✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
Update: Deal expired. ⪢ Better deal available here ⪡
Update: PRICE DROP to $29.95!
Astrolux S42 4xNichia 219C/XP-G2/XP-G3 A6 2023LM Rechargeable Mini LED Flashlight is for $45.95 $29.95 in preorder and with BG points price can be still lowered:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$25.46
$25.16
$24.86
$24.56
$23.96
  • Free tracked shipping included.
Additional 18650 body tube available here: Astrolux S41/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $3.29 or with BG points for:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$2.80
$2.76
$2.73
$2.70
$2.63
So, any technical details?
What is the driver size, type and current?
In one line it says ‘High efficiency constant current circuit’, in the other it says A17DD.
Sorry, it seems this release was a complete surprise. AFAIK no one seems to have any more confirmed info at the moment.
Judging from the description it uses standard FET + 1xAMC driver with ToyKeeper firmware like BLF A6 and Astrolux S41 but that’s just an educated guess.
Voltage indication using LED under the button could be realized on separate PCB along with USB charging functionality. That’s probably why there’s duplicated voltage level indication using main LED - they did not modify A6 driver at all, just added charger board with side button and LED indicator under button. They already have experience with this driver and probably enough spare units so using that is cheaper and means faster time to market. This would mean the setup is highly modable as the main mode-driver could be simply substituted. But we will not know for sure until somebody will take it apart and do a proper review. Probably that’s also the reason it’s so competitively priced in preorder along with the ability to use BG points to get it even cheaper for loyal customers.
Lumintop Copper Worm And Nichia 110LM Wateproof Keychain LED Flashlight using coupon 2017fnl drops price from $32 to $21.70.
Last 17 pieces left.
how to use BG point to lower the price? I tried to use it, but it shows BG point can not be used for unbeatable price.
There must be some other item in your cart with unbeatable price - it doesn’t have any special designation beside usual orange Promo tag.
Purchase this item in separate order. You can use check marks on the left side of the item to disable it from current order to see which one is causing the problem.
If that’s not the case or you only have one item in your cart try refreshing your cart and/or clearing browser cache and cookies.
XANES 300LM Sensing Headlight Night Fishing Cycling Double Light Source Rechargeable Clip Cap Lamp is in preorder for $5.99. ~150 pcs left at that price. Main LED with reflector seems to be Cree XP-E, there’s also COB LED for diffused light. Package includes headband (not pictured) and apparently 2 USB cables.
IR sensor probably works similar to Boruit IR “sensor” headlamp - i.e. just for switching selected LED on and off. Description does not clarify that aspect.
Battery has standard 2 pin connector (same as used in small drones) and is easily replaceable.
BlitzWolf® BW-LT5 Pro IP68 Waterproof LED Panasonic 3350mAh Powerbank Emergency Camping Lantern with coupon travel is 20% off at $15.19.
Lamp uses single 18650 Panasonic NCR18650B 3400mAh (typical, 3350mAh minimum) cell but it’s not replaceable, it’s USB rechargeable and has ability to charge other devices via standard USB type A female port. It is completely waterproof, white light has two steady modes with up to 75h runtime in low mode + 3 modes red light (2 emergency blinkers + steady red), uses separate blue LED as charge indicator.
Restocking! Any chance of getting this sale again?
High quality Original Xiaomi 20000mAh Polymer Power Bank 2 Dual USB Output with Quick Charge 3.0
using coupon mipd2w brings price from $32.99 to $26.39.
Registered shipping included.
Rainbow heat treated stainless steel Astrolux M02 XP-G2/XP-G3/nichia 219B 100LM USB Mini LED Flashlight is for $13.26.
Three types of LEDs are available. Li-ion 10180 cell is included.
BLF A6 XPL 1600LM 7/4modes Non-anodized EDC LED Flashlight 18650 use coupon code 2017FNL to drop price from $26.95 to $18.86.
Silver version.
BLF A6 XPL 1600LM 7/4modes EDC LED Flashlight + INR18650-30Q Battery use coupon code 2017FNL to drop price from $29.95 to $20.96.
Black version with included high drain Samsung INR18650-30Q cell.
BLF A6 XPL 1600Lumens 7/4modes EDC LED Flashlight 18650 use coupon 8A955D to drop price from $26.95 to $22.91.
Black version.
Astrolux S1 XPL 1600LM 7/4modes LED Flashlight 18650/18350 use coupon 76648A or 2017FNL to drop price from $29.95 to $20.96.
This is exactly the same flashlight as BLF A6 but with different name and additional matching 18350 tube already included in the box.
Those deals are time and quantity limited but I will try. We have to wait for enough stock to arrive.
how does it work? thanks.
Haikelite is under restocking right now so we have to wait until new stock arrives. When the light is avaiable again you can use BG points to drop price according to your account VIP level as shown in the table. You still need enough BG points to do so.
Update: :scissors: price drop! :scissors:
Original Xiaomi Miband 2 OLED Display Heart Rate Monitor Bluetooth Smart Wristband Bracelet use coupon MIBD2 to drop price from $24.99 to $19.99, registered shipping included in price.
BlitzWolf® 15W 2A Foldable Portable Dual USB SunPower Solar Cell Panel Charger with Power3S using coupon code D321CD brings price down from $32.99 to $26.39 (20% or $6.60 less). This panel can easily charge any smartphone and will also charge in overcast conditions as well (with decreased rate of course).
Registered shipping included but currently in preorder - stock is due to arrive on May 31.
Update: preorder deal ended. Now only coupon available.
Klarus G35 XHP35 HI D4 2000LM 18650 Outdoor Illumination 1000m LED Flashlight is now in preorder for $75.99 and BG points are working so it’ possible to drop price further, according to your account VIP level:
Update: Use coupon D1F1C4 to drop price to $83.99.
VIP0/1
VIP2
VIP3
VIP4
VIP5
$64.59
$63.83
$63.07
$62.31
$60.79
Astrolux S3 XPL-HI 1400LM EDC LED Flashlight 14500 for VIP2 and above accounts price is now $23.95 (instead of $35). BG points still work so price can be further lowered to:
VIP2
VIP3
VIP4
VIP5
$20.12
$19.88
$19.64
$19.16
Both tints: 1A and 3B are available at the moment.
