ok,this time I was there when it transitioned from FULL Discharge to begin charging stage.
Two minutes after discharge was complete and Charging began, it did the same thing as before. It shut off/reset and came back on default charging of 500mAh :person_facepalming:
EDIT: Right before it happened[just like last time] you could hear the fan weaken like it and the unit was losing power, then it shut off/reset and came back on.
Some questions/concerns assuming Jon will let me keep my Opus and test it with a new power supply AND Return it for a new one if it fails!
What will the quality be for a Power supply that was shipped for $6.99?!
Will it meet the advertised specs of 12V/5A or will it fall into the category of so many falsified capacities/specs. of numerous Chinese batteries?*Fire, ect.
No way for me to know until I get it because I have no equipment to test it!
This is just a guess! It is sold for $6.99,probably cost $1 to make, ebay guy buys it for $2 and pays $2 or$3 to ship to me and gets a $2 or $3 profit!!! :laughing:
See even though I brought this issue to light. I’ve never had it happen on a charge discharge test. Only a regular charge. And usually when cells are complelty done for not only half completed. And not everytime just occasionally.
To me its not heat related. I literally have a window ac unit maybe 2.5feet from it blowing directly on it. Shares the same plug with the unit. There’s no way within 3-4 mins it could overheat with 60degree air blowing across it. A good bit of the time the fan won’t even come on. Or cycles briefly with 6000btu air-conditioning blowing right on it
Edit
I’ve done hundreds of charge discharge test 4 at a time at 1amp. Just did 68 last weekend not a issue. (3day weekend for me) ran non stop literally
What made me notice it me and the wife have 3 tomo v8 powerbanls. They charge uber slow. So we change out the batteries. The batteries are at 3-3.2 volts when being charged. And I’ve seen the problem only at the most power draw of a charge cycle. Once the batteries get 3.7-3.8 the power loading shouldn’t be as hard
I just charged them per “Chops” suggestion to see if the charger worked.
He probably asked me because the “Failures” happen when transitioning from Discharge to charge.
That is when the battery is ~ 2.80V and “May” need the most energy to get the charge started? Hence, the thought process that it probably needs more powerful Power Supply.
All this “detective work” is kinda fun.
Our chargers have the exact same issues. I am gonna hitch my cart to our power supply being the problem theory (inadequate supply for occasional demand in certain instances) … (Thanks HKJ…. . )
It will be interesting to see how it all plays out.
I ordered my Power supplies[Two]! ,and I hope it is the solution because I like my capacity test results and a 0.03v additional charge compared to my original Opus!
For some reason Items I purchase from Washington/Oregon area get to me faster than from anywhere else
I forgot to mention the other night—I usually charge my cells first —let them rest—then I do a charge test—the charger tops them off first before the discharge as normal—I don’t like charging for 2 hours then discharging for another 2 + hours and again charging for 2+ more hours—seems abusive to me
Even California[Illumns] will get here in 2 days for First class mail!
I agree, that is exactly what I did as I wait for delivery. Otherwise the CHARGE/TEST can take 8 to 10 hours!
The only time I don’t do that is for a First time capacity test with new batteries where I let the Opus do the whole cycle. The New batteries are usually ~ 3.60 when I get them.
I could be wrong, but I think you are somewhat misunderstanding what Chops is saying. Maybe a little more abuse, but I take it as time saving.
MINE FAILED when I put the batteries in at a mostly charged state and then the Opus discharged, then tried to charge them @ 1amp but reset instead!
INSTEAD of Charging/discharging and charging for the CHARGE/TEST. It save s time if the batteries are mostly charged or at rest after charging then put them in for Charge/Test. that way you save ~ 3 hours.
The Opus is still discharging and charging so you can get the capacity. My failures have been shortly after discharge when the batteries are @ 2.80v and they begin charging again.I believe the INITIAL charge has nothing to do with failure shortly after the battery is discharged.
Again, where mine failed is what HKJ talked about where the charger spikes in output because it needs that surge of energy when the batteries are ALL @ 2.80v. I think he said it jumps to ~ 6 amps for 0.03 of a second!! He elaborated on that last Friday.
EDIT: Besides ALL of that the Opus should be able to do ALL Three stages without an issue!
Jon from Liionwholesale who sold it to me has about 5 of them running constantly doing capacity tests!
OK, I did misunderstand how you were doing it. I thought you were letting the OPUS do the whole thing…… CHARGING almost empty cells - then DISCHARGING for Capacity - then going back into CHARGE Mode
My bad, I’ve got it now. You and chops728 are on the same “program”. It is me that is different as most of the time I did it as described above.
Soooooo…… that tells me that part has nothing to do with the problem…… :+1:
