I and others have mentioned them before many times. Even put the driver though a full test on the bench to see exactly what it did.
The output remained more or less constant from an input voltage of 8.4V down to around ~7.8V. The output them spiked a bit for some reason from 7.8-7.6V before dropping back to normal until it could not maintain regulation anymore. Somewhere in the low 7V range (which would be about 3.7v per cell). Although all of this is from memory, so don’t take those voltages as gospel.
At that point it was just a high resistance direct drive driver and output would drop as voltage dropped.
This is exactly what you would expect from a cheap buck driver and how it is supposed to work (minus the spike in output in the 7.7V range).
I did try the xhp50.2 with the FX30 and wire across the resistors. I didn’t have my clamp meter then, but I think the amp draw was 9 or 10 amps. I didn’t even think the FX30 could handle that much without smoking something.
They are very similar, but you can’t have both low voltage protection and the indicator led on the 2 cell version of this driver.
Narsil v1.2 has LVP, but no temperature support or indicator led support.
Narsil V1.4 does not have LVP, but does have temperature support and indicator led support.
Basically the indicator is a little fancier than the power indicator. It can be programmed to stay on when the rear switch is on or you can manually turn it off. When you do a battery check the main beam as well as indicator led blink at the same time.
With my light I only needed the power indicator so that I know when the rear switch is on and off. So I chose to have the LVP and no indicator led or temperature support. I can measure the temperature with my hand. Lol
Which is better between what? V1.2 and v1.4 or do you mean both of them compared to M?
1.2 and 1.4 are equally good, they just have different options. Narsil M is supposed to have the ability to let you assign pin 7 so you can choose between temperature sensors or lvp. I’m not an expert in Narsil and the M version was not ready yet when I ordered my drivers.
Is Lexel making you one? If so, I would ask him which version suits your needs.
This is true on any light (unless the indicator light was monitored by the LVP circuit), but I don’t think this is really an issue. I mainly use the sideswitch light to tell me if the rear switch is on or off. If I’m not using the light, I turn off the rear switch so there is zero drain.
