Gearbest New Arrival: March 22nd, Convoy H1 CREE 29.99$
2017 April 24th
BRELONG USB Light Keychain 6 × 5730SMD LED Lamp – 5PCS
Six SMD LED encapsulation mini keychain USB light for laptop keyboard, power bank LED light
Double USB design, both sides of it can be used as the plug. Ultra-thin portable design dedicate for more easy life
Switchable two color temperature for you to choose ( 2700 – 3200K, 6000 – 6500K )
http://www.gearbest.com/night-lights/pp_624821.html (link is external)
9.99$ in Flash Sale
JAXMAN, M2, E2 & E2L, Sitting in row,eatting fruits together with you.
2017 April 27th
1. JAXMAN M2
CREE CREE XM – L2 U2 LED 400LM: 1A 6000 – 6500K/ 3C 5000 – 5500K
http://www.gearbest.com/led-flashlights/pp_621642.html (link is external)
High – low, two kind outputs meet your requirements
CNC machined 6061-T6 aircraft aluminum alloy construction
Built-in advanced protection circuit to extend the battery lifespan and reverse polarity protection to ensure users’ safety
Adjustable two brightness levels: 50Lm ( Low ), 400Lm ( High ). Slightly tap the tail switch of the torch to switch the brightness.
The default level is low level.
2. JAXMAN E2
CREE XM-L2 U2 LED 580LM: 1A 6000K, 3C 5500K
Nichia LED 350LM: 5700K, 4000K
http://www.gearbest.com/led-flashlights/pp_355970.html (link is external)
High – mid – low – strobe – SOS, multiple outputs meet all your requirements
Compact and lightweight, with premium lanyard for carrying every day
IPX-8 waterproof standard, even protects your light from powerful water jets
Powered by 1pc 18650 battery (flat top)
High CRI, more than 90 RA
Switch Location: Tail Cap
Reflector: Aluminum Half an Orange Peel Reflector
3. JAXMAN E2L
CREE XP-G2 LED 900LM: 1A 6000K ( white ), 5A 4500K ( natural white ), 3C 5500K ( neutral white )
http://www.gearbest.com/led-flashlights/pp_619108.html (link is external)
High – mid – low, multiple outputs meet your different requirements
CNC machined 6061 aircraft aluminum alloy construction
Built-in advanced protection circuit to extend the battery lifespan, reverse polarity protection, low-pressure slow flash tip and over-discharging protection to ensure users’ safety
Powered by 1pc flat top 18650 battery ( not included )
Running time: 29h ( Low ), 295 minutes ( Mid ), 90 minutes ( High )
Adjustable three brightness level: 50Lm ( Low ), 300Lm ( Mid ), 900Lm ( High ).
Very good Triple! from Jaxman!
TOMO M4 DIY smart power bank, 4* 18650 Li-ion Battery & Dual Outputs, independent circuit, Reverse polarity protection, zero voltage charging
Custom capacity by 4 × 18650 li-ion battery to make your own power bank, portable external supply, provides your devices enough power.
Also a battery charger for 18650 battery, a dual-use item. Dual outputs, can charge phones, pads or other small electronic devices simultaneously
Independent battery, charging and discharging at the same time, can work together and not influence each other
When it comes to the reverse polarity, the chip inside will automatically identify and cut off the power of the reversed polarity circuit, displays an empty battery level
Reversed polarity will not affect the normal operation of other circuits
Parameters:
Battery: 4 × 18650 li-ion battery ( not included )
Input: 5V / 1.2A
Output: 5V / 1A, 2A
URL: http://www.gearbest.com/chargers/pp_627026.html
(link is external)
Coupon: M4GB
Coupon Price: 11.99$
64.8mm /43.5g LUMINTOP Elfin Mini LED Flashlight – WITH/ WITHOUT TRITIUM
LUMINTOP Elfin flashlight is a luxury gift flashlight with its perfect handy size and eye-catching dazzle color.
As its name Elfin, this little flashlight brings surprises of its glossy surface, for the changeable color of the flashlight in the different view.
In the length 64.8mm and weight 43.5g, you could easily hold Elfin in hand without any burden feelings.
Small and light enough to add to your everyday carry list.
Optimized ultra-precise reflector and double-side AR coated lens which resists impact and thermal shock, offer a more comfortable cool beam of Cree XP – L V5 LED.
Using a single CR123 ( or RCR123 ) battery could approach 4 useful modes for common use:
moonlight mode in 0.5 lumens for lasting long run time;
low and mid mode for indoor and short-distance use,
and high mode offers long beam distance in outdoor.
The inner copper tube body of Elfin provides a better heat dissipation.
Intelligent advanced temperature regulation system allows it to adjust output performance according to its body temperature to ensure stable and safe operation.
The comfortable clicky tail switch is very convenient for one-hand operation, and easily to recognize in the dark through tritium in the tail button.
URL: http://www.gearbest.com/led-flashlights/pp_627003.html (link is external)
Coupon will be shared in new coming week, happy weekends, all
Palm-sized body with chocolate structure surface offers firm grip
IMALENT DM21T warm / Cool CCT
1000Lm Cree XPL HI Palm-sized Searchlight
Intelligent thermal control module automatically adjusts brightness according to body temperature
http://www.gearbest.com/led-flashlights/pp_626560.html
1pc 18650 Li-ion ( 2600mAh ) battery is included
IPX-8 standard waterproof ( 2 meters submersible )
Coupon: DM21TDEAL
Coupon Price: 32.99$
Original Xiaomi Philips LED Ceiling Lamp, warm and cozy lighting,
Simple, Beautiful and Intelligent
App Control Dual Light Source Intelligent Dimming AC 100 - 240V
Xiaomi Philips LED Ceiling Light - Support WiFi
It is deigned as sporting white color in a circular shape.
In addition, a moonlight mode which gives the look of the moon when turned on is surprisingly comfortable.
● 5min Fast Installation ( II electric shock resistant )
● 82Ra: 64pcs LEDs of high CRI provides museum lighting effect
● IP60 Dustproof: protects it from dust, and could get rid of the pesky insects
● 2700K to 5700K, brightness range from 0.1Lm to 2000Lm
● 25000 Hours Lifetime: constructed by premium materials and specified processes
● Efficient Heat Dissipation: unibody aluminum plate maintains highly efficient cooling
http://www.gearbest.com/flush-ceiling-lights/pp_633589.html?wid=21
coupon—- MiPhilips
price —- 89.99
Original Xiaomi Transmitter for Philips LED Ceiling Lamp
1pc CR2450 550mA battery
Integrated temperature and humidity sensor
http://www.gearbest.com/led-accessories/pp_633590.html
coupon: TSLamp
coupon price: 16.99$
expired time: 2017.06.30
KLARUS G35 presents its new flashlight, the G30, which is sure to please fans of KLARUS flashlights.
The G35 carries an up-to-date CREE XHP35 HI D4 LED chip with a maximum output of 2000Lm.
Indeed, the G35 features both high brightness and compact size.
The design of the integrated tube and battery compartment lets the flashlight be handled much more easily.
Besides the unique dual-switch adds more convenience in use, which makes it your best EDC partner!
Klarus G35 CREE XHP35 HI D4 2000LM LED Flashlight
http://www.gearbest.com/led-flashlights/pp_635125.html
Coupon: 3afy74n
Coupon Price:$74.99
MecArmy SGN5 - Multifunctional EDC Alarm Flashlight
Cree XP - G2 S4 560Lm USB Rechargeable Instant Alarm / Turbo / Strobe
CREE XP-G2 S4 LED, max 560Lm in such a tiny size
Instant alarm, strobe and turbo for emergencies
USB rechargeable, charges in just 1 hour on any USB port
Charging time: 1 hours ( charging current 5V 0.5A )
Using time: 42 hours
http://www.gearbest.com/led-flashlights/pp_636669.html
Coupon: MecSGN5
Coupon Price: 24.99$
NITECORE NU10, 160Lm White + Red Dual Light Source Multiple Color Options
http://www.gearbest.com/headlights/pp_605448.html
an ultra lightweight and compact solution for runners, campers and anyone needing hands-free lighting.
Equipped with dual light source and dual-switch UI, the NU10 gives out max 160Lm output and provides 3 brightness levels of white light and 2 special modes of red light to preserve night vision.
NU10 features 170 degree wide angle illumination and can be tilted 60 degree to cover your field of vision as needed.
The built-in 900mAh Li-ion battery, can withstand at least 500 recharge cycles, allows the NU10 to run up to 150 hours.
Black, white, yellow, green, blue and red 6 color options. There must be one color suits you best!
NOTE: This product will not be shipped to the United Kingdom.
Coupon —NU10GIFT
Coupon price —- 15.99 $
zanflare F2 LED Flashlight - 4500-5000K Cree XP-G3 IPX8 Water Resistant 4 Modes
Aerospace Grade Aluminum Body with Anti Scratching Type III Hard Anodization
http://www.gearbest.com/led-flashlights/pp_613216.html
Emitters: 1* Cree XP-G3
Mode: 4 (Low - Mid - High - Strobe)
Low: 15LM;
Medium: 50LM;
High: 200LM;
Strobe: 200LM
Mode Memory
Runtime:
High Mode: 0.63H
Mid Mode: 8H
Low Mode: 32H
Max: 30h
Luminous Flux: 200LM
Luminous Intensity: 2630 cd
Color Temperature: 6500-7000K/4500-5000K
Battery Type: 2* AA not Included
Coupon—F2DEAL
Coupon Price—- $12.99 (CW/ NW)
Please check from here:
http://www.gearbest.com/led-flashlights/pp_613216.html (CW/ NW)
NITECORE MH12GT
http://www.gearbest.com/led-flashlights/pp_641261.html
6500 - 7000K 1000LM USB Rechargeable Light
CREE XP - L HI V3 LED
1 x 3400mAh NL1834 18650 battery ( included )
or 2 x CR123A battery ( not included )
Waterproof in accordance to IPX-8 ( two meters submersible )
Output / runtime ( 1 x 18650 ):
high: 1000LM / 1.25h,
mid: 280LM / 6h,
low: 55LM / 28h,
ultralow: 1LM / 520h
Output / runtime ( 2 x CR123A ):
high: 1000LM / 1h,
mid: 280LM / 3.25h,
low: 55LM / 20h,
ultralow: 1LM / 300h
Seek More: http://www.gearbest.com/led-flashlights/pp_641261.html
NITECORE F2 Flexible Dual-slot Battery Charger for 14500 / 16340 / 18650
http://www.gearbest.com/chargers/pp_649367.html
The F2 flexible power bank is dual-slot, outdoor power bank battery charger.
This double duty charger can power 18650, RCR123, 26650, 14500 and other IMR / lithium-ion batteries using the micro-USB, USB 3.0 cable,
be able to charge cellphones, flashlight, headlamp and other USB devices as a power bank with batteries.
Lightweight and durable, this is the perfect charger for outdoor activities such as hiking, climbing, backpacking, etc.
Compatible with: Li-lithium-ion / IMR: 26650 / 18650 / 17670 / 18490 / 17500 / 17335 / 16340 / ( RCR123 ) / 14500 / 10440
LiitoKala 18650 Li-ion Rechargeable Battery
1. LiitoKala Lii - 22A
3.7V 220mAh for Flashlight
Long life expectancy, recharge times up to 500 times
http://www.gearbest.com/batteries/pp_663621.html
2. LittoKala Lii - 25A
3.6V 2500mAh for Electronic Cigarette
Head Type: Flat Top
Protected: No
http://www.gearbest.com/batteries/pp_663875.html
3. LiitoKala Lii - 29A
3.7V 2900mAh for Electronic Cigarette
http://www.gearbest.com/batteries/pp_663880.html
4. LiitoKala Lii - 30A
3.7V 3000mAh
http://www.gearbest.com/batteries/pp_663882.html
5. LiitoKala Lii - 32A
3.7V 3200mAh for LG MH1
http://www.gearbest.com/batteries/pp_663891.html
26650 Li-ion Rechargeable Battery
1. LiitoKala Lii - 50A
3.7V 50A for Flashlight
http://www.gearbest.com/batteries/pp_663615.html
Cool new Liitokalas. Too bad there’s no shipping to Finland.
Sorry, sorry for come some late :wink: and sorry for the shipping method :person_facepalming:
Dear Gearbest, thank you for making the new Liitokala cells available, I can even see new shipping options .
Are there any technical specs available for the new 18650 cells? Do you know what the discharge could be? Would it be safe to assume that a 500 cycle cell has high-discharge ratings?
thank you!
Hi, Liitokala cells are restocked now with coupon in the thread: Gearbest Daily Deal Updated: March 16th 2021/ Baseus LED Flashlight $21.99 with the code: GBREAKER - #2776 by gearbest :wink:
Technical specs for LiitoKala Lii - 26A 18650:
Model: Lii-26A(For 2600JM)
Type: Li-Ion 18650
Nominal Capacity: 2600mah(2500-2600mah)
Nominal Voltage: 3.7V
Working Voltage: 2.75-4.2V
Limited Charge Voltage: 4.2V
Rechargeable Battery: Yes
Rechargeable Times: Up to 500 times
internal resistance: ≤50mΩ
I cannot give you an answer from my assumption;) I will ask for experts if they would like to make a honest test for the cell, expecting ~
Thank you for your advice ~
Kind regards,
Jona
From specs quoted 50mOhm of internal resistence has good discharge capacity. The question is how much high currents do you need ?
