Word of advice? Make sure there’s a fixed-resistor as the minimum possible resistor you’d want. Otherwise, if it just happens to be near-0 when you first power it up… pouf!. Goodbye LEDs.
So if you want the range to be roughly 20k through 50k, you can get a 22k fixed resistor and use a 22k or 25k pot.
You will need a driver that fits. You’ll also need to enlarge the hole in the reflector as well as have a way to adjust it’s height. Otherwise you may have a donut hole shaped beam with the SMO reflector.
A sliced dome xhp50.2 will probably give you a nicer, smaller hotspot compared to the xhp70. It’s not as bright, though.
Is your current L2 not bright enough for you or is the hotspot too small in your opinion?
You can get the most out of that xpl with a FET driver.
If you just want a bigger hotspot, then the xhp50 or 70 will do that.
I noticed that with the light rested, cells fresh but rested, my lighted side switch acts up still. Playing with it for a few minutes it quits, so it’s like the cells are too hot at first and after some use then it works ok. The “hot” wire to the switch LED’s is coming from the actual point of intake for the positive power, the lead is soldered straight onto the 18ga lead going from driver pad to XHP-70. So the only common place is the ground wire, which is coming off the MCU. If I run a separate ground wire would that solve this? Or should I go with yet a bit more resistance? I want it to be reliable, of course, even considering the problem I’m seeing is only on the top end of the cells life, I’d like to know it’s going to do what I ask of it when I ask it.
Wondering if a capacitor at the ground wire might help… ???
I went with the XHP50 in one of my L2’s and Love it! No hacking up that beautiful reflector, the emitter fits perfectly. I frosted the dome, it’s pert near emitter artifact free,pert near, but it has 2 very slight faint rings, so if your into perfect WW beam shot gasms, don’t bother, it’s outside in the real world this XHP50 J4-1B at 8.5amps rocks in my L2! Want a little more downrange illumination shave it want even more range de-dome it
Try de-doming a 50.2! :person_facepalming:
Here’s a link to an observation/opinion about the 50.2 from one of our own BLF members, I also agree with his opinion, I tried the 50.2 emitter in several different lights, didn’t like it at all, it’s in the junk box.
I still have no idea what your driver looks like. Is it piggy backed on a 30mm board or maybe you added some width to the 17mm driver?
Could you take some pictures of it?
I think it was Tom E that said the shared ground wires should have zero effect on the LED’s circuit so I don’t know why your having a problem.
Yes Jason, it’s a MTN FET driver piggybagged onto the original driver after stripping the components off of it. (Actually it’s a different driver that I stripped, the board fits though so it’s the contact board) The contact board is bored in the center for a 16 Ga wire which is connected at the top of the spring. The other end of the wire is on the MTN FET driver spring pad, so the FET driver is actually floating on top of a 16Ga lead. Ground for the switch is off the ground ring of the FET driver, positive for the switch is on pin 2 of the MCU.
I’m not good at visualizing. I need pics to really understand.
How is the fet driver grounded to the flashlight body?
So the switch LEDs are getting positive from the main wire going to the big LED. That should always be battery voltage as long as the rear switch is on, right?
I’m assuming your mcu pin 2 is always hot and it’s waiting for that side switch to close and provide the ground path it needs.
So you have positive power flowing through the switch LED’s to ground. I don’t see how it would effect pin 2, unless…
It may be possible that one of your switch leds is touching the switch body. They get very close and you may have a solder bridge between them. That would cause pin 2 to see a very faint ground signal. Not enough to effect the switch, but maybe enough to screw with the mcu function or led brightness.
I had one of my switch leds get crooked and maybe touch the switch body so I had to remove it and start again to make sure it had a gap. A tiiiiiny little gap.
Man I hate smd soldering. I tend to use a flashlight and my smart phone camera at 5x magnification like a video microscope to easily see how I did after a solder.
Reduce output, not much, or to worry about, only your meter will know bro! Visually nope.
I use a fine emery cloth or finish sandpaper around 800-1200-1500grt. Very wet, soaked even, like in a bucket of water, you don’t want the grit to become lodged into the silicone dome, or you will have a smoker! Then scrub/clean the dome very well with alcohol and a towel. Sometimes I even polish the dome, I have used tooth paste the white highly abrasive paste, cleanser like the Roman Cleanser/AJAX and water to make a paste, if I don;t have a fine enough paper. Still make sure it absolutely cleaned/scrubbed with alcohol. Blow it off with canned air.
Best to test the emitter after outside the light after cleaning, just to make sure you don’t smoke up your reflector.
That is why I like to build it up outside the light first, take my readings and when i assemble, I know what i should be getting right!
Any of my X6’s with the lighted tail cap I’ve gone with that combination, really like it.
I’ve put a new momentary switch on the pcb in my L6 and it still acts up. I removed the positive lead to the LED’s, still messed up. So I am going to build a new driver and swap it out, see if I can get this L6 working properly…
I did this combo because you mentioned it before. :+1:
Man, I’m not sure why your having so much trouble. So with no power to the switch led’s, it’s still acting funny? I guess the driver has an issue.
Earlier I was thinking whatever mcu your driver is using might just be sensitive to the light circuit, like power was back feeding to pin 2, but I don’t know if its possible since the little leds are still diodes, so they are one way only.
I’ve used the lighted side switch on the FX30 and Tx Avenger drivers and had no issues at all. Maybe their mcu’s are not so sensitive?
