I just a few minutes ago accidentally found an item on your website that I have been wanting and at a decent price. I look up a coupon code for it and it will not work. The item is listed under home which shows a code for 15% off. I open a chat and was told there is no code for that item. I then ask trying to save time if you guys carry 18650 plastic spacer inserts and was told to search the site.
This would have been my first order from you guys. Even at the decent price for the item I wanted I’m going to pass.
We have tons of coupon codes listed here and many do not work or only if you order meets a certain criteria that is not mentioned or posted here.
And to be told to search the site.
Honeatly, tell me what would you do in my place.
I have a copy of the chat if you would like to see it.
Never had this problem with other vendors posting here.
1. if the products are not at sales, then please use the following coupons to try ( some products may not be used because of the Super Hard MAP or High Cost), reduce the price from full price
[/quote
Hi Terry White,
please read this, thanks[/quote]
Gotcha. The code not working really didn’t bother me that much, even a 15% discount would have only been a couple of dollars. Being told to just search the site for a product I asked about is what realy got under my skin.
I did by the way, did a search for about half an hour. I’m pretty sure you carry the item but it can be called by so many different names it is hard to locate even on site’s I shop regularly.
I can’t speak for the whole forum and I am still relatively new here but, if most are like me we only trust a very few sites to order from, and that relationship starts with the experience of that first order.
I also tried the code OUT15OFF in about a dozen knives that were not on sale and it hasn’t worked for none of them.
This code used to work well before the New Year, but no longer.
The highest coupon code I’ve found is only 8% off, and nowhere as high as 18% for RC item, while Huina should be included (as this is RC item as well)…
