And following that, the reason for it being called XHP is obviously to distinguish the 4-die arrangement. It especially makes sense with the 2S2P arrangement of the 6V version.
I also don't necessarily see the unavailability of an improved 5050 1S emitter completely bad. It's time to bake a batch of efficient boost drivers. While not as simple, this easily means fully regulated emitters, 100% PWM free modes, and full battery voltage range utilization.
Also, time to cook low RDS(ON) high current FET switches. Plenty of small & efficient MOSFETs which can be paralleled for reliable & comfortable handling of 10+A tail currents at the press of a tiny switch.
Not only that, but boost drivers put a big strain on the batteries. As the voltage difference (input => output) goes up, so does the current requirement from the cell. We like to overdrive our emitters, but to even reach rated levels with a boost driver would already be very taxing to the cell.
We’re gonna need good buck drivers for our modern “3 Volts” LEDs.
Same problem with buck drivers though: The coil needs to be beefy for high currents, driver needs to be efficient.
Linear constant current drivers have to burn off more excess voltage with those low Vf LEDs
LiFePo is getting interesting, with their more constant voltage of around 3.2 Volts. Still a bit low for the latest LEDs though…
But, meanwhile the modern LEDs are getting more efficient, so you would need less power for the same output.
Well, you’re right about that, but high capacity and high drain are both more expensive than laptop pulls. :money_mouth_face: Seriously though, to need a high-drain cell just to turn your light on, and still not be able to push the LED very hard, just isn’t appealing to me. Maybe when those 21700’s that HKJ tested a while back become commonplace, and good high-output boost drivers are available to make use of them, then I’ll relent. What I think would really be great is for the Vf of the LEDs to continue dropping lower so that either LiFePO4 cells or buck drivers with Li-Ion make sense for single-cell lights, as you mentioned above.
Any load from driver with regulated output is more pleasurable to cell than direct drive.
Most configs can burn you hands with several minutes (even single 14500 cell in Cu X5), really usefull long-time mode wont overload existing cells.
Manufacturing industry cells with high rates raises, while laptops are flowing to the li-pol batteries. $10 for four HE4 cells - not sure that you can buy new laptop cells cheaper.
maybe this is a stupid question, but why we need buck driver for 3V led, when you can simply PWM the voltage
if you want to regulate the output, then add the Rsen, a filter, and something like that, there will be no coil
Pulse voltage will kill led. Led is not slow switch, you cant simple pwm it with bigger voltage like dc motor. Current will raise to enormous amount and led will die in 1/1000 sec.
You need to limit output voltage (direct drive), current (linear) or power (small buck). Otherwise your power supply can meet such point at led V/R curve when current will exceed usual limits.
PWM already sucks enough with our über sophisticated brains and eyes, let alone messing with it for night shots or filming in a world of ubiquitous photography and filming devices. Sucks like there's no tomorrow, imho. For simple low profile designs, maybe you could try switching to better linear drivers like the AMC7136, plus a simple big resistor in series for moon mode. Found something related, btw: Seeking AMC7136 - for a single sided driver design
I know pwm is suck, but not that bad, with high frequency pwm, i bet 90–95 people can’t distinguish
With 32 bit cpu, i think we can push the PWM frequency upto 1Mhz
I know you guy don’t like the Blinking led, but, there are many things blinking around me, and you, we just accept it, and ignore it( your screen which you are using to read that line is blinking, too)
Meteor drivers do exist for over 3 years, components are not very modern, schemotechnics and theory is well-known for 20 or 30 years. But some “driver developers” (fet is not driver imo) were still sure that boost circuits will never work (until klarus realized G20).
In most simple version buck driver can be separated from mcu board, pwm management any constant modes (some fet developers are still sure that this can influence on output ripples, hah), thermal management can be realized with thermistor in parallel with current-setting R.
One board design with high-current curcuit require time that is enough to make 100 or 200 A6-style designs. Testing and bags searching will take extra hundreds of hours. Enormous work for amateurs. Dale provides idea that engineers are nothing, modders are everything. This doesnt work for buck or boost drivers.
