✜Banggood deals≫ NC TUP ⚡Rofis TC1⚡$23.06⚡S41S ★★★ $34.65 BLF GT mini ★ ⚡ Fitorch P25 QUAD LED 26350⚡X1R angle light ★BLF GT70★
SKILHUNT M2 2016 Li-ion Ni-MH Ni-CD Universal Multifunction Charger for VIP2 and above accounts is for $10.99 and using BG points it’s possible to lower the price to:
VIP2
VIP3
VIP4
VIP5
$9.23
$9.12
$9.01
$8.79
According to excellent HKJ review it’s good and simple to use charger:
Test/Review of Charger Skilhunt M2
BLF A6 XPL 1600LM 7/4modes EDC LED Flashlight + INR18650-30Q Battery is in promotion for $21.95 and BG points still work so it’s possible to lower price even more to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$18.66
$18.44
$18.22
$18.00
$17.56
This is probably the lowest price for the set with battery to date.
4pcs NCR18650B 3400mAH 3.7 V Unprotected Rechargeable Lithium Battery is for $17.99 and using BG points it’s possible to lower price to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$15.29
$15.11
$14.93
$14.75
$14.39
LUMINTOP LM34C Micro-USB18650 Protected Rechargeable Li-ion Battery for $6.99
It’s easiest way to convert flashlight into micro USB rechargeable one. Internally it uses Panasonic NCR18650B 3400mAh cell and is longer like all protected cells at 70.7mm so be sure to check if it will fit.
Using BG points price can be lowered even more to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$5.94
$5.87
$5.80
$5.74
$5.59
Astrolux S1/BLF A6 A17DD-L FET+1 2.8-4.35v 7/4 Modes Flashlight Driver is for $4.29 and using BG points price can be lowered further:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$3.65
$3.60
$3.56
$3.52
$3.43
This is exactly the same driver that powers Astrolux S1, Astrolux S41 and BLF A6 flashlights. It’s capable of delivering 6A of power (with quality high drain cell of course) and also features one AMC7135 for efficient low and moonlight modes. Sub lumen moonlight is possible with XP-L (3-4mA which would be about 0.2-0.4 lm). User selectable memory and two mode groups (3 and 7 modes accordingly), hidden blinkies include bike flasher and voltage indicator mode.
UI is very ergonomic - using short click you can go one mode upwards and using medium tap (0.5-1.5s - very intuitive once you try) you can change the mode backwards - no need to circle back whole mode bank.
This driver was conceived here at BLF, designed by Wight and the firmware was written by ToyKeeper. It’s open source and available here: ToyKeeper BLF A6 Firmware
How do you get the S41 for $23.95? It shows $30 when I click the link.
HaikeLite SC02 MTG2 5000K 26650 2000LM EDC LED Flashlight using the coupon code »Request via PM here« lowers price to $40 (-$24.95).
This flashlight has micro USB port for cell charging - it’s located on the head screws so when flashlight is used it’s completely covered.
HaikeLite MT01 Trekker XHP50 V2 CW/5000K NW 2500LM LED Flashlight using coupon code »Request via PM here« lowers the price to $38.95
HaikeLite MT02 XHP35 HD CW 2500LM Thrower EDC LED Flashlight using coupon code »Request via PM here« lowers price to $37.50 (-$14.50).
HaikeLite MT03 II Devourer XHP70 2SPS 8760LM CW/NW High Power LED Flashlight using coupon code HLMT03 lowers the price to $96.95
HaikeLite MT07 Buffalo XHP70 5000LM CW/NW High Power LED Flashlight using coupon code HLMT07 lowers the price to $79.95.
That deal expired - I updated the details. Now you can either use coupon code 8a955d to lower the price to $25.50
Astrolux S41 4x Nichia 219B/XP-G2/XP-G3 A6 1600Lumens Mini LED Flashlight
or BG points to lower the price depending on your VIP status:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$25.50
$25.20
$24.90
$24.60
$24.00
All colors Nitecore T Series Tube 45LM USB Rechargeable LED Light Keychain using coupon code b00e77 lowers the price by 30% (to $6.93).
Update: Deal expired. Now coupon code available - leave me PM for details.
Astrolux S41 4x Nichia 219B/XP-G2/XP-G3 A6 1600Lumens Mini LED Flashlight for VIP1 and above is for $23.56 and using BG points it’s possible to lower the price even more to:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$20.03
$19.79
$19.55
$19.32
$18.85
18650 extension tube available here:
Astrolux S41/S42/Astrolux S1/BLF A6 LED Flashlight 18650 Body Tube for $2,49 (BG points can be used to lower price further).
BLACKWATER KR36 Titanium Alloy Tritium Vials Light Self-luminous 25Years for VIP2 and above is for $36.95 (instead of $49.95) and using BG points it’s possible to lower the price further to:
VIP2
VIP3
VIP4
VIP5
$31.04
$30.67
$30.30
$29.56
This keyfob doesn’t need light exposition to glow at night - it uses gaseous tritium (isotope of hydrogen) in a process called radioluminescence and lasts ~25 years (due to radioactive decay of tritium it looses half intensity in about 12 years - it doesn’t stop emitting light abruptly like discharged flashlight - instead it gradually glows dimmer and dimmer).
Here’s article about how this works: wikipedia: Tritium illumination.
Special price deal expired. Now coupon available - send me PM if interested in deal details.
Nitecore Concept 1 XHP35 HD E2 1800LM Mini EDC LED Flashlight 18650 using the link preorder price is lowered to $47.95 (normal preorder price is set at $64.95).
No coupon so you can still use BG points to further lower the price:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$40.76
$40.28
$39.80
$39.32
$38.36
Quickly grabbed another Astrolux S41 XPG-3… Manual switch ftw! Thanks!
Regards…:slight_smile:
I’m glad you liked it:)
Astrolux A01 Nichia 219B 102LM AAA Mini Waterproof Keychain EDC LED Flashlight is now for $7.99 and using BG points it’s possible to lower the price even more:
VIP0/1
VIP2
VIP3
VIP4
VIP5
$6.79
$6.71
$6.63
$6.55
$6.39
Too late for S41 :frowning:
Hope you find another deal on that one :slight_smile:
