- SingFire 348 with 3535 UV LED from BLF member “sorryIforgotyourname” but I don’t think he’s still selling them. Added a ZWB2 glass
- Lumintop IYP365 with Ali 3535 UV LEDwhich seems to be the same that I bought from said BLF member.Added a ZWB2 glass too. Really powerful, I don’t know how much time the LED will survive.
S2+ shorty 18350 with the same LED and ZWB2 glass too. 700mA driver 1 mode.
They all perform great to show fluorescence and get close to no visible light thanks to the ZWB2.
However, nothing Professional nor directly bought on the shelves…
What is the HDS UV light?
Ok, did some googling, The HDS is indeed that very expensive brand, they do carry a ‘forensic blue’ version that puts out 700mW of radiometric power but fail to mention the wavelength (a big fail IMO for a flashlight that you are going to pay $275 for, why not just mentioning it???). Googling further on ‘forensic blue’ does not get you further, I found 390nm, 445nm, and even 470nm :person_facepalming:
Sooo, what is at least the difference? : The S2+ has a 365nm led which puts out invisible light, about 500mW, while the HDS puts out blue or purple light (so 390nm or higher), depending on what wavelength they use (it needs orange glasses filtering out the source wavelength to obtain contrast with the fluorescence). The application for the different wavelengths are different (I’m not a forensics expert). Further, the S2+ uses an up-to-date high output Nichia led, dunno what HDS uses, let’s hope they are up-to-date with what they put into their flashlights. About value for money, for me that is obvious but there are a lot of HDS addicts out there too
the convoy UV light has one big drawback with the stock aluminum star, it can get too hot damaging the LED
the used Nichia LED is good, but only rated 90°C and 500mA
and most of the Nichia LEDs have a forward voltage of about 3.8V, so you can use only 1/4 of battery capacity before loosing output
It is driver with 700mA which can be a problem when riunning long on a relative high ambient temperature
OK you get 800-1200mW radiant flux depending on bin
I did use heat on my S2+ UV light another way
there is an easy fix here a custom made copper board which performs a lot better than the stock
another option if you go ZWB2 filter anyway is the LiteOn LED that has a dedicated thermal pad,
so it can be used on DTP stars and overdriven easily to 1050mA for about 900-1000mW radiant flux
One of the things I got addicted to: (thank you, djozz )
And from the bussines end (all 365nm lights have ZWB2 filter)
From left to right:
Powdercoated C8 host from 3Tronics, 395/400nm 5050 Epileds UV on 20mm copper (Ali), 6*7135 AMC
Regular S2+ from GB flashsale, swapped 395/400nm 5050 Epileds UV on 16mm aluminum (Ali), 8*7135 AMC
Regular S2+ from GB flashsale, swapped 3535 Int-Outdoor UV on 16mm Noctigon, 3*7135 AMC
S2+ host with SM reflector/pill/driver from “old” Convoy UV-light, 3535 Semileds (led4power) on Noctigon, 3*7135 AMC
S2+ shorty with Nichia UV, 2*7135 AMC
Ultrafire SK68 (ordered for being a real Sipik !! :rage: !!) with 365nm led from “old” Convoy UV-light, driver unknown
EDIT 20180808: because this thread has been been revived, I have replaced the kaputt links to Phot by links to Imgur. In the mean-time more UV-lights have joined the club.
The second and third light from the left are victims of my “NOT my 2000 post GiveAWay” and are currently on their way to Greece and Bavaria. In a few days there will be another GAW and then light #4 from the left will be given away (be it in a red host.).
Really nice collection, however an UV thrower seems to be overkill…I LOVE that :partying_face:
Did you put a ZWB2 glass behind the aspheric ?
How do you like the 395/400nm to compare with 365 ?
how well is it holding up at 1.5A?
I am not sure if I push it to 1.05 or 1.4A.
those UV have only a Tjmax of 90°C and they get damaged real quick compared to white ones if they get too hot
Yes, there is also a ZWB2 filter in the zoomie, just behind the aspheric lens.
I replaced the original black plastic shim by a rather thick and smooth O-ring.
With the head facing down, just lay the filter on the lens, inside the O-ring.
When the head is re-assembled, the O-ring can only move in one direction: inwards.
Until the moment is reached that the filter is clamped on all sides by the O-ring, so to speak.
Of the two kinds, 365nm is far better with paper money.
But 395/400nm is better suited for some organic materials, despite the disturbing purple glow.
@teacher, not being the expert that djozz is, my first impression is that:
- the picture of the UV-led on the Jaxman site looks like the Royalighting or Intl-Outdoor led as reviewed by djozz. It can be driven by 3*7135 AMC (at least I do, on a Noctigon) but Jaxman has a policy of “not pushing the envelope” so they use 2*7135 AMC. This led emits a lot of non-UV light. You definitely need a ZWB2 filter to separate the men from the boys, so to speak, because that filter blocks the white light that prevents you from seeing what you want to see with the UV light.
- the Convoy UV-light with Nichia is standard equipped with a 2*7135 AMC driver. Stick to that, I do. When I got this light directly from Simon (Convoy) it came with a black ZWB2 filter. IMHO the output (spectrum) of this led is better than that of the Royalighting, but it still emits a considerable amount of non-UV light. You also need a black ZWB2 filter for this one.
- the question of upgrading the driver is already implicitely answered: don’t. You will just kill the led.
- as dr. Ruth already said: always wear protection. Certainly when you are using lights with a ZWB2 filter. You won’t see it coming. And not only from shining directly into your eyes but also from the refection in a glass window or bathroom tiles.
I used my Convoy S2+ with the stock MCPCB a few hours and with Djozz board also an hour or so
I noticed that parts of the emitter start to get very dim, no color change like other LEDs had
I guess 700mA is not healthy for this Nichia LED on the stock star
As for UV flashlight, I think Tank007 TK566 is a good choice, professional Japan chip, dark glass as lens which can filter visual light and get more UV light.
With such a high priced UV light, at least give the sutomers more than “japan UV emitter”…
You need to give them more information in order to justify this price.
The host doesn’t seem to have good quality, I really hope that this is a Nichia in there at least
