JasonWW
(JasonWW)
June 18, 2017, 5:46am
8642
teacher:
Some people are saying it would be no problem designing & making a dual footprint board.
Others are saying the exact opposite.
This leaves the mentally challenged, such as myself ; confused…. to say the least. :person_facepalming:
Both groups can’t be right…. I don’ think anyway.
Which group is correct??
They both are correct because the question was not clearly defined.
Is it easy to change the design of the mcpcb to a dual footprint board? Yes
Is it easy for Thorfire to change the mcpcb to a dual footprint board? No
The Miller elaborated on the many reasons it’s not easy for Thorfire to do this.
I think anyone who said it would be easy for Thorfire to switch designs were purely speculating. I would have to defer to The Miller’s answer.
teacher
(teacher)
June 18, 2017, 6:40am
8643
Thanks Jason, that answers what I wanted to know. :+1:
AFAIAC the rest of it is a mute point.
The explanation djozz gave several post back as to why it was a very bad idea to change anything about the MCPCB made perfect sense.
Perfect sense in that it could lead to untold Q8 misery with what TF might come up with.
Nobody wants that possibility to be introduced any more than it already is.
fixed_it
(fixed it)
June 18, 2017, 12:24pm
8644
And that is by far the best summary of the situation I’ve read so far! You are clearly enlightened.
PBWilson
(PBWilson)
June 18, 2017, 1:09pm
8646
So it’s just down to locating new springs and dealing with board delamination, right?
I’m crossing my fingers both can be addressed soon.
The_Miller
(The Miller)
June 18, 2017, 1:36pm
8647
Yes, that is right
Springs
Board
Narsil latest version
Manual (4 pages 1 general manual and 3 on par with Narsil)
Pretty close now
hank
(hank)
June 18, 2017, 4:21pm
8648
Thorfire had no idea what the key features were that makes the Q8 perform. Despite our continuous and very clear
design advice they kept changing stuff without explanation, re-designing parts and body. Often the changes were neutral
so we just let it be, sometimes it was undermining performance
and
Flag these to be elaborated for a “lessons learned” reconsideration, once this is all over.
Now cue the ominous background music.
“What are they doing over there? It’s quiet. TOO quiet ….”
Somewhere out there, a bean-counting cheese-paring businessman is nibbling away at a design specification to make a little more profit on each piece.
https://www.google.com/search?q=scorpion+frog
I put an XM-L triple mcpcb in my Titanium X6 and used XHP-50.2 emitters on it. … if I use 2 of my new Efest 20700 cells to power it, the dang thing produces a whopping 14,283 lumens! (27.84 Amp draw!) … tremendous increase in heat …
… already pretty maxed at 6,000 + lumens. … could easily be dangerous … not equipped to handle the heat …
You know things have gone a little too far when even Doctor Frankendale thinks it’s dangerous.
I finally did some testing, now that I’m back from Asgard and have a working computer again. Not sure how much Tom will have time to change, or how much he wants to change. There don’t seem to be any important firmware issues, but there might be some small things to fix or some small improvements to add.
… and hopefully it won’t turn out like the X6v2, where the units shipped with old firmware. That was unfortunate.
teacher
(teacher)
June 18, 2017, 4:48pm
8651
+1 , yes it is! Simple, factual, to the point.
Three great words……
hank
(hank)
June 18, 2017, 7:16pm
8652
Aside — has someone checked how “phosphor bronze” translates?
There’s been so much confusion because copper, brass, and bronze all seem to translate poorly to Chinese.
It would be good for them to know how Djozz’s phosphor springs made in Netherlands were specified — alloy? unique identification numbers?
Googling the term, there’s a wide range of variation:
goshdogit
(goshdogit)
June 18, 2017, 7:46pm
8653
I’m very pleased that the Q8 has a tripod mount, and I’ll credit myself for being the first to suggest it waaaaay back in post #25 !
The Noctigon Meteor doesn’t have a tripod mount, so I made one out of a quick-release ‘truss clamp’ used in concert and theater lighting.
This type of mount is rock-solid for attaching the Meteor to a bicycle, ATV, or anything that can have a screw or bolt fitted to it.
I’m hoping the clamp will fit the Q8, too.
Can someone with the latest Q8 prototype share the diameter at the center of the battery tube?
I realize the diameter may change slightly for final production, but the truss clamp works from about 1-7/8” to 2-1/8”.
The_Miller
(The Miller)
June 18, 2017, 8:25pm
8654
Can I give measurements in mm? Inches are so strange to me.
goshdogit
(goshdogit)
June 18, 2017, 8:36pm
8655
Of course! I speak metric as well as imperial.
BTW, 1 inch = exactly 25.4 mm.
The_Miller
(The Miller)
June 18, 2017, 9:17pm
8656
Ha how tired I am, the caliper has a button to switch so I can give both, tomorrow, the Q8 is next to the bed and I know I just don’t want to bring it from there before I slept a little
The_Miller
(The Miller)
June 18, 2017, 9:25pm
8657
Ah and yeah thanks for giving us a hard time making that tripod hole a part
No joking, it is an awesome part, really thanks
djozz
(djozz)
June 18, 2017, 9:38pm
8658
The diameter in the middle of the battery tube, away from the flat bits is 50.0 mm.
goshdogit
(goshdogit)
June 18, 2017, 10:05pm
8659
You’re very welcome! The Q8 will be an awesome work light when paired with a small tripod!
Thanks! :+1: Looks like a good fit for the truss clamp.
For anyone interested, the 2” quick release truss clamps can be found on eBay for about $10 each.
To make two mounts, go with a ‘dual swivel’ clamp like this:
I had one made for my bicycle to mount another BLF Special edition light. One of the Truss vendors on Ali Express made it on order.
hank
(hank)
June 19, 2017, 1:57am
8661
The bolt on the truss clamp fits the tripod socket on the flashlight?
