I did this combo because you mentioned it before. :+1:
Man, I’m not sure why your having so much trouble. So with no power to the switch led’s, it’s still acting funny? I guess the driver has an issue.
Earlier I was thinking whatever mcu your driver is using might just be sensitive to the light circuit, like power was back feeding to pin 2, but I don’t know if its possible since the little leds are still diodes, so they are one way only.
I’ve used the lighted side switch on the FX30 and Tx Avenger drivers and had no issues at all. Maybe their mcu’s are not so sensitive?
I have had this driver working fine in this light for months, making 7200 lumens when I first built it. Didn’t start having issues till I tried the lighted switch.
At any rate, I built a 20mm MTN FET driver and swapped it out. I’m gonna have to quit doing this on pain meds. Put the Zener on backwards and played he figuring out why I had nothing! lol Got it flipped around and the light seems to be working fine, lighted switch and all. It was making 5600 lumens on the cells at 84% charged, recharging cells now…
I’ve got a 91K resistor on the switch LED’s. I’ve got 18ga leads from the driver to the LED, 16ga from the contact board to the driver. So, why am I now only getting 5740.8 lumens where I got 7200 before? The only thing really different is I’m using an SIR404DP mosfet instead of the SIR800DP. Might have to pull it apart yet one more time and swap MOSFET’s… ugh.
Just remembered something… I pulled the UCLp lens to use in my scratch built triple 50.2, I think I have a S70 lens in it now. Could be that the combination of changes is doing it. Some lenses can block a lot of light and the UCLp is the best out there, so I’d expect to see losses for the lens change, maybe not so much, but still…
In the morning I’ll test it without a lens, see what that shows…
Some time back I bought a MaxToch SN6X-2X in a group buy. I put an UCLp lens in it and it made a 27Kcd difference in throw. Seriously. Biggest single gain I’ve seen for one item change. This is a variable of course, depending on the quality of lens already present. I’m using an S70 lens because the AR coating on the L6 lens got accidentally damaged. I DO have what appears to be a very nice white glass lens with good AR coating from Klarus that is fitted to the L6, can try that in the morning as well, see if a swap will help there.
flashlightlens.com has the best lenses in the business. Comparable to eyeglass or photography lens coatings and clarity with up to 98% transmission as I recall. (just checked, 97% in the UCLp … 68mm is $8.25… and 98-99% transmission in the smaller UCL glass lens)
With an Thorfire S70 lens it makes 5740.8 lumens
With an Klarus G35 lens it makes 6168.60 lumens
With no lens at all it makes 6523.95 lumens
So there ya have it. The S70 lens is costing it 783.15 lumens while the Klarus G35 lens is only losing 355.35 lumens. This is all on the same LiitoKala 5000mAh cells without recharging them, I took the S70 reading last night on fresh cells, the no lens reading first this morning, then the Klarus reading last.
I also talked to somebody that has used the SIR404DP MOSFET quite a bit lately and found them to be finicky, easily damaged by heat in the re-flow sequence. So I’ll be pulling the 404 and putting an 800 back on.
People ask why I pay $8 for an UCLp lens, with a lot of effort going into making a 6500-7200 lumen light it sucks to lose 780 lumens to the lens! Cutting that loss as much as possible is worth the price, considering the FET itself can be as much as $4, why not let the light out with the right lens?
I’ve shown a light to my Dad before after putting the UCLp lens in it (without saying anything about the lens swap), no kidding he tried to put his finger in the reflector declaring I’d forgotten to put the lens in! Then the astonished look on his face when his finger hit the lens, like that last step you thought was there and about fall down when it’s the floor instead of another step. I myself have completed a build and thought the same thing, you see the emitter so clearly down in the reflector that you have to tilt the light around and try to catch a reflection off the overhead light or a window, it’s really just amazing how clear it is.
With the 91K resistor on the switch LED’s and the new 20mm driver now having an SIR800DP FET on it, I’m still only getting 5754.6 lumens with the Klarus lens on and 6272.1 with no lens at all. So I’m nearly 1000 down from when I first built this light. In this instance, the lens itself is robbing me 517.5 lumens. Guess I’ll be getting an UCLp and see how that works out…
On the plus side, it’s working fine with the lighted switch.
