Yes, that is right
Springs
Board
Narsil latest version
Manual (4 pages 1 general manual and 3 on par with Narsil)
Pretty close now
Yes, that is right
Springs
Board
Pretty close now
and
Flag these to be elaborated for a “lessons learned” reconsideration, once this is all over.
Now cue the ominous background music.
“What are they doing over there? It’s quiet. TOO quiet ….”
Somewhere out there, a bean-counting cheese-paring businessman is nibbling away at a design specification to make a little more profit on each piece.
https://www.google.com/search?q=scorpion+frog
You know things have gone a little too far when even Doctor Frankendale thinks it’s dangerous.
I finally did some testing, now that I’m back from Asgard and have a working computer again. Not sure how much Tom will have time to change, or how much he wants to change. There don’t seem to be any important firmware issues, but there might be some small things to fix or some small improvements to add.
… and hopefully it won’t turn out like the X6v2, where the units shipped with old firmware. That was unfortunate.
+1, yes it is! Simple, factual, to the point.
Pretty close now
Three great words……
Aside — has someone checked how “phosphor bronze” translates?
There’s been so much confusion because copper, brass, and bronze all seem to translate poorly to Chinese.
铜,黄铜和青铜
Tóng, huáng tóng hé qīngtóng
It would be good for them to know how Djozz’s phosphor springs made in Netherlands were specified — alloy? unique identification numbers?
Googling the term, there’s a wide range of variation:
Phosphor bronze - Wikipedia
Phosphor bronze is an alloy of copper with 0.5–11% of tin and 0.01-0.35% phosphorus.
Resources: Standards & Properties - Copper & Copper Alloy Microstructures: Phosphor Bronze
The phosphor bronzes are designated as UNS C50100 through C54200. Leaded phosphor bronzes combine good strength and fatigue resistance with good machinability, high wear resistance and corrosion resistance. They are used in applications such as sleeve bearings, thrust washers, and cam followers. They are designated as UNS C53400 through C54400.
I’m very pleased that the Q8 has a tripod mount, and I’ll credit myself for being the first to suggest it waaaaay back in post #25!
The Noctigon Meteor doesn’t have a tripod mount, so I made one out of a quick-release ‘truss clamp’ used in concert and theater lighting.
This type of mount is rock-solid for attaching the Meteor to a bicycle, ATV, or anything that can have a screw or bolt fitted to it.
I’m hoping the clamp will fit the Q8, too.
Can someone with the latest Q8 prototype share the diameter at the center of the battery tube?
I realize the diameter may change slightly for final production, but the truss clamp works from about 1-7/8” to 2-1/8”.
Can I give measurements in mm? Inches are so strange to me.
Of course! I speak metric as well as imperial.
BTW, 1 inch = exactly 25.4 mm.
Ha how tired I am, the caliper has a button to switch so I can give both, tomorrow, the Q8 is next to the bed and I know I just don’t want to bring it from there before I slept a little
Ah and yeah thanks for giving us a hard time making that tripod hole a part
No joking, it is an awesome part, really thanks
The diameter in the middle of the battery tube, away from the flat bits is 50.0 mm.
You’re very welcome! The Q8 will be an awesome work light when paired with a small tripod!
Thanks! :+1: Looks like a good fit for the truss clamp.
For anyone interested, the 2” quick release truss clamps can be found on eBay for about $10 each.
To make two mounts, go with a ‘dual swivel’ clamp like this:
I had one made for my bicycle to mount another BLF Special edition light. One of the Truss vendors on Ali Express made it on order.
The bolt on the truss clamp fits the tripod socket on the flashlight?
Hmm, I suppose you could configure it that way using a 1/4-20 (quarter twenty) bolt if you wanted to fasten the light to a 2” cylindrical object, but my plan was to hold the flashlight in the clamp and bolt the clamp to a bike, ATV, etc.
Sorry if I created some confusion by mentioning the tripod hole. I plan on using the tripod mount for using the Q8 as a work light, and using the truss clamp in more rugged situations.
Please add me to the list for one unit. Thank you.
Yes 50mm (or 1.968 inches
Oops m=mm
Yes 50m (or 1.968 inches )
Did you mean 50 mm??
I was thinking about reflowing 4x Nichia 219C 4000K CRI 90+ D240 LEDs instead of the XP-Ls.
Does anyone have an estimate of roughly how many lumens I can expect to get with this setup?
My crude estimate places the output at around 4000 lumens.
