Yes, Banl said so in a post about these drivers and I also got a email from Kaidomain stating it as well. User Khas has an H1-A and reported the same. Mine should be arriving soon.
It has on-time memory. Meaning you have to leave it on a level for 3 seconds and it will be memorized. If you turn the light off before 3 seconds it will register that as a half press and then turn back on in the next mode.
I believe this is a driver Kaidomain is making themselves. They created the firmware themselves and its kind of a basic design. Hopefully they will figure out how to put off time memory in it. They also said they can do custom levels if 25 or more are ordered.
hmm, 25 or more….
I know that so many people have so many preferences, so I’m pretty sure this is not going to work, but:
Say I ask Ban for 25 drivers with my favorite UI: 1–6–36–100, always start on lowest with no memory. Would it be possible to get 25 people wanting this enough to pay the extra $1.80 for the envelope and stamp to send it from me to them?
I will just start a list here in post #24, who knows how far we get…. :
Well, I prefer to have mode memory, even though I don’t actually use it much. :person_facepalming: Also, I definitely need direct access to the highest mode, especially if there are 3+ modes. If you can get direct access to both high and low from off, and a mode memory toggle, so the end user can choose, you probably won’t have any trouble getting 25 drivers sold.
Ehm, we are talking about a clicky driver David, how do you see direct access to high and low from off happening?? And I expect with this hardware and no ToyKeeper around at Kaidomain I fear that a requested custom UI can not be too complicated.
Perhaps my favorite UI will round up fewer people than some other UI, but of course my motivation to start this is based on me wanting my favorite UI, so someone else should start an interest list for a different UI. I will just keep my list going in post #24, see what happens…
1% - 6% - 36% (- 100%) mode spacing, I like that . Would also like some other sort of variable exponential driving current discrete set like: 0.03% - 11% - 33% (- 100%).
Mode memory seems fine as it is to me, last mode memory or whatever is it called.
Custom UI requests for a small fee could be a killer feature, at least for a given minimum of features: spacing and mode memory.
Not joining the party for now, would be quite unwise given my current financial situation.
Originally posted on Fri, 04/21/2017 - 14:30; typo fixup.
Just got my H1-A and H2-C drivers 2 days ago. Looks like the MCU is a PIC 12F, same as the FX30 driver that the L6 uses. So custom UI programming should be possible if the drivers were reverse engineered to determine the pinouts. Just need the PIC programmer. I just happen to have a Microchip ICD3…
I added an R100 resistor on top of the existing R025 on the H1-A, current is up to 3.5A at the emitter.
This is up from the stock 2.75A at the emitter I measured before the mod.
Testing was done using an electronic load set to 6.2V constant voltage mode for the emitter, and a bench supply set to 3.7V for the battery.
I forgot to look at efficiency before the mod, but it isn’t great after at about 70%. This is with fairly long test leads though. I wouldn’t push it any further than this personally, the inductor gets hot fast, and it was pulling almost 9A from the bench supply.
Jensen567, I'd like to take a good look at more rigorous testing conditions. Even with good high discharge cells like the LiitoKala 26650-50A, input voltage at the driver would be below 3.7V pretty soon: with about ⅓ of the capacity left, Vbatt barely is above 3.3V with a 10A load. Source:
