This is a first check if enough people are interested in a Q8 Dual footprint, quad LED copper DTP LEDboard. The Board would be produced by Kerui Electronics for about 8 euro per board (50 pcs minimum order). It is only a interest list to check if we could get filled the minimum order. No commitments for now.
Board with 4 Luxeon V 400K 70CRI = 19,97€ (led4power)
Board with 4 Luxeon MZ 5700K 90+CRI = 32,97€ (led4power)
The Luxeon MZ are Flux bin : R (840 – 900lm)@2800mA (most MZ LED´s you can find at Mouser, Digikey. . . have a lower Flux bin )
I refer to djozz contact. If the Q8 boards are the same quality like djozz N119er boards are, i could not think of any problems.
There is a lot to figure out to make it happen but i def would like to get one board. The options with the new leds are to tempting!!!
(Can not wait to see the sst-40 overdrive test and for shure the dedome test!)
I think we would need the exact ledboard layout (for perfect reflector allignetment) and the exact position of the holes . . . to ask for a price.
It would be a big step in the right direction if one of the PCB layout experts could jump in.
The original quote from Kerui for a quad SRK board was based on a pretty vague pencil drawing, so an exact design is not needed for that (you could use TA’s dedign for the quote and hand in the exact design later) . It helps the interest check if you have the real price.
I think the logic of making it XM and XHP70 can’t be beat. There’s no reason to use XP, since the original board is already that. That board that Texas_Ace made (that The Miller posted above) would work quite well, if changed to XM and XHP70. It’s already set-up for the flexibility to use any combination of series and/or parallel connections. It already has a place for the thermistor. It’s well designed to fit most SRK lights. Since we have access to the exact dimensions of the Q8 board, maybe it could be tweaked to be a better fit there. It needs to be modded a little to accommodate the two hold-down screws.
One major thing though, the wires must be soldered to the MCPCB in the center for the reflector has the milled out area there, so what TOD said, somebody needs to make a design.
The four holes are for the wires
Center hole for screw so sizes probably need a little tweaking too
I have contacted Sundy and asked for a ~ price and min order quantity for a DTP, 2mm copper, 38mm diameter board with a similar layout to the TA board. Now we will have to wait and discuss which design is the most prefered.
I would order one of these if they were made. I think an XHP50.2 Q8 would be great. It would make the stock 6000 lumens much easier and with much less heat. It should also peak over 15k lumens.
In fact some quick math says that the xhp50.2 could produce ~10k lumens for the same amount of heat as the stock XP-L’s produce 6k lumens due to the higher efficiency (~130lm/W vs ~80lm/w).
XHP70 would be more work since you would have to drill out the reflectors but they should be able to do ~20k lumens, for a few seconds.
Personally I think I would get some 90+ CRI xhp50.2’s and call it a day. 10k+ lumens of nice, high CRI light.
