The problem here is that we don’t know how those people built their lights (maybe the focus was off?). We don’t know how they de-domed their LEDs (maybe they didn’t remove enough silicone or maybe they damaged the phosphor). We also don’t know how consistent the luminance is after de-doming (probably not a problem though).
Maybe sma made a mistake in his measurement.
So in the end we don’t really have enough real evidence either way. I can say that sma has a lot of experience with luminance measurements and that in the past his measured values pretty much always correlated with measured throw of different lights.
I think the problem is that a few people tried this LED and then wrote negative things and everyone else gave up.
Also a lot of people have started building unregulated lights with FET drivers. This poses the risk of damaging an LED when turning on a light because the startup current can be extremely high when using these new low-Vf emitters.
Controlled tests must in my eyes be done with constant current.
The_Driver, those are plausible explanations. I would love for the XPG3 to meet or beat the XPG2, but I’m doubtful. There are several examples of experienced modders getting similar underwhelming performance results with the XPG3.
I did extensive testing on the XP-G3 when it first came out, with MEM assisting. I found it to not meet the capabilities of the XP-G2 in a reflectored light although MEM found promise with aspheric builds.
I do not like the beam profile from the G3, domed or sliced or de-domed, so I don’t use it.
See what I mean though? The blueish purple aura and odd spill color? I don’t like that, so I don’t use it. Not fond of the XHP-50.2 either, for similar reasons. Will eventually pull the three from my scratch built light and go with something else.
Back about 3 years ago, when the HD2010 was giving me these problems, I did this to solve clearance issues. Made it easy to dial up the focus without worrying about touching electrical contacts…
Yes, I agree with that.
Above I was just talking about center beam lux/candela, not all the other problems.
There might be a solution for this though. Somebody here on BLF did it with an XP-L2. After de-doming it he cut away all the excess phosphor. This way he got rid of the yellow-green corona.
The blue spot can probably be fixed by starting with a lower color temperature LED before de-doming.
It’s not so bad, the first “trick” is to get the rectangular shape of the thermal pad cut into a copper box, then match it width and height with some sheet for the electrical contacts. I cut slightly shorter strips from a coke can as aluminum doesn’t solder. Placed like 3 strips between the sheet and pillar, held them with a small clamping tweezer (might have been a hemostat) and placed the assembly on the Noctigon with solder paste present, solder paste on top of the copper as well. Then I put the emitter on top, re-flowed all of it simultaneously.
I did it to the XP-G3 in a Courui D01 when they first came out, it helped, but it did not improve throw not one bit. This had .005’ silicone left over from shaving. I made up ground washers with different thickness’s .005’’ increments, to shave as close as I could.
This is what happened when I went to the next .005” smaller washer! There was still a bit of soft mushy phosphorus left, kind of thin though! :person_facepalming:
So close and yet so far! What was amazing back then, when they first came out, was these G3’s were pulling 8+ amps, it got very exciting, but yet I was only able to achieve 270-280kcd IIRC in the Courui.
I’ve bought two lights from Amazon and I build both lights with BLF Fet driver. One light is with domed xp-g2 s3 1a and the second one is with dedomed xp-g2 s2 1d. The dedomed led is reflowed on Maxtoch 26mm with custom build centering ring and throws as well like my modded jax x1 with same Setup. For this small money, I think you can’t get better light.
How precise is your test setup? How does the lens look? Does it have the colored reflection at high angles? Are you accounting for all the variables (full batteries, exact same measurement distance, room temperature etc.)?
The comparison was made in less than 5 minutes, first with stock lens X lux at 8meters, then put the AR glass and do the same test with the same numbers showing in the lux meter
I also claim that there is no significant difference; well at least with some cheaper AR lenses I tried on Jacob A60. They are more beautiful I can’t argue that…
So question is: Can pure air or no lenses at all on top of reflector be better than lets say the best AR coated lenses?
I am asking that cause with my reflector mods I can easily measure lux without any lenses in front of reflector. So theoretically… Do I have 100% of light transmittance without any lenses in front of reflector?
If this is correct I will say that only negligible difference is visible on lux meter(about 1% more lux for pure air without any lenses on the top of the reflector vs classic non ar coated lenses).
I’ve been testing some that way as well, remove the lens completely and see what the baseline is then test different lenses to see what comes close to no lens at all. Ironically, the Klarus G35 AR coated glass lens is really good, very comparable to an UCLp. To be fair, the UCLp in acrylic isn’t as good as the glass UCL, so there is that small room for improvement. With the glass UCL with a claimed 99%+ transmittance, you’re just not going to get a better lens. Problem is, of course, the size limitations of that lens.
If you take the lens out and see green glass on the sides, there’s room for improvement. Whether it’s AR coated or not. If the glass is water white, you have in your hands a nice lens and it’s probably not worth spending money looking for improvement.
