MUSTOOL MT833 2000 Counts Auto Ranging Digital Multimeters DC Current Frequency Capacitance Resistance Diodes Transistor Audible Continuity Tester is for $11.11 for all accounts now.
Update: Deal expired.
Astrolux TB-01 Bullet Copper/Stainless Steel 45LM Mini LED Keychain Flashlight is for $3.29
Astrolux TB-01 Bullet Aluminium Alloy 45LM Mini LED Keychain Flashlight is for $2.26
Two sets of batteries are included with either version.
Those lights are good as zipper pulls because of their size.
Astrolux K01 CU XP-L 7/4modes 1400LM Tactical EDC LED Flashlight 14500 for VIP2 and above accounts the price is $29.95 and using BG points it’s possible to lower the price even more:
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$25.16 |
$24.86 |
$24.56 |
$23.96 |
Lumintop Ant Stainless Steel/Brass XP-G2 R5 120LM EDC Mini LED Flashlight is now in preorder for $25.90 (brass version) and $26.90 (stainless version). BG points are working so it’s possible to lower the price even further to:
Brass version:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$22.02 |
$21.76 |
$21.50 |
$21.24 |
$20.72 |
Stainless version:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$22.87 |
$21.60 |
$22.33 |
$22.06 |
$21.52 |
Lenovo ZUK Z2 5.0 inch 4GB RAM 64GB ROM Snapdragon 820 2.15GHz Quad-core 4G Smartphone is in promotion for $175.99 and BG points still work, so having enough points it’s possible to lower the price to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$149.59 |
$147.83 |
$146.07 |
$144.31 |
$140.79 |
KEWEISI 3V-9V 0-3A USB Charger Power Battery Capacity Tester Voltage Current Meter is now for $3.27 and using BG points price can be lowered to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$2.78 |
$2.75 |
$2.71 |
$2.68 |
$2.62 |
Astrolux S41 4x Nichia 219B/XP-G2/XP-G3 A6 1600Lumens Mini LED Flashlight is right now for only $23.95. All three LED options available.
Coupon code is now available: use code 8a955d to lower the price to $25.50
18650 extension tube available here:
Astrolux S41/S42/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $2.49 (BG points can be used to lower price further).
BlitzWolf® Graphene Earphone BW-ES1 In-ear Wired Control Earphone With Microphone
Good value earphones with graphene diaphragm converters now for $11.99
ARILUX® AL-SL06 Solar Powered 62 LED PIR Motion Sensor Light Outdoor Waterproof IP65 Wall Lamp
for VIP2 and above at only $19.99 and using BG points it’s possible to lower the price to:
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$16.79 |
$16.59 |
$16.39 |
$15.99 |
$1.28 for Outdoor Portable Silicon LED Light Night Running Mini Safety Hanging Lamp Warning Light and using BG points it’s possible to lower price to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$1.09 |
$1.08 |
$1.06 |
$1.05 |
$1.02 |
$19.95 4PCS NCR18650B 3.7V 3400mAh Protected Rechargeable Lithium Battery using BG points it’s possible to lower price to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$16.96 |
$16.76 |
$16.56 |
$16.36 |
$15.96 |
Nitecore MT06MD Nichia 219B 180LM LED Pocket Medical Penlight Flashlight
Using coupon code price drops considerably. »Request deal info via PM here«
The flashlight uses 2xAAA cells and Nichia 219B LED with CRI over 90 at CCT=5000K. It has 3 modes and always starts in low (4lm), medium is at 45lm and high at 180lm.
$39.99 EKEN H9 WiFi Sport Action Camera DV Car DVR SPCA6350 4K 25fps 1080p 60fps 720P 120fps New Version
This is the new version with round lens housing.
$44.99 EKEN H9R Sports Action Camera 4K Ultra HD 2.4G Remote WiFi 170 Degree Wide Angle
This version is equipped with mini remote control.
Other Eken cameras
For the ones without dedicated promotion use EKEN20%1 and/or EKEN20%2 coupon codes to lower price by 20%.
Following deal has expired. Send me a PM for a valid coupon code.
Astrolux S42S Stainless Steel 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight is now in preorder for $42.95 but using BG points it’s possible to lower price to:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$36.51 |
$36.08 |
$35.65 |
$35.22 |
$34.36 |
XP-G3 and Nichia 219C hight CRI available. Registered shipping included. Colored version is also available in the same price - links below:
Astrolux S42S Colored 4xNichia 219C/XP-G3 2023LM Rechargeable Mini LED Flashlight
To utilize LEDs to max extent and be able to get the most light it’s best to use 18650 high current drain cell.
Matching extension tubes are available:
Astrolux S41S/S42S Colored LED Flashlight 18650 Extension Tube Body Tube for $9(silver) / $11(heat colored) and using BG points it’s possible to lower price as well:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$7.65/$9.35 |
$7.56/$9.24 |
$7.47/$9.13 |
$7.38/$9.02 |
$7.20/$8.80 |
note the opposite orientation of the tube on the 18350 tube
that is the wrong way to use it as the threads are not long enough on that end to have the body reach the contact ring
it works on the stainless because the threads are not anodized so current goes though them to the copper head
it won’t work on the black tubes
even though I think it looks more balanced the way it is
with the stainless model you can have a reversible clip position by reversing the tube :+1:
That’s true - black aluminium tubes work only in one position - cannot be reversed. Same goes to Astrolux S41.
Deal expired - now coupon available: details here
All colors Nitecore T Series Tube 45LM USB Rechargeable LED Light Keychain using this link lowers the price to $6.28 and you can still use BG points to lower the price even more:
VIP0/1 |
VIP2 |
VIP3 |
VIP4 |
VIP5 |
$5.34 |
$5.28 |
$5.21 |
$5.15 |
$5.02 |
Note: if the link did not lower the price and reloading the page doesn’t help, clear cache/cookies and use the link again.
Astrolux Flashlight Protected Bag Holster For Astrolux S41/S41S/S42/S42S 12.8x3.2cm
Very good single 18650 flashlight holster now for only $0,99! Fits all Convoy S2/S2+/BLF A6 sized lights perfectly.
Lumintop ED25 XM-L2 620LM AA 6-mode Tactical Outdoor LED Flashlight use code LMTED25 to lower the price to $17.95 (-$7.05).
Holster is included, registered shipping as well.
This is one of the brightest 2xAA lights, has 3 normal and 3 blinky modes (those are hidden: need to loosen the head 1/4 turn to access -> no way to accidentally activate and provides fast access at the same time :+1: ).
Machining and overall quality is truly incredible for this price range. Hard to beat value for money.
Lumintop IYP365 XP-G2/Nichia AAA EDC LED Portable Pen Flashlight is for $12.00 using code LMTIYP365 (-US$13.00).
Cree XP-G2 R5 or Nichia 219BT high CRI options available.
Mode order is medium≫low≫high, no mode memory. If you want similar pen light with low≫medium≫high mode order with Nichia LED see Nitecore MT06MD
