what would be a good choice of 18350 cell for this, xtar 18350 850mah unprotected, BASEN 18350 800mAh 12A. Trustfire TF 18350 Li-Ion 1200mAh Button Top 3.7v Unprotected, EFEST 18350 Batteries 3.7V Li-ion 800mAh IMR, my guess unprotected would be best.
Note they are somewhat ‘old’ - four/five years. There has not been much evolution in the 18350 format but more recent cells may have a bit more capacity (those test at 700 mAh). Make sure you buy new ones because LiIon cells do age even without use - or so is my understanding.
with the 18650 tube on the S41S my button top Samsung 30Q’s are a press fit and even stripped a bit of the shrink-wrap off of one.
worked OK just too wide for the extension tube. Same with protected 18650’s
they work fine in the S41 extended tube
Got my order of 18350s yesterday, and they’re labelled Efest. Need to check the capacity, but as they’re labelled 800mAh, I assume that they’re the Efest IMR18350 800mAh (Red) tested by HJK.
Index of Efest batteries (This is the index, as it keeps truncating the direct link to the battery review)
