It does the job…
Plan on buying an XHP35 HI mounted on a 25mm and just flatten the shelf. I did an XPL HI on a 16mm with a nice amount of throw but the donut hole is pretty bad.
I may of cheated here. If I could learn how to add extra chips I’d be real happy. ltp tried but I still failed miserably.
This is a 26mm MCPCB with dedomed XML2. I machined .25mm from the base of the reflector. On assembly it made no difference whether the isolator was installed or left off. The same petal pattern was still there.
You are kidding us right?
Lux results since we have only 2.8A draw around 150kcd?
Machining is cheating Just kidding…
I have forgotten the calc for working out throw. If you can refresh my memory I’ll take a measurement.
Because of the design of the light it is near on impossible making a pill with better heat sinking abilities. The OD where the 26mm MCPCB sits is 27mm which just fits in the head and as the battery tube and pill overlap there is no room to move there. The holes for the led wires were drilled on an angle to not get them to break through the side of the pill and to get to as close as I could to the outside edge at the top.
If the end user wants more light I’ll have to either improve my soldering or put a fet driver in at the risk of blowing the led.
An fet driver won’t blow the led Steve. Like, man if that were even possible I’d have 500 blown emitters.
At 5M, exactly, your meter reading is multiplied x25 (5 squared, or distance squared) for candela or of course K is thousands, hence the Kcd reading. Multiply the cd x4 then take the square root for a calculated throw in Meters.
So, from 5M, if your meter reads 100 and your meter is set on x10 (100x10=1000), then multiply 1000 x 25 for 25,000 or 25Kcd. Multiply 25000 x 4 = 100,000 and the square root of that is 316 M throw. There ya go, easy peasy. And I even know that from MEMORY!
Hmm… I’m running 3.88 Amperes on an XP-L HI V3 and the light barely gets warm, and i’m using (the remains of) the stock pill.
But, there is a good heat path from Led board to the big head, because everything is tightly screwed together.
I also tested it without reflector and bezel, the LED board didn’t get significantly warmer (to the touch) than the head.
My stock Convoy C8 (2,8 Amperes XP-L U6, no pill) gets warmer.
I still have nightmares from when I was building the C83 and how many leds l blew up before anyone knew what the problem was. :person_facepalming:
Thanks for the formula. :+1:
An XP-G3 can take direct drive from a single cell at up around 6.6A, as can the Nichia 219C (top cells might be too much though). The XHP-50/70 and MT-G2 can take direct drive from 2 cells with the XHP-70 and MT-G2 easily doing 12A on top 26650’s.
The XP-E of course has issues with an FET driver. The XP-G2 will limit itself through a high Vf to around 4-4.6A. A buck driver from Richard can do 5.5A to the XP-G2 through 2 cells.
Edit: To make it easier to stack chips on a Qlite style driver, remove the spring first. Then you’ve got a clearer shot at the legs. Put the spring back on when you’re done. I tend to do my stacking on the inside, starting with the one where the negative leads comes off and then going across to the other side as those two have the least room on that one leg near the MCU. Then do the two that are opposite the MCU and it’s fairly easy. Stacking another row on top of all those is fairly easy too. That’s what I typically do, go with 12 total chips on the inside, leaving the original 4 on the outside where the spring is. A 1.5 to 2mm bevel tip on the iron helps here….
Thanks Dale. I’ll give removing the spring ago. This light with unknown dedomed XML2 at 2.8 amps is only 13% down on my HD2010 which has an XPL HI running a 5.5 amp buck driver at around 7 meters. Admittedly the led in the HD2010 could be tuned a little better so the difference would be greater than what it is. I’d love to try a dedomed XPG2 but I wont have the time.
Hi Dale, do you have any nanjg driver photos with 12, 7135 stacked? regards!
Probably got a whole lot more...
I’d have that up on the wall as modern art.
I know even simpler one.
Formula is Distance x Distance x Lux. So on given example it is 5m x 5m x 1000 lux = 25000lux
Of course if you have meters on x10 settings multiply that with 100 before calculation.
And real life usable throw(where you clearly can identify target) would be around 100 meters
For those that have given me advice on how to solder chips on and I failed miserably, well I can now say thanks. I wont tell you how long it took but the driver works and outputs 3.4 amps. Yes I’m a happy camper.
I got a meter reading of 190. That is with three pushes of the button so I get a reading on the screen. I have the same meter as you have. Distance is 8.58m. I’ll let you work it out here so I can note it down. Thanks Dale.
That is very good job. :+1:
Edit:
“distance is 8.58m”
8,58x8,58x1900(if you measured on x10) = 139871lux or roughly 140kcd
Cant be simpler than that
If you can’t remember any of these , just try this tool :
Thanks guys.
What cd should I expect with Maxtoch 26mm + dedomed xpg2 + fet driver + centering ring tunning?
