Congratulations Tom, best to your Daughter and her family as they adjust to sleepless nights…
And Congratulations to the team with the arrival of the new Proto #3 and it’s apparent success.
Awaiting further instruction.
Just to clear up any confusion, does the Q8 actually have a larger hotspot than the Securitlng or is it set at a brighter level and the camera is blowing it up to look bigger?
No tri blade endcap? No biggie. This one looks fine. :+1:
waits for the order code
It’s looking good!
Thank guys for update. please add more 2-3 for me ( my original post was #405) any tentative period for order ?
Wow to a lot here!
Thanks for the triple channel firmware info.
Yeah DrJones is highly respected but doesn’t do open source a key factor for the projects I do.
He did, with TK helped with the first parts list for the driver though, pretty awesome in my book when little me asked these two heavy hitters and they answered and gave input.
Tom wowsers, gonna edit topic title later
Looks good.
Gonna check with Barry where the samples for the team are, for it seems a good check by us all is all that it needed to give the go!
Thorfire did good, also our German friends will love the Chinese Export marking as I do
I missed that hot logo before.
Dang it looks professional, sweet!
Can’t resist after seeing the latest prototype, please add me for one.
The labelling isn’t as clear on the new version, cheapens the look. Having said that, its not a deal breaker.
EDIT Shouldn’t have viewed on a 4 inch screen. On a 26” now and I agree version 3 is better.
What do you mean?
It’s clearly sharper and better looking.
Now, working on it, this post thus also doubles as MARK
Done list should be up to date.
Well it seems all we need is the samples for the team if Tom does not discover things needed changing.
I hope/think they are already on their way!
The tools do flash a hex costs you less than 5$
http://www.ebay.de/itm/SOIC-8-SOP8-8-Pin-Test-Clip-Test-Clamp-Testing-Programmer-IC-For-BIOS-24-25-93-/272632155108?hash=item3f7a248be4:g:
http://www.ebay.de/itm/LC-01-USB-ISP-Programmer-fur-ATMEL-AVR-51-ATMega-ATTiny-/172347499024?hash=item2820b62210:g:0LYAAOSwLnBX3S-v
The markings look great
Guess how I know……
Oh yeah
I just found
A small parcel in the mailbox
The usual plastic baggie
Didn’t think much of it so tore it open
Some white sheet padding
A small pristine brown box
Opened it
A sheet of black padding
YAY
It
Is
Here
This is prototype 2 of 7
I so hope other team members will find something too!
First look (not even put cells in it) sweet
SO HOPE WE CAN LABEL THEM SAMPLES!!
Great news Miller! That answers your question if the other 6 prototypes were send out as well as Tom’s one.
(oh, no, I’m so busy ’till sunday night that I will not even be able to even check the mail for middle-of-the-road plastic bags :person_facepalming: )
You should have known better, not being able to check the mail…tss …
Sadly i can check my mail 24/7 as i will never be a working man again kinda sucks cuz the same fact also severely affected my online shopping powers.
regarding the BLF Firmwares running out of space and IOs, what bigger MCU could be the next step? And can old code be used?
Lamps getting more and more nice / complex. I see multicoloured lights, some with displays, more or RGB status LEDs.
Can’t the AT84 and little more expensive and newer AT841 be seen ad future MCUs, more pins, more channels anx better power usage for the 841 if I understand Mike C correctly.
Looking forward to seeing what the team thinks of the Proto 3 lights. Thanks for the pics Tom! Those comparison beamshots are amazing as well. The “grouping” is obviously much tighter with the Q8 than the Securitying. Did they thicken the shelf or did the team decide it was ok with the shelf thickness from Proto 2?
The shelf, we (well I) said it was OK for a thicker copper slab would add depth and it already worked great with a thinner smaller OD ledboard
Just to clear up any confusion, does the Q8 actually have a larger hotspot than the Securitlng or is it set at a brighter level and the camera is blowing it up to look bigger? No tri blade endcap? No biggie. This one looks fine. :+1:
Yes, I do believe the hot spot in the pics is bout accurate to what I'm seeing. It doesn't mean though the 4X SRK clone throws much better. Found in my notes back on July 5th when I did the full mod to that light I measured 52 kcd, but that was at 5,450 measured lumens @30 secs and ~16.0A tail (clamp meter). I never could get as much amps out of that light as I could with the Q8 prototypes.
This is good news you received your Q8, The Miller - bout time you get a look
