Actually it is not the best method to use rice. The problem is not the water. the problem is the salt and minerals in the water. and if u let it dry (using rice or a fan . . . ) the salt and minerals can still short things out. and it will still corrode further. (Should you put your phone in rice? Only if you want to buy a new phone - YouTube) a good inside look what happend if u use any simple dry method (jump to 36:40 to see a rice dryed pcb). Or check Louis comment and pics (How to use rice to repair water damage on iPhones and Macbooks - YouTube).
If your device gets wet first thing to do is get the battery out if possible. and then get the device to someone that can dissasemble it to get it cleaned. I did some of this repairs myself. using destilled water and isopropanol to clean the parts. some are still working.
Does rain water have a heavy enough mineral presence to leave a robust evaporate film that short electronics? Honestly? How do grapes grow to make wine in France with so much salt present in the rain?
Hahaha water coming through the roof is not clean anymore.
There is not a hole in the roof, there is/are opening(s) where water enters, then finds its way down the several layers the roof is made of
Indeed was rain just directly fallen on it I would just dry and only open if not working.
Being the miller is living “down there” i would assume his roof are made of slate shingles, and since some have been pulverized there must be some minerals in the rainwater.
The first winter in my house we had snow blow into the sealing :person_facepalming: so the following summer i had to go up on the roof and fix the very top of it as that’s where the problem was.
And i can assure you sitting up there with one leg on either side of the roof, pretty fast that become only enjoyable to masochists.
So i had to dismount the roof pretty fast and go get something thick and soft to sit on while i scooted backwards on the roof top as i fixed the problem.
<—- grew up in Dad’s lumber yard, built quite a few houses after he sold the yard (they [Dad and his brother] had up to 7 carpenter crews, sawmill, lumber yard, 35 years) So I definitely know the feeling Sparky.
Sad to hear that TF will not give us the 3 bladed tailcap but it is nice to see that the Driver PCB is now secured properly!
The delaminating traces are not so nice! Hope that it will be possible to reflow new LED´s on the MCPCB at least one or two times before the delaminating gets to bad!
I hope that the delamination was caused by my impossibly hot 80W solder iron, and that normal reflow temperature does not cause it, and that it can handle multiple reflows without problems.
Just to note, I'm concerned about what djozz experienced, but I have worked with the ThorFire predecessor to this MCPCB in the round 1 and round 2 prototypes and didn't have the problem, or at least noticed it. I de-soldered/soldered wires and removed LED's, reflowed others on.
I used to see SinkPAD and Noctigons exhibit this separation if I went to hot on the hot plate, now I use a hot air station at 370º C and have zero issues.
If temps above 300°C is not a problem reflowing LED´s should be no problem. But maybee someone can test the last batch of MCPCB´s. After all this MCPCB is not cheap or easy to get if damaged.
I've been bad as of late - I've been reflowing LED's with a small torch, heating the underside of the MCPCB. Gotta keep it under control of course, very careful with the heat, but seems to work ok for me. Only problems I've had with MCPCB's has been with the KD ones - not full delamination but on edges of traces, they were pulling up.
True - we should do more testing on these. Not only are they not cheap, but may not be possible to replace directly. Dunno if ThorFire will offer these for sale or replacement. Other MCPCB's could be used of course, but with some modding work I'm sure.
With two holes - slightly misaligned, as shown in the picture above — notice the oval opening
a smaller diameter screw (as described above) will, yes, fit all the way down through to (barely) engage the threads in the lower hole
and it can be tightened because it’s wedged in, but it is going to be in contact less than halfway around each of the holes and barely engage the threads
It’s just the kind of thing to notice on a handmade sample that shouldn’t happen on a production line where they’d use a jig to align the pieces before drilling and tapping.
I was wondering ( cuz i see little things like that )
If the emitters was turned 45 degrees in their location so a corner faced towards the center hole, would that have a impact on beam profile, or would it just be me overthinking stuff again.
