would also like the option to have it turn on in turbo with the rear switch.
Are both of those easily done with the normal Narsil or does it require special work?
Thanks
Tjhosan
(Tjhosan)
March 28, 2017, 9:14am
33
Please add the indicator led option on my driver aswell
tekwyzrd
(tekwyzrd)
March 28, 2017, 10:50am
34
Interested in an attiny 85 narsil in the size closest to fitting a courui d01.
Lexel
(Lexel)
March 28, 2017, 2:05pm
35
JasonWW:
Thanks
The turbo on rear switch is just a few lines different code.
for the illumination of the sideswitch when rear switch is on I can add a 4.7kOhms resistor to the driver
Just keep in mind that a the driver supports as well a indicator LED you could add a green as power LED and a red indicator LED to the sideswitch
the indicator LED can be wired on Pin 7 with an additional resistor
I can add for both LEDs a resistor to the driver for 1$
Lexel
(Lexel)
March 28, 2017, 2:38pm
36
Which size has the driver and how much space is in the lights body so parts dont collide with it
It is possible just to piggiback a small driver on the original board
there is a 38.5mm TA driver design that could fit
Of course , now it’s an awesome light . First , it’s running Narsil and second , it’s making 292kcd with a dedomed xp-g2 .
Made the driver with LDO for low parasitic drain
Lexel
(Lexel)
March 28, 2017, 2:53pm
38
More than 2S will burn the 7135 to hell
Yes on this FET-7135 driver, but I don’t run 7135’s only Straight up FET’s 2-4S no worries! Never used a LDO for a 1S 3v either and the Zener in 1S screws with the UI. But thanks!
JasonWW
(JasonWW)
March 28, 2017, 9:15pm
40
Yes, please add both resistors. That will help me out.
Will I need to change the firmware code myself? I’ve never done this.
I assume that once the new line of code is added, the rear switch turning on will made the light come on in turbo, then I can press the side switch to turn it off to standby. Then it will function like narsil normally does, ramping up and down and turning off back to standby. Power LED stays lit.
Turning off/on the rear switch resets everything and makes turbo activate again.
Is this correct?
Tjhosan
(Tjhosan)
March 28, 2017, 9:43pm
41
Oh wait there are two resistors for two leds? Then i want both haha
I need all the bells and whistles on my L6 :sunglasses:
