If the price is right…I’m in…
MfG
list updated
100+ :beer:
Very much interested
I’m in depending on price
Interested, please
Unless we check for nasty stepdown i will have to wait …
Giorgo, from Klarus…
” • ITS (Intelligent Temperature System) temperature control monitors internal temperature and adjusts outputs for balanced brightness; protects the LED and internal components; ensuring safety, stability and optimal performance
interested…thanks!
And that’s the reason i won’t be in , even though I’m sure Martin will offer an awesome price !
Thanks for the info Dale
beamshots found in german forum:
I, uh, well, just couldn’t wait. Mine will be here Monday.
Sorry Martin. I have this little flashlight problem…
Haha
where did you order?
i hope you at least used a general code or something else to save a bit?
Interested depending on price.
I discovered a new site called flashlitZ, they’re in Tulsa Oklahoma which isn’t all that far from me (all things considered) They were offering a 10% off discount on a first purchase from the store so I used that and the introductory pre-order price. I was impatient, as I have about 20 days before I have surgery and after that I’ll be out for probably 2 months. My G35 is in Austin, about 60 miles South of me and the hub that will send it to my home town. So it will definitely be out for delivery Monday morning.
great!
i hope you can share your valued opinion with us :beer:
I aim to do as much of a review as I can accomplish, under the circumstances. If it’s not glued I’ll disassemble it and get pics. If it’s glued, I don’t know that I’ll be able to defeat that in my present condition.
Interested! Thanks
I received e-mail notification that my G35 is out for delivery, so another couple of hours should have it in my eager little hands!
Will post about some initial findings, of course…
We can’t wait :innocent:
Got a package today. This is not a review light, nor is it from this group buy. I found someone closer to me and ordered it on the 6th, remarkably it got here today, the 15th, ahead of schedule as everywhere I saw this light listed it was on a Pre-Order status.
Light looks really good, finish is spot on with no visible mars or blemishes. Fit’s the hand really nicely, it’s like a grown up version of the UT02, in virtually all respects. With a tail switch AND a side switch, both giving the same functions, operation is very easy. Holding both buttons down simultaneously for 2 seconds locks it out. If you hit a button while in lockout it blinks red 3 times, reminding you that 3 quick clicks of either button will remove the lockout. Doing so gives you the 2 blinks of the LED signifying lockout is toggled and it returns to off. (If you hold the light upside down in your hand, such that the index finger is at the tail cap, it’s fairly easy to do the lock-out with one hand, even with my hands being on the small side.)
The reflector is significantly larger than the UT02, it’s got a flat reflective area around the emitter, would’ve liked to have seen a wider aperture with the centering ring filling the space. There are some of the usual slight artifacts showing that it’s an HI Cree emitter, nothing really obnoxious but the little tell tale signs are there. It’s got a nice tight semi-bright aura around the hot spot, Looking at the reflector it’s well done but not the best I’ve seen. You have to look hard though to see that it’s not a perfectly smooth mirror finish, there are microscopic giveaways of the machining underneath the mirror plating. Virtually all reflectors show this, so I’m probably OCD about this.
I found that Efest 2500mAh button tops work well, they’re longer than Sony VTC6’s which only allow the single cell slot to work, the other 2 C6’s are loose, not making contact. So I soldered copper buttons on the Sony flat tops, got contact but it could be broken with a hard shake, soldered another of my thin copper buttons on (two thin discs on each cell) and now everything is great with the VTC6’s. Should be plenty of room for protected cells, and virtually any cell should be capable of producing the current this light is drawing… especially with 3 cells in place. With one cell, the level 4 (top setting) is of less output as you’d expect, but still decent in spite of this. Great that the driver gives an emergency option, to use one 18650 or 2 CR123 cells. Versatile.
With the C6’s not freshly charged, I see these numbers…
28.74 Lumens
121.10
393.3
2114.85 at start (after the other readings)
2038.95 at 30 seconds.
At 5 Meters testing, I got 223.5Kcd for 945.52M throw.
EDIT: At the emitter, voltage and current read as follows…
0.03A at 10.49Vf
0.08A at 10.92Vf
0.24A at 11.53Vf
1.88A at 13.97Vf
With only one VTC6 it does 1486.95 lumens in level 4.
All in all it’s a very marked improvement over the UT02, a light that I like a lot already… so the Klarus will certainly become a weekly favorite on my 600 yard walk.
