Aha, no brass retainer ring on the driver side, so it’s some 2.5mm too short inside…
I guess just remove the driver spring (and put a subtle solder blob there) will solve the problem.
Any battery rattle or anything with the fix? Does it still want to crush the negative side?
Horrible with this lights regular price that this has been overlooked to begin with
Oh boy, definitely no rattle. Crushing the Batt- end? Well, maybe... It's darn tight in there. These are older EFEST cells, so might have been already some crushing. But it you see the cell sitting in the tube, just a little under the end, and knowing the tail spring has to completely collapse down to ~2 mm maybe, it doesn't look good.
I’m expecting mine any day now… :person_facepalming:
After the S41S crushed leds, now the S42 too short battery tube or whatever…
However, i ended up with a somewhat ‘free’ S41S after BG sent back a new head and agreed to sell the tail/switch part. Maybe we’re headed the same way again? Glad i didn’t pay the full price on this one.
I’ve no idea how to unsolder the driver spring without overheating the whole assembly… Can you share some tips?
Fits well using the S41 tailcap. The spring is soft and maybe set deeper:
That's about 1.5 mm clearance with the solder blob job:
Now we're cranking... A BLF A6 tube fits, reversed, then need to add a washer in the tail:
My S41 head is glued up real tight, never was able to get it apart. Least I can't break posts...
The tail spring is 1 mm diameter wire, sits in a 2 mm depth machined out depression. Full compressed it's still about 2.5 mm above the base (~4.5 mm compressed total).
Actually for mine, things are even worse. I tried bypassing the tailcap with a paper clip between the battery and the battery tube, and it still would not power up. The problem is that the *front*(emitter) end of the battery tube is too short (or the threads in the head are too long), so it never touches the negative contact ring on the board itself. I proved that by screwing the battery tube in *backwards* so that it made contact, and then I was able to get it to power up using the paper clip on the negative side. Inserting a circular shim in *front* of the battery tube, just ahead of the emitter board, yields a working flashlight which can also be tightened without further compression damage to the battery. This is clearly a design/fabrication issue, and I told Banggood in my latest email. Awaiting a response.
This setup works well for me. The o-ring is exposed though. With the solder blob on the driver, and the 1.4 mm thick copper washer shown above in the tailcap, the battery is not under stress.
Ohh - I managed to re-assemble the head w/optic with only one leg!
Exactly!! Yet to receive mine but if it too is faulty I have neither the time, tools, skills or inclination to bodge it together just to make it function.
