1 please
I’ll go for one please.
…I’m in for one. A triple the size of a sc63? Yes!
I would like to input on the design, add a bevel or chamfer on the middle portion of the body tube, and if the tailcap could use a magnet as a button plus a cutout for a ring magnet + trits, it would be heaven.
We’ve done some computation on that matter and these were rather promising. More data to follow as soon as we have the first prototypes. However, it should be clear that you can’t expect a light of that size with that output to be stable on turbo for extended periods…
Tommy
Ah yes, a space for a 6mm x 1.5mm trit in the tail would be nice, preferably in the switch but also maybe done as a keyring attachment point so theres an option.
Just a thought.
Please put me down for 1
In for two please.
Put me down for one!
In for one :+1:
I am interested in 1.
Sign me up.
Do you have a preliminary weight of the light?
I’m in for one!!!
But why no XP-l!?
The XP-L doesn’t fit under unmodified Carclo triple optics.
With triple channel and the high lumens the chosen LEDs give it would run too hot to handle on turbo yet should be able to give nice output for a longer period on lower modes, its Narsil so a perfect brightness is easy to set
Not a lot of room for cut outs for Fritz trits
The switch assembly will have a rubber dome beneath the metal switch to press to insure the best waterproofing. I see modders having a go at adapting that for a trit if they want to.
This is a small elegant light
Will update list later.
Around 55 grams/ 2 ounces excluding the battery.
Throw me on this list! I really like the looks of this one!
In for one, please!
Thanks
This project came along at just the right time. I have been pondering a triple and was either going with the Astrolux s41 or a Jaxman E2L, but this one with Narsil and the machinist’s touch looks to be an even better choice. I’m excited about this.
Forgot that the s41 is a quad…
