I prefer the charging port to be accessible from the outside of the light. I know, less water resistance. But I rather not have to unscrew the light every time I need to charge it.
The Astrolux version has the charging port accessible without unscrewing the head. Rumor has it a version with an aluminum body and copper heatsink like the S41 and this Manker is coming soon.
Thanks for review!!
For me this type of charging port have the advantage of better water proof than the external ports covered by perhaps not reliable rubber pieces.
( I am using my unit with 18350 IMR Aw and IMR Nitecore 18350 most of the time)
Do you see signs of the clear coat in any way, on the copper head?
This is most certainly on my ‘soon to-get’ list. I LOVE that it has two pocket clip grooves also.
I am thinking about tearing mine apart, and removing the (reported) clear coat. So I can get a tad better cooling, but more importantly. That all so wonderful patina, later on down the road. :sunglasses:
I was excited with the driver , now that it is a fet+1 and charging is in a different circuit someone can have a ramping firmware without a stepdown for the cost of 1-2 resistors (for the lvp)
Yes it has a very thin layer of clear coat or something similar .
I polished my S41 and created a patina , the one in one of the pics , it has a cool uneven patina … (i will try to get a better pic )
Thanks for the review (in progress). I see the great performance of this light but can not get over the looks, it is plain ugly to me :innocent: .
I see that the head does not have the rim that the opic can sit on (the fix that Astrolux had for the S41S) and that prevents twisting the optic when closing the bezel. So a modder’s question: are the dimensions in this light such that the optic is the correct height above the leds without damaging the domes, and that the bezel can be closed without chance of shearing off the led domes?
That stepdown is ridiculous. It’s reasonable enough for a FET quad to have a significant stepdown, but to less than 10%? Good thing it isn’t too hard to get to the MCU and flash a different firmware.
I think you should have a look again. In the description is says goes to high mode after 40 secs of turbo. They even replied saying in the final version that’s how it’s gonna be.
