I would like to get one put me on the list.
Thanks
Please add two for me.
add me 1
Please include me in the list. I appreciate your teams effort to bringing us this nice light!
In retrospect it looks like that Manker clip isn’t a clean through cut, I still think that would be neat though, spelling out what you want while skeletonizing it at the same time. A bead blast before ano would remove any burrs.
You’re right, I didn’t notice that it isn’t cut through. Just after you mentioned it you notice the R would be floating…
Will update list later
It is a neat idea
Cut FW3A through the clip
The A would make a triangular hole for a lanyard too.
With the e-switch, the tailcap isn’t nearly as long as mechanical switch lights. I would rather have a standard clip than a deep carry clip with this design.
Add me to the list please
Sure, if I can find anything precise enough to measure it…
Any details on the driver, levels, u.i. etc?
Driver is being designed now
UI, Narsil so almost too many options to mention to choose from by users via simple interface
Please put me up on the list for one - haven’t purchased a flashlight in months :money_mouth_face:
Yes of course!
Humm, hard to resist, if there’s a hiCRI option or TK’s screen configuration, I won’t be able to justify not buying it … :innocent:
I’m down for 1
Okay, I managed to find some digital calipers. No idea how accurate they are, but the precision is 0.1 mm.
The SolarForce clip appears to be formed from a steel sheet 1.2mm thick. The ring is 1.4mm wide where it wraps around the light. The ring’s inner diameter is 22.4 mm, and the outer diameter is 25.3 mm. The main, long portion of the clip is 8.5mm wide.
The light itself measures 25.1 mm in diameter, so the clip ring sticks out a tiny bit. The threads measure 21.8 mm, which leaves the clip ring a bit loose.
I have the bulky Solarforce clip on a couple of Solarforce lights, in that context it works all right. The Sinner Cypreus is far too elegant a light , IMO, for the bulky Solarforce clip. I have the Titanium clips Sinner supplied on all of mine and they work fine. I’ve been asked to modify Sinner’s lights for the Steel Flamed clips that cost a fortune, in my opinion they are far too strong and do not yield which represents a possibility of damaging a copper light by ripping screws out of the threads. Just my 2 cents. That might be more valuable or less according to my status with Sinner, as I am essentially his North American Warranty Repair… I’ve seen a good many Sinner lights that people have messed up in one way or another.
Thusly I am saying that, in my experience, the strength of the Solarforce clip is too much for a small 14500 light. I either would remove such a clip from the FW3A or wouldn’t buy the light at all if it came with such a mismatched clip. Purely my own taste in lights and clips, of course.
Sign me up for 1.
KuoH
It looks like the FW3A is about the same size as a Sinner Cypreus, just a few mm shorter. Big enough for the 18650 cell and not much else.
The clip will likely scratch it a little, but with the clear-anodized aluminum it shouldn’t be very noticeable. No screws to strip either, so a sturdy clip should be reasonably safe as long as it doesn’t clamp down hard enough to make it unusable.
My Cypreus has some small marks where the clip makes contact, but if I always keep it rotated to the same position it isn’t an issue. I tried using it without a clip for a while, but it didn’t take long before it rolled and fell and got dinged up, so I put the clip back on. It also helps add an extra mm internally for the battery, which has been helpful. This early model was a bit tighter inside than his later builds.
In any case, there’s a very good chance I’ll end up ordering a bunch of FW3A lights to give to people, since it seems like it’ll probably turn out to be unusually nice at a much lower price than anything else like it.
