Not sure on this, for me the colour LEDs are a waste as donāt want or need them. Would prefer xhp35HIās, be them In a reflector or optics (narrow focus). As for battery packs, presuming itās an 8x18650 light, sometimes carriers are not user friendly . When I use the tk75 with added run time kit(4+4 ), itās a pita swapping out in day lightā¦.never mind in the field. Carriers do have advantages at times, plug in and charge wins for me in this caseā¦.subjective I know.
Donāt worry, pure flood with weak throw will underwhelm quickly, unless you dont have any other monster light, those larger XHP50 dies barely got anything to collect them.
And then thereās also the universal law: lumens sell
Vinhās lights sell, so obviously there is a market for lights with stupid high lumen values. I think Acebeam is doing something interesting by offering lights of this category as a main stream company.
I am sure this flashlight will have itās driver removed and fit in the 17mm direct drive from RMM/MTN wrapped in kapton tape to make it higher-end, because Vinh light baby.
I meant to say lights with under 25Kcd (guessing 20Kcd?) are underwhelming lights when they produce 25Klm, it is that much more floodier/spreadier/underwhelming for the amount of lumens.
Hey how are you doing man, nice to see you back. :partying_face:
Yeah I know what you mean. You need to have the right environment to benefit such output. Dense forest with super tall trees in a ~10 to 20 meter range will make the light shine. In an open environment you will be blinded by the spill in front of you while a large part of the lumens will be tossed in air making it useless.
Quote: āā¦In an open environment you will be blinded by the spill in front of you while a large part of the lumens will be tossed in air making it useless.ā
Yes, true, correct, succinct and well said. I agree that most of the light is tossed away from where it can be of use, and the close in glare makes viewing anything impossible. I have several legacy lesser flooders that do this not quite on such a grand scale. I do not need the current offering that does this in the biggest way.
I want the current offering that does this in the biggest way.
