I have a close up picture in the OP. I could make it bigger and ad one straight on.
Cool,we can ALL have names for our Opus’s! :+1:
This is the best possible picture in my opinion.I enlarged as much as I could[100].The OP version was 85 iirc.
It is clear and you get to see how much it protrudes. Not really that much in real life.
Picture from front.
Notice the label is side ways? I did that on purpose because the wires lay better and are on the center of the board[not getting pinched] at 7 O’clock VS at 4:30!
The cover was pinching the wires a bit when installed at 4:30.
Right, I’ve seen that one. I was just hoping for a different angle close up. It looks real good from what I can see too. The slight gap in the case probably helps in air flow to wouldn’t you think?
Interesting stuff :+1:
OK, thank you. I see you posted pics while I was typing.
yaaa, the little gap can not hurt,a little extra ventilation is good
The reason there is a gap is because I did not want to strip the screws like I did w/ King Opus! Also,It is not a perfect fit so once it starting getting tight enough I stopped tightening.
EDIT: The screws were not stripped. The fiberglass board[holes] got stripped.
Thanks,It is exciting to be a Flashaholic when through a learning process and help from others, we get to see results derived from manufacturers imperfections. :sunglasses:
Henry Xu is very accommodating and pretty efficient and reliable.
to me
Hi, Robert
With our new design, we have not fixed the fan size yet. If we can use two bearing type fan, I think the problem of fan reliability issue will be fixed, no matter ADDA fan or some other fan to be used.
We are still reviewing the fan internally.
regards
henry
_
This is in regards to the “NEWLY PLANNED GENERATION” OPUS which is due out in several months. This will be his present to me!
sales@opus-instrument.com
Jun 6 (1 day ago)
to me
Hi, Robert.
For discharge terminate, we will terminate at 2.7v with load of 1000mA. With this conidtion, it will be safe for batteries with protection.
regards
henry
_
I have asked him everything that I have needed to ask him. Now I wait to hear from him in several months when the charger comes out.
Sounds like a good plan to stop before stripping… it looks good.
Henry Xu needs to make readily available replacement parts (Fans) that work in his products—That would be a good start for us past customers
OH… I just saw the info from Mr. Xu you posted. Thanks for posting it… :+1:
Interesting & sounds good…. like they are trying to get it right on the first try.
Dropping termination to 2.7 V also…… works for me.
Thanks again for posting this info Robert. :+1:
yaa,he needs to upgrade the fan which he appears to be doing and also provide easily accessible replacements.
For me, I would not use his stock fans in mine anymore unless the newly designed one coming out has ZERO STOPPAGES during discharge. Even then I would probably put the Delta in. I love the results and actually listening to its impressive CFM!
I have 2 X Delta fans and I have a source[speaker_joe] to get more.
Opus would never put that high quality of a fan in because of costs.
For people curious like myself.
The reason the TOP of the fan protrudes more than the bottom[which is actually flush] is because when tightening the cover plate it pushes on the bottom of the fan and with no grooves to keep it in place, the top pushes out and protrudes.If the fan had grooves it would still stick out with the additional 1.5mm in depth. It would just be an even protrusion! lol!
Nice.
5V DC??
Have you checked what voltage is applied to the fan?
The fan has a resistor to cover the other 7V.
I do not recall how “rdana” and HKJ explained it,but it works.
EDIT: Here is “rdana’s” answer. He is the ONLY one who sells the BT-C3400 V3.1
The original fan has an inline resistor added to it, this is why the fan is 5v, the terminal on the pcb is probably providing unregulated 12v (obviously the external PSU is regulated). The 5v fans is a probably the cheapest they could find and they just added a resistor to divide the voltage, I would think the gearbest fan is better at least in that regard. Do not use a 5V fan directly on that board, it will almost certainly blow out or die within days.
_
The ADDA fan w/ resistor is on the left.
Btw, for those who may not know what ADDA means by “HYPRO bearing”, you can find a short introduction here, which mentions various modfied sleeve bearing technologies, e.g. Panasonic’s Panaflo Hydro Wave Bearing, Sintec Bearings by EBM/Papst, Fluid Dynamic Bearings by Sony, etc.
Thank for the link gauss! :+1: . That explains it a whole lot better than anything I had found……… and I had looked.
Discharged at 1A
Group buy/Brand new 30Q BT from Liionwholesale.
New and improved BT-C3100 2.2 W/Top tier Delta fan-12V/0.12A/1.44W
4 Slot Median:2972mAh
HKJ:2884mAh with FT 30Q @ 1A
A little higher mAh than my other test w/ newish 30Q BT
That’s the range my last twenty 30Qs tested with my 3400—-Not a bad match at a little over 2%
