Yea that does make sense. I don’t know if it would conduct through the masking 1/10th as well the DTP connection. Comparing high temp epoxies in post #23, there was a 10x difference in thermal conductivity just between two different brands of epoxy. Thermal performance can vary widely among materials.
Yeah, I just looked up thermal conductivity properties in Engineering Toolbox and the only materials that even come close to 1/10th (or better) are other metals and Diamond.
You could also isolate the MCPCB with a disc of aluminium nitride or something. Aluminium nitride is really interresting for that kind of purposes, but it’s expensive.
Anyone done any testing/measurements with these? I just ordered some 5000K 70cri E21A emitters from futureelectronics and will report any measurements I do.
They’re bright and comes in 9080! No tint shift so far.
With XP sinkpad you get oval beam, 2p E21A non isolated, with XM sinkpad you get 4p E21A non isolated. Cathode must be soldered to the MCPCB’s thermal pad. Scrap the masking paint between pads for best result (minimal solder thickness). Also to get the most flat arrays.
Any non conductive thermal pad will do. Best with thin thermal grease on an anodized heatsink.
Yes, 4x 17A should exactly fit an (DTP) XP-pad, all minusses (cathodes) soldered on the thermal pad. The body has become led-minus, a minor problem to solve :party:
And with this one we can get the almost impossible to get: 9080 4500K Nichia
I’ll post my result with 2pcs sm503 and 2 pcs sm303 on a XM DTP board later
It seems there are two ways to deal with the lack of a thermal pad. One way is just to electrically isolate the MCPCB from the flashlight body. As clemence suggested, an anodized shelf with thermal grease should isolate fine, but most shelves are not anodized. Another simple way to electrically isolate the MCPCB is to put a layer of kapton tape around the perimeter of the MCPCB so there is no metal-to-metal contact, then fill the space between shelf and star with thermal paste. Kapton tape is 25-50 microns thick and thermal paste has at least 2 W/mK thermal conductivity, so with a 16mm MCPCB the thermal resistance of the thermal paste is 0.25-0.5 K/W, which is pretty small. Anyway, there are lots of solutions to the problem, but this is the one I was thinking of using.
The other way, as djozz is suggesting, is to electrically connect the flashlight body to the (+) or (-) of the LEDs. I read your description of how to have the LED positive connected to the body, but how would you deal with having the LED negative connected to the body? Putting the driver in the tailcap is one way…
Eventhough the thermal pad isn't enough for all LEDs to sit on, I gave them a try...
Please don't complain about it, they're tiny, harder to handle, and fly easily. The sm303 9080 is thicker by 0,1mm. Let's see how Djozz handle the smaller E17A later.
ultra low current by multimeter could lit them all
Could be Windows next logo
Gaps, yes I know...
Fits aliexpress XML optics loosely
Pleasant 4500K
And....pffffffftttt! one dead at 4,6A. With proper MCPCB these should handle up to 8A
The burns damage all through the MCPCB and short the whole array. Three survived, I'll keep them for later test
Thanks for the nice tests! Pity about the burnt led. At 4.6A that is just 1.15A per led (well, ‘just’ as in the usual BLF expectations). Let’s hope that it handles more current when better mounted.
And that was using the 20mm XP DTP MCPCB with the largest thermal pad. Sinkpad XP has much smaller thermal pad. I guess your E17A will fit better in XP MCPCB
The gap looks to be at least as large as in the XHP70, though it will probably be less noticeable because of the phosphor covering, sort of like the XHP50.2. But whether or not you see a donut hole in the beam, gaps reduce the peak beam lux in a reflector light.
Looks way smaller then an XHP70 to my eye, got to remember that this is a 3535 footprint they are sitting on, the xhp70 sits on a 7070 footprint, twice the size.
To me it looks lighter packed then an xhp50. In fact it would not be hard to figure out, if clemence can measure the total size of the dies we can compare that to the total size of the xhp50 dies.
The E21A package width is 2.1mm, so similar to the XHP70 individual die size. Estimating from measuring images:
The width of the gap between the dies in the XHP70 is about 7% of one die width. For the E21A quad pictured above, it is about 13%, even taking into account the small gap between the packages. So there is comparatively more dim/unlit area in the E21A quad.
