hate to be a pain, but where is order list to confirm/count my count so I can check to order more ?
Good work on the light , guys…
A long time in coming but looking GOOD…
Trump’s latest…Ban shredded cheese…Make America grate again…
post #1
You are listed once (#265) which means one unit.
Thanks JasonWW, yeah indeed check list in post 1
Ah and the list also says to what post it is updated, after that will be done next time
I’m on the list (number 1320) for one unit but I would like to add two more for a total of three units. Thanks again!
I just confirmed the parasitic drain on the round #3 Q8:
It really was a sanity check to confirm it still is the same as the earlier round 2 prototypes, and it does match exactly.
In switch Lock-Out mode, the switch LED is off. There's also a quick trick method to turn off the switch LED when the light is OFF:
To put it in perspective:
Thanks for the update Tom.
I am on the list, #265…
Please add me for 2 more, total of 3…
thanx
Thanks Tom, good info. In the big scheme of things… I seriously doubt anyone will have a problem with this.
Great Tom
Gonna try that click hold till moon comes on, release and fast clicjyto turn off and see what the switch led does.
Really liking that green switch led but its good to be able to turn it off fast when one wants. Same procedure to turn it on again?
Will update list later.
No, just click the light on, click off - it's restored.
please add me to the list. thanks.
Oh Tom, it works very nice and nifty!
turn the Q8 off directly after turning on and the sideswitch goes off, and vice versa works as well.NAT!
The Banggood 30Q BTs arrived
a small cardboard box and a plastic baggie inside for each cell so well protected.
My Lii500 says:
24mR
22mR
23mR
25mR
prettywell mathed,
looking good
fast testing now, so tonight I can finally pump max non modded amps through the Q8! YAY!
Please could you add me to the list?
Yes
welcome to BLF!
Thank you…
Yes, amd welcome to BLF!
You are full of surprises Tom. Yes this works perfectly as Miller has mentioned. :+1:
