Hehehehe , yep !
Sometimes the stock levels for the Oz warehouse are disappointing …
Try Banggood.com or possibly gearbest for your RC needs …
I have recently started to play with Micro quads like the Eachine EO11 and the JJRC H36 bound to my Turnigy 9XR pro VIA a multi protocol module … https://goo.gl/v37FxQ
These things can be flown inside or outside … ( And for the $$ are just a boat load of fun )
My JJRC H36 set me back $17 AUS … RC is cheaper than smoking these days
Ok… here we go. All the 18650 are unprotected.
Lg he4 flat top. Work
Samsung 30q flat top. Work
Sony vtc4 flat top. Work
Samsung 30q button top. Not work
Lg mj1 button top. Not work
Sony vtc6 flat top. Work
Lg mj1 solder blop. Not work
Sony vtc5 solder blop. Not work
Lg mj1 flat top. Work
Sony vtc6 button top. Not work
Looking inside the light , the driver / contact board has a contact nipple on it ( solid ) . So I can’t see that end being the issue …
Take a MM or some wire , and pop the battery in and then run the wire or MM from the back of the battery to the body …
Does the light turn on ?
I dont know how to do that. Lol… but anyway… i am not here try to complain or cry… i love this light. It cost $31.79 and received in 15 days… ( fast )… i used to have an olight m1x striker xml led cost $60. This zanflare f1 is great deal… latest led. True moon light. I can navagiate around the surounding in low mode… i also like how the tailswitch operate… while the light is on, half press the tailswitch will temporary turn the light off.
Conclusion. I love this light for what it is. Great price. Xpl v6. Great construction. I will buy zanflare light again.
I just dont understand why my light doesnt like unprotected button top or solder blop. Thats all.
One needs to isolate the issue !
Is it the driver side , or the clicky side that is the root cause ….
If you have some electrical wire , one merely runs it from the back of the battery to the bare aluminium at the tail cap end , all you are doing is completing the circuit … ( Much like the clicky switch does )
If the light turn on when completing the circuit , the problem is not the battery …
To find solutions to problems , one first needs to know what the problem is !
( Because I am using a flat top battery in mine )
If we eliminate the battery or the front of the flashlight , then that points to something entirely different .
And after (?) is it almost 10 years now , one of the major reasons for issue for most people is the tailcap / clicky / assembly . ( And often the fix is as simple as tightening the retaining ring ) .
You sure you charged ’em?
Ok , 16340 …
I charged up some 16340 , these are really old unprotected 16340 , but always performed well .
They came of the charger at some 4.09 volts …
Low / med / high output was a match for the 18650 …
What surprised me was the output on Turbo , 1300+ Lumens which ran for all of about 5 seconds before the thermal protection kicked in …
I get the feeling that perhaps this light might be meant for the 3v rechargeable 16340 … ( 3.6v ’ish fully charged ) ??
Because Turbo on the 4.2v Fully charged 16340 ( well , 4.09v ) really pumped …
There does not seem to be any advantage using 16340 ( 3.7 nominal ) for output in the other modes .
And 5 seconds of Turbo is ( ? ) …
I dont have any Primary CR123 that are new … I have some old ones in my Surefire …
Yep , pretty much spent after all these years … ( Just tested )
Might have to order a 17650 for the 6P surefire …
Sorry about that guys , all my Primaries are like seriously old and I should probably toss them … ( Confirmed )
Hi Zanflare, I visit your website. How to get a F2?
Thank you, Zanflare. I will check out them .
ordered it
The waterproof of F1 is excellent . One night I walked in the heavy rain with Zanflare F1. It worked well all the way.
thank you too
me too
Quick regarding the review.
A notice there two version of the zanflare F1, a 4500-5000k and a 6000-6000k.
Which version did you review?
Which version would you recommend?
Thanks in advance
PS: Great review.
Mine must be the cool white … ( 6000k )
Just depends on how much a purple tinge on the edge of the beam offends you ? ( White walling )
Some folks just love warmer emitters ( nice yellow light ) …
Apples and oranges …
Hi Guys
Could you recommend me which flashlight diffuser or aka traffic wand that fit well to zanflare f1 ?
Been searching high and low but most fit up to 25.4mm.
Thanks
My suggestion, search for “diffuser” on these stores (that are both Kaidomain, one on AliExpress, the other, the KD store):
https://www.aliexpress.com/store/708513
Hope this helps
Anyone has measurement of kcd for both NW and CW?
Is it meeting spec of 16kcd?
Thanks.
Thanks for the review, it made a difference deciding to buy one.
