That’s what I was thinking. The top side of the board wasn’t sitting as flat like the bottom side without the head fully assembled, wouldn’t the reflector push the LED board fully flush with the shelf?
Yes, that board hanging loose from the pill just doesn’t look right.
Although depending on how well clamped it would be to the pill, once its inside the head, it might not be an issue. Thanks to Texas_Ace’s test here As long as its pushed down tightly and both surfaces are smooth all should be well.
I received mine today, it was ordered from fasttech and i must say i got a nice surprise, first is that the tail cap is lighted with blue leds and the second is the included pocket clip. Those things are not mentioned anywhere, not even at the convoy store at aliexpress. Good stuff i must say.
I guess my plan for a fet driven S2+ will wait since i don’t know if the BLF A6 driver will work properly with the leds in the tail.
Yes 2 LEDS. Not really bright. It has only a small gap where the light can come out so at daylight or in a room with the lights on you can’t see it. You can only see at dark places.
Mine came today and also has the tailcap light.
The threads are super smooth and the finish is excellent.
The MCPCB is copper.
Only needs a Biscotti firmware to make it better. Mine came with green Convoy labeled driver with old firmware.
Tomorrow I will change it to biscotti. I hope the tailcap does not mess bisscotti but I think I will need some bleeder resistor as my other Biscotti Convoys with tailcap light.
And the led centering ring maybe can be flatter a little in the reflector. I can see some white around it when I look straight in it.
Wouldn’t 330Ω mean that the leds would receive something like 0.01A thus depleting the battery in less than 2 weeks? or the resistor is not the one that controls current to the tailcap leds?
I got a light build with 4.7kOhms bleeder and 20k LED resistors
Get a bit below 0.1mA, but the leds are through a clear cover bright like tritiums, not to be seen when not almost completely dark
With the 330 Ohms in tail the bleeder must be really big
