Jason, did you put power to the 2 SMD LED’s in Series or in Parallel? Reason I ask is because those are 3V LED’s and the power supply is 8.4V on a fresh pair of cells, so either you ran them in series or the power supply point you found on the driver is a 3V output side supply point. Is that supply point from the Inductor (silver box like component) actually 3V? Think I’m seeing what you did there, makes for a nice and easily sourced lighted side switch without a lot of hassle.
At first I didn’t see why the two slots then I figured out it lets you feed the switch board from the inside, completely wired up.
Thinking slow these days… just looking to confirm I’m seeing it right.
The clear switch covers are from Convoy. Simon uses them on the clear version of the L6. He will send you some only for the cost of shipping (a couple dollars) or if you buy something he can add them to the order for free.
The LEDs I got from DBCustom. I’m pretty sure they are sized 0805/2012. They are cheap if ordered from china. EBay has lots of them.
At first I thought 1206 leds would fit, but as you can see, they are a little big for the switch pads.
Yep, the notches are just to slip the switch PCB through. It would be nice if Simon designed the L6 with notches, but a small round file does the job pretty easy. The top and bottom of the ridge get really thin so that’s the best spot to file.
If you look at the pictures you can see where I bridged the 2 pads on the back of the switch with a small metal wire and ran a single wire to them.
The negative side of both leds connect to the blue negative wire on the pcb. The switch was designed with 4 pads on the back. One positive wire for the switch and one positive for each led. That way you can use 2 different color leds like for battery voltage, USB recharge indicator, etc… All 3 positive wires share the one negative wire.
The positive voltage source on that metal can is battery voltage, so 8 volts roughly. If I had added 1 led I could have used a 5k to 10k resistor to drop down the voltage. Since I added 2 leds, for better light distribution, a 10k to 20k seems to work well.
I dont think it’s possible to run the 2 leds in series since they share a common ground.
I plan to tidy this up and reduce the chances of a short by using a tiny smd resistor now that I know what value to use. I’ll look through some old circuit boards to salvage one.
I plan to pull this current driver out soon to put in my Tx Avenger FET driver from Lexel when it arrives. It will also have a lighted side switch when the tail switch is turned on.
I’m gonna put this current driver (detuned to maybe 4 or 5 amps) in a little Supfire L5-S. It uses a 29mm driver, a clear momentary side switch and a clicky tail switch. Add some 26350 batteries, some copper spacers, shorten the reflector depth, add an xhp70 and you have a mini version of the L6! Lol
I looked at doing this lighted switch design on my Black L6, but it’s got an FET driver and I wasn’t sure where to draw power… figured the switch wire was coming from the MCU which had a regulated voltage of >5.5V due to the Zener mod, but couldn’t get it to work… might have something to do with my pain meds, don’t know. I have LED’s on the board, will look into it later.
I took the driver out and used magnets to hold the batteries together and to hold the negative wire to the battery. Then I pressed the driver spring up against the battery positive. It was pretty tricky to do. Then I could use my multimeter to find a constant source of positive power on the top of the driver.
For the full voltage simply connect to the V+ from the main LED and then to ground via a resistor. Lots of grounds you can use from the input to the FET or the ground ring, OTC ground, C1 ground ect.
Built hundreds of FET drivers, pretty much know the drill there. Just not used to using these tiny SMD LED’s. Nor am I used to doing the mods so heavily drugged. :confounded: Probably shouldn’t, have burned myself a few times lately. Left hand and arm are totally out of whack.
Jason, the package those LED’s came in identifies them as SMD SMT 080. Hope that helps. I got 8 colors, 20 in each tape, for like $8 and some change on ebay.
That would only light the side switch when the main beam is on (and not needed then), but not when the light is in standby mode.
My whole reason for wanting the lighted side switch is so I would know whether the rear tail switch is on or off. It also helps to locate the switch in the dark instead of having to feel for it.
By connecting the side switch LED to the main led V+ and then to the ground ring via a resistor (most likely between 25-50k), the LED will be on anytime power is applied to the driver. The V+ is connected directly to the battery and so in the ground ring.
In all the FET based drivers we use the positive is always connected, we only control the ground. Since you are bypassing the 7135/FET by going directly to the ground ring (with any of the connection points I listed above) the LED always gets power when power is applied to the driver.
You would need a firmware and driver that supports an indicator LED in order to control the LED past that.
I could have done this instead of searching and probing for a positive battery source? I didn’t bother to check this because I assumed it only had power when the main beam was turned on.
Well what I said above applies to the BLF FET drivers in reply to DB. Some buck and boost drivers do switch the positive side, so you need to see if yours is one of those. If so then you can usually tie into the LED ground and then into a voltage source.
The easiest way to find the V+ voltage source is generally to look for the vias from the spring and see where they come up and follow them to the first easy to tap into location.
Okay, so it’s best to take it case by case. Don’t assume. Just apply power to the driver and probe around to make sure you find a good voltage source.
My next driver is going to be one of yours and it has a spot to add a “power on” led. Now since the led has to use the same negative wire as the momentary switch, can you tell me which pad is positive and negative?
I labeled them A and B.
Hmmm, maybe it’s not important. I can try the red switch wire to A and the blue switch wire to B. If the LED doesn’t light, I can switch them around.
Nope, that could damage the driver. Pad A is for the red switch wire and pad B is the ground so that gets the blue switch wire.
