My new headlamp (driver challenge...)
Iā€™d like some explenation on the pcb also. How did you fix it, cause on the pic it looks like + and - are shorted with solder ? Iā€™m guessing the mid stroke of copper on pcb is - and the 2 outsides are +.
Cool mod tough. How do the COB LEDs compare to cree/nichia led in a mule setup?
The one with 6 of these LEDs on them was a XM-L board, the one with 8 (in the light) and the bare one were XP boards.
Some of them have that long centre pad (you say ā€œmid strokeā€), which is ideal for this purpose.
I just sanded off the masking paint.
:+1: Exactly.
They have practically no tint shift, so everything is the same tint, both in front of you and to the sides.
My other headlamp (which is starting to wear down a bit) has a single 219C and does have a little more yellow on the outer perimeter, even with diffusing optics.
Nice mod.
It looks like the plus and minus are shorted, but they must not be?
2000 ?! :smiley:
Thatā€™s 1 Kilowatt of LED powerā€¦. :disappointed:
I bought these some time ago:
http://www.ebay.com/itm/100-pcs-OSRAM-DURIS-E5-LED-4000K-CRI-95-HIGH-QUALITY-5630-5730-GW-JDSRS1-CC-0-5W-/282448446858
I really like them.
That shop has many more high CRI Osram LEDs by te way.
The centre pad is the minus. :wink:
Right, but it looks like you have solder going across all three pads.
Also, how is the UI? Edit: I saw you explained it some in the OP.
Yeah, it looks like it, but itā€™s not so.
Thereā€™s just very little space left when you put 8 of them on it.
In the picture with 6 on it you can see better.
So i soldered a jumper over the outer pads, where the red wire is soldered on to.
low, high, off. e-switch.
Long press for ramping. First long press increases, second long press decreases output, would be better if it decreased the first long press.
No ramping memory.
double click for strobe.
Not perfect, but no PWM. :+1:
(edit: Yeah i did explain in the OP :slight_smile: )
Well, i use a headlamp daily.
Together with my reading glasses it makes me see very well what iā€™m doing.
With external lighting thereā€™s always shadows cast on the things iā€™m working on / with.
Iā€™ve found a lens that fits (after some filing) too, to finish it off, but havenā€™t found a proper way to hold it in place yet.
Backlit?
My RJ02 glows red when charging and when in magic mode (wave on, wave off), and green when finished charging.
Maybe yours glows green after charging?
Very nice headlight build. I also love hi cri mule 18650 headlights. Iā€™ve always used nichias. Iā€™m not familiar with the emitters your using. They are cheap enough to experiment with some. Thanks for bringing these to my attention. What would you guesstimate the lumens on high is?
How good is the charger? Channel your inner HKJ and comment, does it stop charging when the cell is full, no ongoing trickle?
Iā€™m not sure, but the little LED goes green when itā€™s fully charged.
Good question though.
Iā€™ll have to (finally !) replace the fuse in my DMM and test this.
I really donā€™t know thatā€¦
Those LEDs are rated 0.5 Watts and 47 Lumen, but maybe itā€™s lower because these are high CRI.
But then again iā€™m using them on lower power than 0.5 Watts each, so they probably work a little more efficient, especially on the low mode (which seems to be without PWM).
No, just very greenā€¦ :slight_smile:
Just your average old school green GITD switch boot.
OP updated, not good newsā€¦
No current regulation, so the driver sucksā€¦
I did finish the thing by putting in a lens, maybe iā€™ll show you later.
Maybe i can replace the driver, didnā€™t get that part open yetā€¦
EDIT:
I got it open.
It seems the driver and charging circuit are not on the same PCB so thereā€™s hopeā€¦ :stuck_out_tongue:
(No pics yet, camera battery is charging)
bummer dude but still I learned a new rick with the pcb. Hope u can change out the driver (and if u can, well u know u will have a decent light)
Iā€™m not giving up (yetā€¦).
First the good news :person_facepalming: :
I found a useless double convex PMMA (i think) lens that i made to fit in the opening.
I sanded one side flat in one direction so that it spreads the light a little horizontally.
I thought iā€™d try that and it works rather well. :slight_smile:
Yeah, i painted the bare aluminum circumference black again too.
It got damaged when i took out the original LED board so i sanded it.
Looks neat huh?
And then the bad newsā€¦ :partying_face:
I enhanced some things in the picture.
On the right, the charging PCB.
Iā€™ll just leave that as is.
Maybe someone can tell what kind of circuit it is and if it shuts off when fully charged or if it ā€˜floatsā€™ on 4.2 Volts.
On the left, the driver board, the e-switch and some peripheral parts (2 Rs and 1 C) are on the other side.
So basically the unmarked IC does the UI and regulates the 2 tiny ā€œ00A8Cā€ FETs.
Their output goes to 3 x R680 in parallel (0.23 Ohm) to the LEDs.
So thereā€™s no current regulationā€¦.
ā€¦.so i took the FETs and the resistors off.
I want to replace those parts with those 3 chips there, those are CN5611 current regulators, like variable 7135s.
Bought a bunch some time ago, and i think i can drive them with the IC output (connect to pin 4 ā€œISETā€ via a yet to be determined resistor), instead of the FETs.
They can do 30 to 800 mA each, but thereā€™s a considerable voltage drop above 400 mA, so i plan to use 3 of them in parallel, and 1200 mA total would be quite enough.
The CN5611 has a Voltage drop of around 0.2 Volts at 400mA.
The challenge is getting them on the board with some sort of thermal path and working within the desired range.
It would be 90 to 1200 mA when all works out well.
1200mA is not much, but itā€™s enough for its purposes and otherwise it will get hot and itā€™s around the maximum rated power of the Osram LEDs.
I love the new look you came up with.
The charge circuit is a AP5056 and has the capabilities to indicate " charge" and "termination charge " states Find below a data sheet link :
www.led-ics.com - AP5056_datasheet.pdf
You don't stop amazing me with your imagination !... So many gifted people , forced to do something else to make a living...
Hey, thanks Adrian.
So at least the charging board is okayā€¦ :smiley:
