Well, I tried a direct drive (no driver) Oslon black flat mod and it was a fail. For two reasons:
1)I could not get the Black Flat focussed well in all three dimensions (made the centering piece paper-thin, filed material off the bottom of the reflector, but still the led while closing it all eats its way a bit into the side of the centering piece causing a ever so slight off-centering, for a 1x1mm die that is deadly.
2)the way the light closes, in the final stage when tightening the bezel, the reflector starts rotating too, which is disastrous the way I modded the reflector. I finally managed to short everything out via the reflector and killed the switch.
Need new courage for this, this light brings back bad memories of hopeless mods from a few years ago, with its twisting reflector finding its own way while desperately trying to keep the correct focus :confounded:
Use a light that has a threaded reflector, then when you assemble the light your internal relationships will remain fixed. Something like the Kronos X6, or the XinTin C8 (got that wrong, but you probably know what I mean)
Focussing a tiny 1x1mm die in a reflector this large is about fractions of a mm, you will probably notice a 50 micrometer off-center die in the shape and intensity of the hotspot. You will not get that right with a fixed assembly of internal parts. You either must have a precisely manufactured and rigid (better than I used) centerpiece that relates the die exactly to the reflector, or you need an adjustment system of the led (in 3 dimensions!) that can be employed after assembly (I can not imagine how that can be done in a mere flashlight)
So the part of reflector that is filled down while spinning around catches wires of 20mm pcb and then it shorts them. It needs free 360 degrees in order to center.
Solution is only to have totally flat mcpcb without protruding Ā± wires which will enable free reflector rotation and in that case mcpcb modding is needed or Mitko way with large mcpcb which really looks like the most simple working solution as it allows rotation and tight fit for best focus but as he said it would be nice to have full surface copper machined pill in Kiriba ru style for that.
@l.i., yes, ultimately the Maxtoch board will be easiest. But even then, I set myself quite a challenge with the Black Flat: a reflector that rotates during tightening will always dig itself in, deforming the centering piece a bit and before you know it the led is off.
If I would design a large reflector thrower flashlight for the Black Flat, it would have a bezel that is screwed straight down instead of rotated (MRsDNF-style! looks cool too )
Thinking of that, some notches on the edge of the reflector that are fixed by a protrusion in the head, or simply a flat bit in the reflector falling in a flat bit in the head, will do the job stopping rotation fine.
I would use the threaded reflector to adjust height for focus, Iād glue the mcpcb with Arctic Alumina Thermal Adhesive and adjust the placement of the emitter in the 5-10 minutes it takes for the Adhesive to cure. Put on the bezel and enjoy my light.
If the placement is so critical due to the small emitter size, then exacting precision on tolerances is the key. Starting with a $12 host is the nightmare. Choose the right host to begin with, or make it, and the problems solve themselves.
Some outdoor beams shot I am using iPad mini 4 camera so donāt expect good photos. SupwildFire dd xml2 u4 od about 5000k I guess A6 fet+1 VS Jaxman X1 XHP35 HI 6500K, H2-C driver. That is 160M according to Google maps.
The first three Night photos SupwildFire the last three Jaxman x1. Donāt know how far on this! First two night photo is supwildfire last two jaxman x1 and indoor photo @9M indoor photo are supwildfire.
The next one came , this time it`s a S4 1A based( from the old ones, 4.7amps capable) and tests shows it 280-300cds , the hotspot is nearly perfect, i just need to sand the pill this days, ordered some Ar glasses from KD and i am thinking about a new pill, the default one isnt that good.
The pill and the defautl driver are kinda different from the first one that i got
Can you give us some measurements ? (Pillās) Threads OD , height etc
If not , no problem at all
Edit : Just measured my UT02 with dedomed S4 1A i made 3 days ago , i think the emitter is one of these djozz described as old-dot-pattern/new-phosfor-type and itās making 300,4kcd with a rested Liitokala battery . It would be interesting to check this flashlight with this led too
Very encouraging results guys. Now I know I can expect around 330 from my mod.
But inconsistent production? LOL that should be really crazy adventure. But if it accepts UF T20 pill than there should not be any problem. Problem would be with inconsistent reflectors.
Perseverence! Got the Black Flat working in this nightmare! I made no pictures, hereās some words:
-replaced the blown switch with the same KAN28
-Sanded the base of the reflector as thin as I dared, less than half a mm
-I already had cut away the sides of the reflector base to make room for the wires (see somewhere above in this thread)
-as also mentioned above I used a Black Flat on a 20mm Kaidomain DTP board (sanded down to 19mm), no driver and original driver board used as contact board, both springs bypassed with the cap over the tailspring removed, 30Q battery
-I had to bevel the inner edge of the pill quite a lot to allow the reflector to come close enough to the led, this was essential!!
-I still used a centering piece, reamed the hole a bit because the Black Flat is slightly bigger than 3535-size, and with the base of the centering piece sanded paper-thin, the reflector is now less than half a mm above the ledboard
-I cleaned the reflector after all that filing and sanding by soaking with water and soap, last rinse with distilled water. The reflector still looks quite abused though.
-sticked Kapton tape over the cut-outs on the reflector, and also over the ledwire solder blobs
-I silicon greased the thick o-ring on the inside of the bezel so that upon closing the bezel it would glide easier over the glass.
I positioned the reflector as well as I could over the led+centerpiece, glass on top and while pushing the glass down firmly with a rubber pad I could screw the bezel almost down to maximum tightness, but not the very last bit, so I fixed it by tightly wrapping the groove where bezel and head meet with two layers of cellotape (sounds ugly but it is hardly noticable, and very effective)
The led is in perfect focus but ever so slightly off-center: the hotspot looks fine but the corona is slightly assymmetrical. On an almost full (4.06V after all measurements) 30Q battery I measure 694 lumen (which is very close to max for this led), 5.0 amps and 343kcd (measured at 7 meter after 30 seconds). The output is pretty stable so heatsinking is good and the Black Flat seems happy sofar. If the led had been perfectly centered and I had not abused the reflector so much (and by using AR-coated glass) it could have been a bit better even.
Are there any numbers on an old-style dedomed XP-G2 S4 2B in a HD2010 btw? Could be over 400kcd I guess?
Hereās the hotspot on a white wall with the flashlight at 7 meters distance:
