Replaced Black and Decker "Single Source" 18V battery with HarborFreight, but charging not stopping
22 posts / 0 new
ohaya
Last seen: 11 months 3 weeks ago
Hi,
A long time ago, we bought a Black and Decker “pole saw”. This uses a “Single Source” 18V battery pack, so I bought an extra battery pack, which was quite expensive, so googling at the time, found several Youtube videos about replacing the battery (inside) with the internals from a Harborfreight 18v battery, so I bought 2 of those Harborfreight 18v batteries and they’ve been sitting around in our living room for probably 5+ years now…
Anyway, so now the original batteries are not holding charge very well, so I did the swap on one battery last night.
The Harborfreight battery fits the original B&D enclosure ok, but I had to flip it around. The wires and the connector were long enough so I could just pop out the contacts from the original block and push the HF contacts in in kind of reverse order (+ on right, – on middle).
So then I put it on the original BD charger, and it is charging, but it’s been awhile and the red light on the BD charger isn’t going off :(. I pulled the battery after like 8 hours, and measured and it is now about 20+V. I haven’t had time to try the battery yet or compare voltage to the other original battery, but was wondering if anyone knows if and why that new HF battery will not stop charging in the BD charger?
Thanks,
Jim
P.S. I do have a hobby charger, so maybe I need to use that instead of the original BD charger with the HF battery?
Barkuti
Barkuti's picture
Last seen: 6 hours 9 min ago
For a 5SxP pack, full charge voltage is 21V. It has not finished yet, for whatever reason (slow charging rate maybe).
Cheers Party
LumenHound
LumenHound's picture
Last seen: 3 hours 36 min ago
Those old nicad packs can do that if they have been sitting around in a heavily discharged state for 5+ years like your packs have been. The simple wall wart charger from Black and Decker detects a low voltage and thinks the battery is a 12 volt model and not an 18 volt model so it doesn’t start the charging cycle or if it does, it takes 12 hours or more to reach charge termination.
Hobby charger to the rescue.
fix dead battery video
snakebite
snakebite's picture
Last seen: 2 days 1 hour ago
iirc those have a timed charger.i have a b&d “grass hog” at the shop.it seems to be a dumb timed charger.
i rebuilt the packs and i dont remember if it even has a thermal switch in it.lots of fast chargers use it for termination by temp.
ohaya
Hi,
Ok, I will try the hobby charger when I have a chance, but I tried it in the saw, and it wouldn’t go in all the way. Not sure why yet, but it could either be the blades are too wide in the Harbor Freight connector, or the black dividers between the blades/contacts may be in the wrong position. Darn :(!
snakebite
snakebite's picture
you could have a “brand lockout” tab you need to break off.
common when the same tool is sold with different brands.
ryobi and craftsman is an example.
an extra tab on the pack to prevent cross use.i sliced it off with a dremel.
ohaya
snakebite wrote:
you could have a “brand lockout” tab you need to break off. common when the same tool is sold with different brands. ryobi and craftsman is an example. an extra tab on the pack to prevent cross use.i sliced it off with a dremel.
Hi,
You all would be SO PROUD of me :), I found the problem!
So when I tried to put the battery into the saw, it would hit something. I could tell whatever it hit was pretty solid, but couldn’t tell what it was.
So, I borrowed my daughter’s white nail polish, and put some on all the leading edges of the battery connector part and shoved it into the saw. The white nail polish stuck to the part inside the saw that was contacting, and it was the “bottom” part of the grooves, so I dremeled the bottom part of the 3 grooves on the battery connector, and then, VOILA, the battery connected fine and it locked into the saw!
So now I am going to do the 2nd Single Source battery (I had bought two of the Harbor Freight batteries, way before. I am glad I can finally actually use them!
Also, I am putting the first one I modded into the charger again and will see if it ever terminates (red light goes off).
Thanks,
Jim
ohaya
So I was checking the original B&D battery (the one I took out earlier) and it’s showing like 2+V. Any chance that if I zap it with my lab power supply, say at 18V, that it might come back to life?
If not, how do I setup the hobby charger? It looks like there are a total of 15 batteries in the pack. Someone said for 5S NiCD? Is that right?
dchomak
Last seen: 9 months 3 weeks ago
I have found soooo many of those Black and Decker 18V NiCads in the recycle bins. Many, many of them looked to be brand new, tosssed there by Home Depot.
NEVER have I ever been able to get one to perform. I have tried zapping, slow charging, fast charging etc.
Believe me, I have tried.
ohaya
Ok, thanks, dchomak. You WOULD be the Homedepot guy :)!
So do I just charge it as 5S Nicd on my hobby charger (the one that has the Harbor Freight battery in it now)?
Also, FYI, the reason I was asking about trying to resurrect the old battery is that Harbor Freight doesn’t carry the ones that I bought before – they have a “new design” and I am not sure if that is swapable.
Barkuti
Barkuti's picture
I said 5S, yet not Ni-Cd.
I'd dare to buy 10 high discharge li-ion cells and assemble a 5S2P pack, or a 6S pack of ANR26650M1-B LiFePO4 cells LoL. Easier alternative: 5S LiPo packs. Mooch (E-CigaretteForum) reviewed some 3S packs recently, may be worth checking out.
Cheers Party
ohaya
I’d dare to buy 10 high discharge li-ion cells and assemble a 5S2P pack, or a 6S pack of ANR26650M1-B LiFePO4 cells LoL. Easier alternative: 5S LiPo packs. Mooch (E-CigaretteForum) reviewed some 3S packs recently, may be worth checking out.
Cheers Party
Hi,
I am not “rebuilding” or building a new pack using Li-ion, but rather I have another “new” Nicd pack (the Harbor Freight on) that I want to fully charge (but which does not terminate when I charge it using the original B&D charger, so I think the suggestion was to use my hobby charger (an Accucel 6) to charge the Harbor Freight “18V” battery pack, which is now in the B&D pack “body”.
So I was asking, how/what do I set the Accucel to charge?
Actually, I am trying now, and when I select Nicd, it looks like I only get to select the current, not the “S” or voltage. I am charging the “new” Harbor Freight pack on my Accucel 6 now, setting for Nicd, and 0.5 amps.
I am also confused about something else. As I said this has 15 Nicd batteries, so wouldn’t that be 15 in series to get 15×1.2V = 18V?
Thanks,
Jim
EDIT: Ok the Harbor Freight pack (in the B&D enclosure) finished on my Accucel 6, at 22.91V, 00062 mAh. That was with the Accucel set to Nicd and 0.5 amps.
So now I am going to try to recharge the 2nd B&D battery (unmodded) on my Accucel and see what it does.
snakebite
snakebite's picture
its 15s.
set it to 1a.nicd mode
cycle a few times to “wake up” your new cells.
the old cells are goners.
the reason these die is cheap cells and the fact they get fast charged and used at a high rate.then forced to continue running after the first cell drops.
if you run it till it slows way down you just damaged it.reversing one or more cells.
ohaya
snakebite wrote:
its 15s. set it to 1a.nicd mode cycle a few times to “wake up” your new cells. the old cells are goners. the reason these die is cheap cells and the fact they get fast charged and used at a high rate.then forced to continue running after the first cell drops. if you run it till it slows way down you just damaged it.reversing one or more cells.
Hi,
Thanks. What voltage should I discharge the pack down to? And discharge also at 1A?
snakebite
snakebite's picture
15v.thats 1v/cell
and 1a is fine.
ohaya
snakebite wrote:
15v.thats 1v/cell and 1a is fine.
This is for the 2nd original B&D battery (I haven’t decided to replace the pack with the last HF pack I have):
- Charge @ 1A – ended at 23.12V and 1312 mAH
- I’m running discharge to 15V, but I have it set at 0.5A, but it looks like it only is pulling 0.2A (it doesn’t seem to be able to output 0.5A). My wife was complaining that when she used this pack, that it “seemed to be slow”, so maybe she was right? And maybe I need to replace the pack with the last HF pack that I have?
Thanks,
Jim
ohaya
Thanks,
Jim
Ok, the battery finished discharging, but it discharged at only 0.2A max. I don’t understand why the battery is only able to discharge at 0.2A but can charge at 1.0A? What does that mean? Is the battery now bad?
EDIT: I was just reading this: http://www.scarpaz.com/Attic/Documents/NiCd.pdf and it seems like discharge rate is supposed to be 0.2C.
From the charge/discharge, it seems like capacity of the battery is about 1300 mAh – 1400 mAh, so 0.2C would be about .26A. Is that correct? If so, then maybe the 0.2A I was seeing from discharge testing is ok?
snakebite
snakebite's picture
your hobby charger is probably limited in discharge power.
my original tritons have a fan and can discharge an 18v pack at 1a.
sounds about right for the hf packs.
nothing high quality about them and they are 5+ years old.
i used sanyo 1800’s a friend got a deal on a large qty.
they are a high rate fast charge rated cell.
they hold up longer than the higher capacity cells.
ohaya
snakebite wrote:
your hobby charger is probably limited in discharge power. my original tritons have a fan and can discharge an 18v pack at 1a. sounds about right for the hf packs. nothing high quality about them and they are 5+ years old. i used sanyo 1800’s a friend got a deal on a large qty. they are a high rate fast charge rated cell. they hold up longer than the higher capacity cells.
Hi,
I am pretty sure that the Accucel can discharge test > 0.2A, at least for non-Nicd (this is really first time I worked with Nicd), but anyway I tried other B&D battery, the one that is supposed to be still good, with the original B&D batteries, and it is only discharging 0.2A also.
So maybe they put something into the packs to limit the current draw to 0.2A?
snakebite
snakebite's picture
read the manual for your accucell.
it is power limited.
a power tool is useless with a .2a limited pack.
Hi,
LumenHound
Sorry, I must have missed it. Turnigy Accucell 6, Accucell 8, or Accucell 8150…?
The 8150 can discharge 150 watts.
aarone
dchomak wrote:
NEVER have I ever been able to get one to perform. I have tried zapping, slow charging, fast charging etc. Believe me, I have tried.
Agreed. I gutted all my 18V single source Ni-Cd cells and converted them with an adapter to take ryobi 18V li-ion packs. Best thing I ever did.
