Gearbest New Arrival: March 22nd, Convoy H1 CREE 29.99$
Congratulations for purchasing our zanflare flashlight. You have chosen a high quality product designed from the latest technology.
Zanflare F6 EDC Flashlight Cree XP-G2 200 Lumens IPX8 waterproof
URL: http://www.gearbest.com/led-flashlights/pp_622807.html?wid=21 (link is external)
Material: Brass
Cree XP-G2 with a lifespan of more than 50,000 hours
Body diameter: 14.6mm
Product weight : 31g
Reflector: orange reflector
Drop test impact resistance up to 1.5 meters
Color temperature: 4500K-6500K
Micro USB charging port and* indicator*
Full charging time is about 1 hour
The end is magnetic and can serve as a whistle
Coupon —ZF6DEAL
Coupon price —- 17.99$
Nice flashlight Gearbest!!
The first Zanflare flashlight that I have no design objections against. It takes the small 10180 flashlight type a bit further with a magnetic tail and a wistle (I never have use for a wistle but I like the idea, i.e. much better than the mandatory bottle opener that they put in everything while you can open a bottle with just about every random object in sight, including the Zanflare F6 :slight_smile: ). And I like the looks and that it is made of brass.
Ok then, one design objection: really a next level would be to get rid of the annoying twisty and put in an electronic switch.
The Zanflare F6 looks very interesting.
The Zanflare F6 is very interesting but it does not include the battery, no store sends separate batteries to my country
Uruguay, right? It will be new breakthrough for us, right?
MiBOXER C4 Smart Battery Charger offers flexible charging current options, it is 4 slots LCD dispaly and compatible with Li-ion, Ni-MH, NiCd and LiFePO4 batteries.
2017 April 19th
MiBOXER C4 Smart Battery Charger—EU/US Plug
4 Slots LCD for Li-ion Ni-MH NiCd LiFePO4 Batteries.
MiBOXER C4 is an integrated digital LCD screen clearly displays charging parameters and progress, an intelligent automatic power-off function terminates current when charging is complete.
With flexible charging current options, broad battery compatibility and multiple protections, the C4 is the one and only charger you would need in various scenarios.
URL: http://www.gearbest.com/chargers/pp_624386.html (link is external)
Coupon: MiBOXER
Coupon Price: 26.99$
Compatible with Li-ion, Ni-MH, NiCd and LiFePO4 batteries
Capable of charging different types and sizes of batteries at different current simultaneously
Each of the slots monitors, displays and charges independently
LCD and LED display charging parameters and progress
Optional charging voltage: Ni-MH 1.48V, LiFePO4 3.6V, Li-ion 4.2V / 4.35V
Reversed polarity / over-charge / over-voltage / over-current protection
Made of durable fire-retardant ABS material, durable and safe
Parameter:
Input voltage: AC 90 – 260V 50 / 60Hz, DC 12V ( charger )
Output: 4 × 1.48V / 3.6V / 4.2V / 4.35V + / – 0.05
Input current: 2A
Output current: 0.1A / 0.25A / 0.5A / 1A
Zanflare S2 2M USB Multicolor Indoor LED Strip for EU/ US Plug, 60 RGB IP65 Waterproof 110V - 240V, 11 Color Options, 5-level Brightness, 5-level Speed
2017 April 20th
Zanflare S2 2M USB Multicolor Indoor LED Strip Light:
Zanflare S2 LED strip is extensively applied for backlighting, accent lighting and architectural decorative lighting,
It can stick onto or be wound around many places including furniture, staircases, bedrooms, windows, bars, balconies, plants to light up your colorful life.
Adopting eco-friendly high quality material, S2 is certified by CE, FCC and ROHS.
Features:
LED type: SMD 5050RGB
LED SMD quantity: 60 pcs
Material: aluminium alloy + FPC
Nominal voltage: 5V
Rated current: 3A
Rated power: 15W
Charger input voltage: 110V – 240V
Strip length: 2 meters / 6.56 feet
IP65 waterproof standard
With memory function, automatically turns on with the last mode enabled
11 Color Options: red, yellow, blue, green, light blue, purple, pink, orange, warm white, cool white, multi-color.
5-level Brightness: super low, low, medium, high, super high.
5-level Speed: super slow, slow, medium, fast, super fast.
12 Modes: motionless, escape mode, wave mode, Christmas tree, rhythmic mode, one-color fade, multi-color fade, color stream, run up mode, blinking, multi-color blinking, strobe, etc.
zanflare S2
http://www.gearbest.com/led-strips/pp_624660.html (link is external)
Coupon: S2NEW
Coupon Price: 32.99$
2017 April 24th
BRELONG USB Light Keychain 6 × 5730SMD LED Lamp – 5PCS
Six SMD LED encapsulation mini keychain USB light for laptop keyboard, power bank LED light
Double USB design, both sides of it can be used as the plug. Ultra-thin portable design dedicate for more easy life
Switchable two color temperature for you to choose ( 2700 – 3200K, 6000 – 6500K )
http://www.gearbest.com/night-lights/pp_624821.html (link is external)
9.99$ in Flash Sale
JAXMAN, M2, E2 & E2L, Sitting in row,eatting fruits together with you.
2017 April 27th
1. JAXMAN M2
CREE CREE XM – L2 U2 LED 400LM: 1A 6000 – 6500K/ 3C 5000 – 5500K
http://www.gearbest.com/led-flashlights/pp_621642.html (link is external)
High – low, two kind outputs meet your requirements
CNC machined 6061-T6 aircraft aluminum alloy construction
Built-in advanced protection circuit to extend the battery lifespan and reverse polarity protection to ensure users’ safety
Adjustable two brightness levels: 50Lm ( Low ), 400Lm ( High ). Slightly tap the tail switch of the torch to switch the brightness.
The default level is low level.
2. JAXMAN E2
CREE XM-L2 U2 LED 580LM: 1A 6000K, 3C 5500K
Nichia LED 350LM: 5700K, 4000K
http://www.gearbest.com/led-flashlights/pp_355970.html (link is external)
High – mid – low – strobe – SOS, multiple outputs meet all your requirements
Compact and lightweight, with premium lanyard for carrying every day
IPX-8 waterproof standard, even protects your light from powerful water jets
Powered by 1pc 18650 battery (flat top)
High CRI, more than 90 RA
Switch Location: Tail Cap
Reflector: Aluminum Half an Orange Peel Reflector
3. JAXMAN E2L
CREE XP-G2 LED 900LM: 1A 6000K ( white ), 5A 4500K ( natural white ), 3C 5500K ( neutral white )
http://www.gearbest.com/led-flashlights/pp_619108.html (link is external)
High – mid – low, multiple outputs meet your different requirements
CNC machined 6061 aircraft aluminum alloy construction
Built-in advanced protection circuit to extend the battery lifespan, reverse polarity protection, low-pressure slow flash tip and over-discharging protection to ensure users’ safety
Powered by 1pc flat top 18650 battery ( not included )
Running time: 29h ( Low ), 295 minutes ( Mid ), 90 minutes ( High )
Adjustable three brightness level: 50Lm ( Low ), 300Lm ( Mid ), 900Lm ( High ).
Very good Triple! from Jaxman!
TOMO M4 DIY smart power bank, 4* 18650 Li-ion Battery & Dual Outputs, independent circuit, Reverse polarity protection, zero voltage charging
Custom capacity by 4 × 18650 li-ion battery to make your own power bank, portable external supply, provides your devices enough power.
Also a battery charger for 18650 battery, a dual-use item. Dual outputs, can charge phones, pads or other small electronic devices simultaneously
Independent battery, charging and discharging at the same time, can work together and not influence each other
When it comes to the reverse polarity, the chip inside will automatically identify and cut off the power of the reversed polarity circuit, displays an empty battery level
Reversed polarity will not affect the normal operation of other circuits
Parameters:
Battery: 4 × 18650 li-ion battery ( not included )
Input: 5V / 1.2A
Output: 5V / 1A, 2A
URL: http://www.gearbest.com/chargers/pp_627026.html
(link is external)
Coupon: M4GB
Coupon Price: 11.99$
64.8mm /43.5g LUMINTOP Elfin Mini LED Flashlight – WITH/ WITHOUT TRITIUM
LUMINTOP Elfin flashlight is a luxury gift flashlight with its perfect handy size and eye-catching dazzle color.
As its name Elfin, this little flashlight brings surprises of its glossy surface, for the changeable color of the flashlight in the different view.
In the length 64.8mm and weight 43.5g, you could easily hold Elfin in hand without any burden feelings.
Small and light enough to add to your everyday carry list.
Optimized ultra-precise reflector and double-side AR coated lens which resists impact and thermal shock, offer a more comfortable cool beam of Cree XP – L V5 LED.
Using a single CR123 ( or RCR123 ) battery could approach 4 useful modes for common use:
moonlight mode in 0.5 lumens for lasting long run time;
low and mid mode for indoor and short-distance use,
and high mode offers long beam distance in outdoor.
The inner copper tube body of Elfin provides a better heat dissipation.
Intelligent advanced temperature regulation system allows it to adjust output performance according to its body temperature to ensure stable and safe operation.
The comfortable clicky tail switch is very convenient for one-hand operation, and easily to recognize in the dark through tritium in the tail button.
URL: http://www.gearbest.com/led-flashlights/pp_627003.html (link is external)
Coupon will be shared in new coming week, happy weekends, all
Palm-sized body with chocolate structure surface offers firm grip
IMALENT DM21T warm / Cool CCT
1000Lm Cree XPL HI Palm-sized Searchlight
Intelligent thermal control module automatically adjusts brightness according to body temperature
http://www.gearbest.com/led-flashlights/pp_626560.html
1pc 18650 Li-ion ( 2600mAh ) battery is included
IPX-8 standard waterproof ( 2 meters submersible )
Coupon: DM21TDEAL
Original Xiaomi Philips LED Ceiling Lamp, warm and cozy lighting,
Simple, Beautiful and Intelligent
App Control Dual Light Source Intelligent Dimming AC 100 - 240V
Xiaomi Philips LED Ceiling Light - Support WiFi
It is deigned as sporting white color in a circular shape.
In addition, a moonlight mode which gives the look of the moon when turned on is surprisingly comfortable.
● 5min Fast Installation ( II electric shock resistant )
● 82Ra: 64pcs LEDs of high CRI provides museum lighting effect
● IP60 Dustproof: protects it from dust, and could get rid of the pesky insects
● 2700K to 5700K, brightness range from 0.1Lm to 2000Lm
● 25000 Hours Lifetime: constructed by premium materials and specified processes
● Efficient Heat Dissipation: unibody aluminum plate maintains highly efficient cooling
http://www.gearbest.com/flush-ceiling-lights/pp_633589.html?wid=21
coupon—- MiPhilips
price —- 89.99
Original Xiaomi Transmitter for Philips LED Ceiling Lamp
1pc CR2450 550mA battery
Integrated temperature and humidity sensor
http://www.gearbest.com/led-accessories/pp_633590.html
coupon: TSLamp
coupon price: 16.99$
expired time: 2017.06.30
KLARUS G35 presents its new flashlight, the G30, which is sure to please fans of KLARUS flashlights.
The G35 carries an up-to-date CREE XHP35 HI D4 LED chip with a maximum output of 2000Lm.
Indeed, the G35 features both high brightness and compact size.
The design of the integrated tube and battery compartment lets the flashlight be handled much more easily.
Besides the unique dual-switch adds more convenience in use, which makes it your best EDC partner!
Klarus G35 CREE XHP35 HI D4 2000LM LED Flashlight
http://www.gearbest.com/led-flashlights/pp_635125.html
Coupon: 3afy74n
Coupon Price:$74.99
MecArmy SGN5 - Multifunctional EDC Alarm Flashlight
Cree XP - G2 S4 560Lm USB Rechargeable Instant Alarm / Turbo / Strobe
CREE XP-G2 S4 LED, max 560Lm in such a tiny size
Instant alarm, strobe and turbo for emergencies
USB rechargeable, charges in just 1 hour on any USB port
Charging time: 1 hours ( charging current 5V 0.5A )
Using time: 42 hours
http://www.gearbest.com/led-flashlights/pp_636669.html
Coupon: MecSGN5
Coupon Price: 24.99$
NITECORE NU10, 160Lm White + Red Dual Light Source Multiple Color Options
http://www.gearbest.com/headlights/pp_605448.html
an ultra lightweight and compact solution for runners, campers and anyone needing hands-free lighting.
Equipped with dual light source and dual-switch UI, the NU10 gives out max 160Lm output and provides 3 brightness levels of white light and 2 special modes of red light to preserve night vision.
NU10 features 170 degree wide angle illumination and can be tilted 60 degree to cover your field of vision as needed.
The built-in 900mAh Li-ion battery, can withstand at least 500 recharge cycles, allows the NU10 to run up to 150 hours.
Black, white, yellow, green, blue and red 6 color options. There must be one color suits you best!
NOTE: This product will not be shipped to the United Kingdom.
Coupon —NU10GIFT
Coupon price —- 15.99 $
zanflare F2 LED Flashlight - 4500-5000K Cree XP-G3 IPX8 Water Resistant 4 Modes
Aerospace Grade Aluminum Body with Anti Scratching Type III Hard Anodization
http://www.gearbest.com/led-flashlights/pp_613216.html
Emitters: 1* Cree XP-G3
Mode: 4 (Low - Mid - High - Strobe)
Low: 15LM;
Medium: 50LM;
High: 200LM;
Strobe: 200LM
Mode Memory
Runtime:
High Mode: 0.63H
Mid Mode: 8H
Low Mode: 32H
Max: 30h
Luminous Flux: 200LM
Luminous Intensity: 2630 cd
Color Temperature: 6500-7000K/4500-5000K
Battery Type: 2* AA not Included
Coupon—F2DEAL
Coupon Price—- $12.99 (CW/ NW)
Please check from here:
http://www.gearbest.com/led-flashlights/pp_613216.html (CW/ NW)
NITECORE MH12GT
http://www.gearbest.com/led-flashlights/pp_641261.html
6500 - 7000K 1000LM USB Rechargeable Light
CREE XP - L HI V3 LED
1 x 3400mAh NL1834 18650 battery ( included )
or 2 x CR123A battery ( not included )
Waterproof in accordance to IPX-8 ( two meters submersible )
Output / runtime ( 1 x 18650 ):
high: 1000LM / 1.25h,
mid: 280LM / 6h,
low: 55LM / 28h,
ultralow: 1LM / 520h
Output / runtime ( 2 x CR123A ):
high: 1000LM / 1h,
mid: 280LM / 3.25h,
low: 55LM / 20h,
ultralow: 1LM / 300h
Seek More: http://www.gearbest.com/led-flashlights/pp_641261.html
