New Convoy C8 – Clearly better
1530 posts / 0 new
giorgoskok
giorgoskok's picture
Last seen: 1 day 21 hours ago
A great review from mhanlen : https://www.youtube.com/watch?v=MS0N6vnemZg
ToyKeeper
ToyKeeper's picture
Last seen: 5 hours 54 min ago
J-Dub74 wrote:
Clear anodizing is literally the absence of any added dye.
What people are seeing as “silver” or a glittery/metalic surface is just light reflection.
That might explain both the color and the spots with continuity. If the anodized layer is really thin, it could still appear silver… and might have areas thin enough to conduct. Generally anodizing darkens the surface, so I figured it would need a silver dye to lighten things up again.
J-Dub74
J-Dub74's picture
ToyKeeper wrote:
What people are seeing as “silver” or a glittery/metallic surface is just light reflection.
I’ll have to check with Simon on the details but I think you may be spot-on. I remember him being disappointed in the first several attempts at clear anodizing because it was too dark. He said it looked almost like the grey color he was already selling. It could be that they had to go with a thinner anodization layer to achieve the desired look.
varbos
Last seen: 6 days 1 hour ago
My black 3/5 mode C8 has a feature which I find annoying: when the light has been in a particular mode for more than a few seconds, doing a half-press does not cycle it to the next mode. It just blinks off and comes back in the same mode. I guess it is supposed to be a ‘mute’ function but I don’t care for it.
Does the new C8 with biscotti have this same quirk ?
Phlogiston
Phlogiston's picture
Last seen: 11 hours 23 min ago
All Convoy lights with that driver respond that way. The intent is to guard against unintended half-presses changing the mode after the user has selected a mode they intend to use for a while.
If you half-press twice in rapid succession, the light will change to the next mode, with subsequent single half-presses also changing mode until the light is left alone for a few seconds again.
I don’t think so, but I don’t have one of those lights, so you might be best waiting for someone else to confirm that.
varbos
Yes, I guessed there was some intention behind it (rather than a bug). I don’t like it personally, I prefer a flashlight that always does the same thing when a button is pushed.
I am thinking of buying the clear C8 so hopefully it doesn’t have it.
DB Custom
DB Custom's picture
Last seen: 1 day 20 hours ago
The new ones with Biscotti don’t do that. When we started using he Off-time capacitor it was to do away with that. All the old Nanjg 105’s and Qlites had that type of action, you had to bump it twice to nudge it forward after it’d been on for a bit.
Biscotti in the new Convoy’s brings a wealth of change, virtually all good. Wink
ToyKeeper
ToyKeeper's picture
As far as I can tell, there wasn’t actually any intent behind that. It was an unfortunate side effect of the way it implemented memory.
The “on-time memory” it used worked like this:
  1. Light turns on. Read the mode number from eeprom, and go to it.
  2. Write the mode number plus one to eeprom.
  3. Wait a second or two.
  4. Write the current mode number to eeprom.
  5. Wait forever.
So, if you leave it on for more than a second or two, next time you use it it’ll go to the same mode. If it was on for less than a second, it goes to the next mode. It doesn’t attempt to measure how long it was off.
Biscotti uses off-time memory instead. The behavior is determined by how long the light was off. So, during use, a quick tap always goes to the next mode. This is almost universally preferred. The main downside is that it’s more sensitive to what happens while the power is off, so a lighted tailcap can interfere with the “off time” measurement.
varbos
Very interesting, thanks for explanation DB Custom and Toykeeper.
If it is writing something to eeprom every time we switch modes, could the memory eventually ‘wear out’ ? Or is eeprom write endurance sufficiently high for this not to be a problem during a typical lifespan ?
ToyKeeper
ToyKeeper's picture
I don’t know if the old 3/5-mode firmware uses wear leveling. If so, the ROM should take at least a few centuries to wear out. If not, it should still take at least a decade. And those are both low estimates. Biscotti should take nearly a thousand years, even with quite a bit of daily use, before it ever starts thinking about having eeprom wear issues.
DB Custom
DB Custom's picture
<—— filling out post-it note that TK guarantee’s Biscotti for 1000 years, logging it at 4/28/2017.
I’ll be watching you! Silly
gchart
gchart's picture
Last seen: 17 min 54 sec ago
Dale, I’m afraid to see what your post count will be 1000 years from now. I’m guessing it’ll cause an overflow at some point Silly
DB Custom
DB Custom's picture
?huh ,tnuoc ym fo emos ecuder ot redro ni sdrawkcab gnihtyreve gniyas trats ylbaborp dluohs I
gchart
gchart's picture
I don’t think it works that way Party
(man, after a bit of Sobieski, that took a minute to process!)
DB Custom
DB Custom's picture
ROFLMAO!
I had the standard text on standby, just in case. Silly
Y’all are soon to be on vacation from my ever present wit so enjoy it while you can. Wink
ToyKeeper
ToyKeeper's picture
So, the eeprom is rated for 100,000 erase/write cycles minimum per byte… but in actual testing people tend not to encounter any failures until more like 10 million write cycles. So take 100k as a lower bound and 10M as an upper bound.
With only 32 bytes used for wear-leveling, let’s find out how many times a day you’d have to press the button to make it fail in 1000 years or less:
  • 100,000 * 32 / 365.24 / 1000 = 8.76
  • 10,000,000 * 32 / 365.24 / 1000 = 876
So… to make it fail in 1000 years, you’d have to press the button at least 8.76 times per day (every day) or potentially up to 876 times per day. I’m pretty sure some other part of the light would wear out first, like … the switch.
JasonWW
JasonWW's picture
Last seen: 4 hours 35 min ago
I didn’t care for it either. You can reflash it with a different firmware like guppydrv for instance or swap to a driver that has different firmware on it.
Both my S2+ and black C8 have guppydrv and it’s great.
Texas Ace Lumen Tube calibrated with Maukka lights
Click this to go to signature links.
DB Custom
DB Custom's picture
guppydrv lacks low voltage protection though, something to be aware of….
JasonWW
JasonWW's picture
Really? This is the first I’m hearing of it.
For example, on MTNs website for the Qlite driver it says the driver has low voltage protection then it says guppydrv is an option. It doesn’t say you lose the LVP with this firmware.
Maybe Richard should point this out as I had no idea.
In my 2 lights that have guppydrv I use protected cells. The one I’m working on right now, I had planned to use an unprotected one. I guess I can switch to a protected battery for it. Ah wait, that one was gonna use 2 26350 which are unprotected only. I may need to switch to a different firmware.
Thanks for the heads up.
DB Custom
DB Custom's picture
Richard DOES point that out. He states that the light will downshift but will not turn off.
Which means that it’ll run in the lowest mode till the battery is dead.
If you use the newest Bistro you’ll have a similar number of mode choices, it’s on the list as 9 but by changing H-L/L-H you’re doubling the list. Bistro allows you to set it up as you like, at will, including changing memory by toggling it on or off. You decide if it has 2 levels or 3 or 4 or 5 or 6 or 7 or 8 or 9, at will. You decide if it has moon or not. Also gives you choices with strobes, in a hidden group you back into. And the ability to reverse to a lower mode can go a LONG way towards saving battery life. Bistro is also on an FET+1 driver, so your lower modes are more efficient, pulling from a single 7135 chip instead of 8 or the FET.
JasonWW
JasonWW's picture
Okay, so guppydrv has more of a low voltage warning as opposed to low voltage protection. You’ll know when the battery gets too low, but if the light gets turned on by accident and you don’t realize it, then it can drain the battery dangerously low. Is that correct?
DB Custom
DB Custom's picture
Pretty much, yeah.
When the light is on a higher level and the cell is draining you can usually see that and you’ll know, but by shifting down to lower modes you don’t notice the dimming, so say it shifts down and you’re still fishing, still using the low to bait hooks and what not. The light stays on, you forget it’s on low by it’s own device and in the morning you find your cell at a shocking 2.1V. Oops! Some chargers will accept this, some won’t. An isolated occurrence like this shouldn’t do harm to the cell, but there ya go, it’s up to you to monitor it where true low voltage protection will shut the light off at a safe cell level.
It’s a plus in some cases, you don’t have total darkness without warning, but of course you’re supposed to stop and swap cells when it drops down… you DO have a spare with you, don’t you? Wink
JasonWW
JasonWW's picture
Spare cells?
Shoot, I got spare flashlights!
3 or 4 spare lights just in case.
BobbyMK
BobbyMK's picture
Last seen: 23 min 23 sec ago
Three generations of Convoy C8 flashlights
 Olight i3s, Olight S1, Olight S Mini, JetBeam Jet-1, BLF 348, Astrolux S41S, UF SK-98, Convoy S2+ 3*XP-G2, Convoy S2+ 3*XPL, Convoy S2+ 219CT, Convoy M1, Convoy C8, Brinyte B158, Courui D01, Convoy L6, Noctigon M43
DB Custom
DB Custom's picture
Gotta love em!
I’m betting on Simon having some new stuff for us, he’s alwys on top of things and seems to like lights as much as we do!
Take my money Simon, please! Big Smile
BobbyMK
BobbyMK's picture
I agree with you Dale, i am always excited when i see something new from Convoy because: a) it is not going to cost an arm and a leg; b) it is going to be very good quality; c) when properly modded it is going to put to shame everything in that price range.
Anyways i do really like to see proper thrower from Convoy, not that the L2 or even the L6 when modded are bad but i do want something that can push 500kcd or even more Smile
Jensen567
Last seen: 4 months 1 week ago
I would love to see future lights start to be available with 20mm+ driver sizes. I have a project right now to try to modify a convoy C8 to fit the 20mm H1-A boost driver to run an XHP50.2.
flucero28
Last seen: 2 weeks 6 days ago
Hello all, I am hoping I can get some help. When I compile the .c to .hex in avrstudio 5.0 it is successful. However when I try to write the flash to the attiny13 avrdude gives me an error (ERROR: address 0×0410 out of range at line 65) it then has the path to my .hex file. Can anyone please tell me what I am doing wrong?
Thank you!
EDIT: When I build the .hex file in atmelstudio 7.0 it gives an error stating the 1084 bytes 105.9% Full. What gives?
gchart
gchart's picture
I’m not familiar with that error. But it might help to post it to the firmware howto thread. Plenty of firmware-knowledgeable folks watching that one.
ToyKeeper
ToyKeeper's picture
In both cases, the .hex file is too big. You’re probably missing some compiler options, like -Os and -std=gnu99 , which tell it to optimize for size. See bin/build.sh for the full set of recommended compiler options.
