Excellent packaging once again. Seems that the Ledil triple has legs that fit right into the XP32 these days, no need to trim the legs shorter anymore.
Built a X7 triple with a MTN20DDm and 219C CRI80s and it’s glorious pure white goodness.
Any ideas?
If mod mentioned above looks not so cool nowadays, Im open for your suggests.
I actually have an old incan 3D mag. Currently has a simple drop in LED, maybe 200 lumens tops. Been thinking about upgrading it. I might look for a replacement reflector to sacrifice. I had also been thinking about possibly going with a multi-emitter TIR setup instead of single LED with stock reflector. Something like this.
They also sell these on that website, which I think uses stock reflector.
http://asflashlights.com/home/63-copper-heat-sink-for-maglite.html
Im not sure that heatsink for stock reflector is needed. Single-die leds wont make wow-effect while multi-dies require OP reflector which is rare and expensive. 50mm tir optics can be also used, but it needs some extra development work to be sure that such mod can be assembled easily.
For multi-led version, I would prefer to use 50mm optics instead of 35mm cute-3.
I still love my VG10 quad. A very nicely balanced light.
Very big update in first post, big clearence. Also hope it will look more usefull from mobile devices.
Just wondering, are there any M1 spacers left?
And is it for the new M1 without the pill? Sorry, I have no idea how the spacer is supposed to be mounted…
Those XHP LED’s are a great deal and a hard to find tint. I would get some for sure if I had the money and something to use them in. I might see if I can find something to use them in…
2pcs in stock.
Just over stock pcb shelf, doesnt matter if it is solid pill-less or brass pill.
Didnt receive any replies, but one member helped me with host drawings and after I saw them I decided to make Mag D sink with adjustable insert.
Last question about it. I gathered to make regular driver place for 17mm driver with retaining ring. But there is enough place for bigger driver (buck?), which should be more usefull with various of host length. Unfortunately, I dont have opportunities to make big retaining ring now, so we need to decide - 17mm with retaining ring or bigger (25-30mm) place for driver press-fit.
Thats a tough choice. Retaining rings are very good but larger drivers are also very good. I see drivers moving to larger form factors as time progresses, particularly if the 21700 cell becomes popular. I am a big fan of moving to 20-21mm drivers myself, they give so much more room for driver features and we need every bit of that room. Although right now most drivers are still 17mm based.
I guess it really comes down to what people will power these lights with, lithium cells or D cells? Unless the voltage matches up with the LED power it will have to use a buck or boost driver.
The best option would be say a 30mm driver with an optional adapter to neck it down to 17mm. I know people have found washer that work for things like this in the past.
If that is not an option then seeing as there are not really any good buck options above 21mm right now (I see that changing in the next year or 2) just stick with 17mm. Most people building a maglight are more worried about simplicity over raw performance I would guess.
If there is enough space, there could be some steps with enough space for each step.
Kaidomain.com has some good boost-drivers with 20 and 22 mm for 6V and 12V LEDs. I think they should fit in the sink.
Perhaps for a 17mm driver with ring and 30mm and lower driver with adapter. You could sell the adapters too.
(I do not plan to mod maglites again, but thats my opinion for a sink)
I like idea with adapters more than step design. Just need to find proper thick brass tube.
What are the inside dimensions? (MCPCB size?)
I’m in the camp that says go with a larger driver and use adapters if the user wants smaller. As long as the sink is copper or brass soldering/press fit works for retaining.
32mm driver would allow use of KX70 boost driver, 30mm would allow use of L6 drivers.
Go as big as possible, easy to make a small driver work in a big hole, hard to make a big driver work in a small hole.
I can get measurements from the L6 30mm retaining ring if you like.
I would not call this inside (pcb is inside reflector, not inside heatsink). I know that stock reflector hole is 14mm, but I want to make it for 16mm mcpcb.
30->22
30->20
30->17
Does other sizes required?
Only other common size is the 21mm. I wish we could just standardize the 20-22mm drivers at say 21mm. That would be perfect for lights based on the 21700 cells.
Anything larger can generally also be had in 30mm.
21mm would still be able to squeeze inside most 18650 lights too when you consider the wall thickness of the tube the battery sits inside of. It would be nice if everyone could move away from 17mm up to the 20-22mm range to give more driver space, allowing for more complex buck and Boost drivers.
I don’t know that any other adapter sizes are needed besides the 3 listed though. Maybe 26mm for some of the buck drivers on fasttech.
