I'm quoting myself here to clarify this. There is more metal to the housing of the S41 than the S42. Comparing them, it seems like the much smaller driver accounts for a lot of it. The 17 mm driver the S41 has means the housing in that area of the driver mount is much thicker and the inner pill area much narrower, where the 20-21 mm wide driver in the S42 pushed the width out, combined with the sandwich 2 board design to accommodate the USB connector, there is no room at all to make the shelf any thicker than it is already (~1 mm).
Tested the integrated charger. Took 6 hours 13 minutes to charge a 3000 mAh VTC6 at 0.4-0.6 A (measured from the usb socket, not the battery). End voltage 4.16 V. Discharging at 8 watts produced a total energy of 10.56 Wh, which is about 97.7 % of a completely filled cell charged in an MC3000. Not bad, albeit too slow for me.
Charge curve
Discharge curve.
Blue: after charging in the S42
Pale blue: after charging in the SkyRC MC3000
Tom, checked this with a simple cable between housing edge and battery bottom, it worked alright: for the first time, I saw the light !
So inner dimension of head and tail (too long) vs screw parts dimension of classic A6 tube (too short) is clearly the issue …
Thanks for the advice!
My Keeppower 18350 end voltage was 4.11v.
My Samsung 30q 18650 end voltage was 4.12v
Is anyone having the same result when using the USB charger?
Thanks
Sorry for the delay, now we give a solution for S42 problems:
After Verified by the manufacturer,the length of the tube is too short and it can’t compatible with most length of 18350 and 16340 protection cells and button top cell, the manufacturer adjusted the tube length and they verified the 40 mm tube will solve the problem and allow most cells to be used without the danger to damage it, including the 18350 and 16340 cells. At the same time, they also modified the design of the USB silicone cover.
Any problems, please contact our CS, we will send you a free 40mm tube and USB silicone cover, you can replace it yourself. Please send E-mail to cservice@banggood.com, don’t forget to include your order number, thank you.
By the way.S42 and s42s will use 40 mm tube and the latest USB silicone cover. The s42 now has been sent back to the factory repair, thank you for your understanding and support, we will try our best to do well in the after-sales service.
Hello all,
I have just received mine today, exactly one month after purchase. While I was able to get it working with the shortest 16340 battery I have, mine has a different problem. After turn on, long pressing for turbo makes it flash quickly and then disconnect from voltage. Breathe light turns off. Unscrewing and re-tightening tube restores function. It displays the same behavior when short clicking. Once it reaches turbo the same short flash and voltage disconnect happens. Very disappointing. Battery is fully charged efest purple flattop.
This battery length/tube issue reminds me of the UT01 where i almost broke the light and dented the button of a cell… One easy way to alleviate the problem, at least temporarily is to add a couple copper ‘rings’ inside the tail cap, where the tube connects. The oring will likely be exposed though.
Such ‘rings’ can be made of a short section of copper wire wrapped around something about the same diameter. You can use tin foil too but it would likely not stand the high current on the S42.
I got a nice assortment of copper washers a while back, recommended here, so just had to pick one that roughly fit in the tail - pics posted a while back. I'd say it exposes about 2/3 of the o-ring.
well, I sacrificed an Efest 800 to the Krunch God just so I could try this beast.
kinda disappointed that I could handhold it, even recycling turbo from time to time.
now with the spacer I can use my WindyFire 700. whole different animal.
terminated the first finger test due to familial duties….just a few minutes
came back and within a minute, I was uncomfortable, and crying like a baby a moment later
seems to my finely calibrated, elderly thin-skinned hands, that the hottest point in the whole danmed light is the switch ring
great engineering there! :person_facepalming: and I gotta hold it for a long press to off? :person_facepalming: :person_facepalming:
I’m glad I got a chance to see this in its potential before my Aspires arrive.
