Aaah damn, t seems that FT rised up the price, the last time i ordered Y3 from FT it was like…25$? 33…a bit high i presume
Actualy the seller seems to be a bit jealous and kinda strange too
I asked him about a wholesale price of 10 and the answer was( copy/pasted):
” Hello Dear, i offer 18.81$ per latherna , good for you, good! You pay aditional 80$ US dollars for DHL , okay? Great for you
And ofc he maybe joking, but i have never seen a chinece person joking so far….
If he plans of 20$ for a torch…well, i will pass….14.5 is still a good price for it
It might be a ZY-T08 alternative, since it is out of stock in most places. There is a gap between C8 and L2 and I would like to find a moddable thrower around 25$. Any ideas?
Here in the OP: https://budgetlightforum.com/t/-/8279, HD2010 listed as reflector I.D. of 52 mm. Matches Mitko's measurement exactly. So 63.9 mm head for an HD2010 - this light should be at that, or close.
Funny, that HD2010 thread was the HD2010 standard reference. Back in the day, 500 posts were huge, big league Notice the prices? Over $40 list. $30-$35 I recall was a good price for that light back then.
Well it has a chunky head indeed yet the reflector is 52 mm for sure, an exact hd2010 match
Actualy the same torch appeared like 2 years ago priced at 40$ but …40$…come on
15$ with that quality is quite a different story( with original emitter and east 92 driver): reminds me of good old BLF days, thats why i posted about it
Ofc they can always ruin it( liek zoomie ZeusRay, do you remember?) , something so typical for China goods
HD2010 accepted only low profile 17mm drivers, this was the main issue. Also it had space for 20mm pcbs but the manufacturer had opened 18mm space only and used 16mm pcbs, this was often causing short circuit with the reflector.
Hi, I want to know something, led CREE XM-L2 U4 1A, can be driven by Direct Drive Fet, like BLF A6, just an example, I want to buy this flashlight and add this led on MPCB maxtorch 26mm, but I do not know which driver It fits this configuration, greetings and thank you very much.
My only real concern is the reflector . i remember having a hd2010 that was impossible to focus . Mitkos beamshot pic is reassuring…But i still have the memories of horrible beam profiles and finally shorting out the emitter … thanks for that memory “wallbuys ”
Another problem is In my head it’s this or a utorch ut-02…and the BLF devil on my left shoulder is saying buy them both .
I have modded probably 4 UT02’s until now , and i will make another one these days . One of my favourite lights to mod , big stock mcpcb , big driver place nice reflector and easy to center. Not cheap , but it’s an awesome light , stock or not . Get one
UT02 is a great light, xhp35 choice was bad imo. Xpl hi around 4 amps with charging port and the huge reflector would be better. Price would be lower with xpl.
(1) The LED is not centered.
(2) The heatsink is loose.
(3) The bezel can not be tightened down.
(4) The threads of the tube (ends) are not clean and will cut someone.
(5) The exterior of the light is missing anodize, chipped.
