One of my DN35'S had the same issue. Even though it is a 26650 cell, the spring needed just maybe to be 1mm taller.
I took my spring out. Set of needle nose pliers and it popped right out. It was held in place by nothing but it's own diameter. No glue or solder. Really hard to press back in but I got it done
What worked on just that light was screwing the head on as tight as I possibly could by hand. No problems after that.
Not sure that will help here. DN35'S and 70's oy have a single 26650 cell. You have 4 18650's so it could make the other 3 fit too tight.
I sent all of my video and information to Imalent. I was thanked, and told they would look into it.
I have two sitting about 3 feet from me the DN70 and 35 ad both are working perfectly. It is a newer company so that could all change at any moment, but I have had the 35 for a couple of months now and the 70 for about a month no problems.
I have had 2 Streamlight Stingers in the last 6 months and both died when they were dropped about 3 feet for the first one during a hunt, and the other was dropped while it was still in the shipping carton so no way to say for sure if it was D.O.A. or when it was dropped here.
Then on the flip side of those I have an old original Ultrafire sk68 that has been beat, dropped, kicked, stepped on and 2 years later it still works every time I reach for it.
I am not outright defending Imalent. I am saying that when I contacted them directly it did take a few days to get a reply but I had no problem with their support.
Any light can have an issue and almost all rate their lumen count far above anything realistic.
I wish they would offer to send replacement parts to customers that have warranty issues and the knowledge to fix it themselves. Currently they want people to ship their light back to China at roughly $50 one way with no insurance.
I was thinking about rolling the dice on a DN70 and hoping I got a good one, but I’m not really a gambler.
I did tell them up front that me shipping anything to China was out of the question. I asked if they had any dealer in the states at all that I could maybe order parts or even ship it to them if I had to.
Got it worked out before any of it came to that.
Honestly though it kind of surprised me when they agreed to start including a spare USB cover. I figured well that is a start.
If the light is bad when it arrives the issue should be resolved with the retailer, not the manufacturer. One must check the retailer policy to see if the return cost is up to them or to the buyer.
It seems that what’s specific to Imalent is that they don’t sell parts. Warranty is always a risk when buying from abroad, be it from China or the US. Even if the manufacturer does the repair without cost, the return and send back often have to be paid by the client. We’re quite used to this in Brazil…
I got a dt70 and my battery holder has 4 large springs. I also have the older version that has the weird looking things that act as spring.
Although they fixes this issue, the springs are very stiff and makes screwing the head quite tight. The older ‘spring’ made a much smoother screw motion of the head into the battery compartment.
Here is my spring loaded version. The only issue is that it does not lockout with a spin of the battery compartment like the non spring version. Also the springs are tight, so the rotation of the battery to the head is not as smooth.
Since you have both versions, can you tell us if they battery tube is longer or where exactly the extra length comes from in order for it to use the coil springs?
Did Imalent make any announcement about the design change or even mention it in any of their sales pages?
They seem to be both exact same lengths. Only difference is the spring which pushes the battery up about 3-4mm higher. You wont hear any battery rattle when you shake the flashlight.
The only other way I can see them switching to coil springs is with a design change. You can’t just swap springs unless maybe they use very cone shaped coils that can compress fully flat.
