I know pwm is suck, but not that bad, with high frequency pwm, i bet 90–95 people can’t distinguish
With 32 bit cpu, i think we can push the PWM frequency upto 1Mhz
I know you guy don’t like the Blinking led, but, there are many things blinking around me, and you, we just accept it, and ignore it( your screen which you are using to read that line is blinking, too)
Meteor drivers do exist for over 3 years, components are not very modern, schemotechnics and theory is well-known for 20 or 30 years. But some “driver developers” (fet is not driver imo) were still sure that boost circuits will never work (until klarus realized G20).
In most simple version buck driver can be separated from mcu board, pwm management any constant modes (some fet developers are still sure that this can influence on output ripples, hah), thermal management can be realized with thermistor in parallel with current-setting R.
One board design with high-current curcuit require time that is enough to make 100 or 200 A6-style designs. Testing and bags searching will take extra hundreds of hours. Enormous work for amateurs. Dale provides idea that engineers are nothing, modders are everything. This doesnt work for buck or boost drivers.
My hope is that with the new low Vf emitters, and the new 21700 cells, we start to see lights based on those cells that have larger driver sizes. If we could use 22mm+ drivers, all of a sudden higher current buck and boost drivers become more of a possibility.
I do a lot of long exposure night photography and PWM has never been an issue for me. For video, or non-long exposure photography then it may be an issue.
I know several such drivers , buck and boost.
They are more complicated and require more knowledge. So people simply use old good “steam engine” instead of it.Fortunately the most of new powerful led are 6v-12v.So the only way is buck boost drivers.
Took a peek at the last one, at least for as far as browsing a few russian/spanish transgoogled pages. Buck-boost engine, 2.75-4.35V input range, lads speaking of triple parallel nichias. I guess it's geared for 1S emitter output voltage ranges (actual range?), Tamagotchi commented some sort of negative answer after someone asked about driving UV emitters.
Nice.
I believe you should move forward, step by step or whatever. Share and improve your designs. Once you get some good buck, boost and buck-boost designs freely available everything would go much smoother and with way less complaining.
Those appear to be great drivers, yes. But literally none of those drivers meets all the simple criteria I listed above. There are dozens of such drivers that are linear, direct drive, and/or PWM drive. Can you come up with even one driver that meets my criteria? I’m not trying to be rude, but I firmly believe in put up or shut up. You said linear, direct drive and PWM drivers are like steam engines and need to die. I’m just asking that you prove it! Come up with ONE direct replacement!
DavidEF, maybe AEDe sounded a tad radical. I believe what he/she wanted to mean is that he/she is irked for the fact there's a lot (cough…) of research in certain aspects of drivers/flashlights (UI, lighted tailcaps, built-in charging…) and so little in others like actual regulation, efficiency, proper battery voltage range utilization and protection. I sort of have to agree.
Don't expect flashlight manufacturers to magically get involved in stuff if there are no good chances for profit, you may already know that, right? However, if you/we were to develop some nice buck and/or boost designs we could share its design with a manufacturer AND make a somewhat decent deal for an initial group funding/buy, research and development improvements could “hit the shelves”. Don't you did this with Banggood in the past, for example?
i think we are out topic now, we shold go back main topic
so
there is SST-90 led, with use single cell, and produces lots of lumen
the biggest drawback is high price
I expect if there is an XML3 that it will be similar to the XPL2 in die size and output.
The SST90 is interesting; we don’t see many incorporated in mods. It should be able to pull around 15A from a good single cell and provide ~3500 lumens I estimate, based on data from the datasheet.
If you are interested in high output 3V emitters, keep your eye on the Nichia E21A and E17A. They are 3V LEDs with small packages that can be grouped together to make XHP70-like configurations. There are currently heat dissipation issues because of the non-standard footprint of the emitters, however. Nichia E17A/E21A series (April 19th: updated with output tests in the OP)
Am I the only one not impressed by Cree new leds for flashlights?
I mean, tint shift, not easy to dedome, for our goal tricky VF, come on, people scouring LEDs of 1 generation before.
I get flashlight is not main focus so sure the overall idea of Cree makes sense to them, but for us so idk?
Seeing the XHP50 cross get smaller is nice true.
XML2 is a huge footprint for Cree, more material, less units made in one go, they practically scream that this huge amount of space is for different LEDs, not single die, the cost of making a XPL sized led doing a respectable lumens per watt is so much lower, I’d be surprised if the XML line would not be updated and vanishes when the machines making them cannot do it reliable.
Could be wrong of course.
I have nothing to prove. It is only my opinion. I have my own criteria. For example driver should drive modern powerful led xhp/ 144A with 1 *18650 and should has good stabilisation.
As xml3 is still in our dreams and has chance to stay there.(I think xml3 will not be in production because of hi current. 2000lm it is more than 6A.)
Are you doing driver development?
If so do you mind me pmming you for drivers are beyond me, but I am involved in some BLF projects drivers play a critical role in
