very nice design, thanks for sharing.
Subscribing to thread to see whether the version works. Will probably order afterwards (depending on parts availability)
I’m working on a baseline firmware to release. Once it’s out I can update with a parts list and so on. Later I can release a full feature firmware for those interested but I suspect the other’s drivers will be more of interest once they are up to speed.
That looks awesome, made it in a 17mm driver! 8k flash, should be able to really make an interesting driver with this one. Extra I/O pins, batt check led’s should now become standard. Can’t wait for this the be ready to roll.
I’m not really involved in the hardware design, but it looks like this opens up all sorts of fun possibilities for firmware.
If I understand correctly, connecting an e-switch would fill the S hole but it could still be reflashed if someone holds the probe against the filled hole? Also, which 7135 is which? Is the chip in the center the PWM one or the constant-power one? I could see people wanting to put a BAT+ bypass there instead of using the offset hole, but only if it’s the non-PWM 7135 chip which gets sacrificed.
Yes. It would only be one pin one would have to hold if the via is occupied. However, I’ve thought about moving a trace and small signal via, this would make room for another S via so this would not be needed. I’ve waited with making this change as I might want to make more changes once I’ve received this latest design. For development testing with the board outside of a light it’s not an issue though, just have to solder together an additional wire or similar.
The center is on PB2, which I use as for dedicated PWM, but PA1 can also be PWMed.
Why would you want to? In my mind a via for a wire with direct contact with the cell is far better. If I know why, maybe I can re-arrange something in a new design.
Only because it’s physically easier to go through the center of the board than through the edge of the BAT+ pad. There’s often a spring in the way. For example:
It’s harder to do that when the hole isn’t inside the spring:
Aha, ok. I always cut the wire at the end of the via and do a separate spring bypass if I am using a spring. I never really though about doing it that way, just pulling the whole wire through.
If I can’t figure out how to shuffle the F-2’s components around enough I can just design a F-1 for those who want it that way. In any case I need to wait for these boards to show up from OSH Park before I make any changes to design.
Exciting. How many cells do you expect you could go up to in series, assuming the voltage divider and FW is appropriately adjusted? Looks like you are planning on only going up to 2S (based on text in the OP), but was wondering if the selected LDO above can go to 4S.
Do you plan on using one of your spare boards as a pin jig for flashing?
EDIT: I heard that 7135's can't go past 2S, but I've done it before with LDO's. Maybe I was lucky with emitter Vf's close to the battery voltage. I did beef up the 7135 heat sinking in those cases, but I really haven't used those lights much. So maybe they will soon die. Anyway, putting aside the 7135's, I'm wondering what the max number of cells you expect will work.
It looks like, for people who want a driver bypass on BAT+, they could just drill a hole through the middle instead of adding the second 7135 chip. I don’t see any critical traces there. Or they could do a normal spring bypass, or put the bypass on the outside of the spring.
4S. However, my attempts with 7135s on 4S where not successful, so for 4S I have shifted my attention to a 3 amp LDO (LT3083). I haven’t gotten around to testing them out yet though. I have all the parts, I just haven’t taken the time (been more interested in getting the ATtiny841 boards ready.
Do you have any more details on the LDO and design you used to get 7135s running on 4S? I’ve got everything working with 4S except the 7135s.
No. My plan is to have one dedicated development board with stiff pins soldered in place. Then when I want to upgrade firmware in flashlights that have the drivers I would perform some acupuncture like the photo in the OP.
Yeah, but designing a F-1 from the F-2 would be fairly easy. First I’ll see if I can achieve it with the F-2, after I have received and tested the latest version.
Anyone know the via drill size used in that MTN 17DD driver? The size I have used is probably too small as it isn’t designed to fit the whole wire with coating.
Useful for single sided drivers that might be getting firmware updates. Basically all my lights are eligible for firmware updates
Done. I fiddled around a bit in Eagle and managed to move the BAT+ via almost dead center (it’s a little off). I also made it bigger with a 1.6mm drill size. I had to sacrifice one of the 0805 C2 caps in order to keep both 7135s but I’m pretty sure only one is needed. I’ll upload v5.3 to OSH Park and share it once v5.2 is tested.
You didn’t have to do that… it was already very good.
My only concern of any substance is whether it’ll be able to fit in common 17mm hosts. But I’m guessing it could have ~0.4mm filed off the edges if necessary? I’d love to hear whether it fits into popular 18650 tube lights, since that size of driver gets used so widely.
To be honest I did it for myself. I hadn’t thought about wiring the LED that way, it’s pretty neat. I also needed a break from coding, so a bit of mucking about in Eagle was welcome.
I changed the via size down to 1.5, but there is enough clearance for a 2mm hole if one wanted to drill it out. I was thinking about putting a hole instead of via, but that would mean a little extra hassle for my lights where I don’t want a driver spring.
I’ve used this same 17.8mm diameter drivers in my S2, S3, M1 and M2s since a long time. I use that diameter so I can file down for a snug fit, although I haven’t had to file anything off but the fabrication panel tabs for the shelfless S3 and M2. Filing all the way down to 17mm would be no problem, there would still be some ground ring left, you would have just hit the holes in the ground ring vias.
When I get a chance, I'll dig up one of my lights that I did it in and double check that they do work properly. If it does, I'll report back.
Well, one thing led to another… now there is a F-4. It’s the same as the F-2 except with two additional 7135s that are on the back side, which in turn required a slightly smaller spring pad so they could fit. Of coarse the two new ones are on another pin, so any number of one to four 7135s can be turned on in constant current, and for any level between I will PWM the 7135 on PB2.
I’ll still keep the F2 available as it has a larger spring pad, otherwise there is no need for it if Nanjg sized springs are used. If only two 7135s are wanted, don’t populate the ones on the back (spring pad) side. I also put another 0805 cap on the back side since I removed one from the F-2. If the F-4 is made with four 7135s, then it’s a double sided board anyway, so two OTSM caps can be used for longer measurable off times if desired.
I also managed to squeeze in another switch via, so if a E-switch is soldered in place there is still an available via for acupuncture style flashing. This is for both the F-2 and F-4.
I want to test that the F-2 v5.2 works before making the v5.3 F-2 and F-4 available. As far as I can tell, no one has ordered the current F-2 so I’ve un-shared it for now because the new v5.3 (that the firmware will be working for) will have a pin change.
Work is getting the way though, I’m being sent of to Israel tomorrow, and then on to New Delhi, so this stuff will be on hold. I don’t want to take small electronics and development stuff will cells, buttons and wires with me because Israeli airport security is a lot tighter than most other countries.
It sounds really nice. I should probably get or make one after it’s known to work, for development purposes. It seems avr-gcc didn’t add support for the tiny841 until fairly recently though, which means I’ll have to upgrade some tools…
BTW, before you finalize anything, do you think there’s any chance of getting a trace from an ADC-capable pin to LED- ? This would allow the driver to sense the ambient light level while the LED is off, which means it could be configured by pointing it at a computer screen with binary code blinking in black and white. Or it could maybe sense whether to skip moon mode when the ambient light level is too high for moon.
