:+1:
Doesn’t mean as much if I say it…some people might think I’m biased.
:+1:
I cant be bothered with modding flashlights i have to say.
And the ultra small ones like running on a 18350 or similar that’s just too small for me, would work fine for my friend as he seem to love what i call lipstick flashlights.
But i prefer something a bit more beefy and i might even consider one with a 26650 as i carry in belt and not pocket.
Biggest issue it seem to me is finding one that also have a good pouch that will last more than a few months.
But not to worry i will find something that will work for me, but it might take a few tries to get it right.
Biggest issue it seem to me is finding one that also have a good pouch that will last more than a few months.But not to worry i will find something that will work for me, but it might take a few tries to get it right.
The Convoy BD06 and BD01 both run off a 26650, have built in chargers run off any standard USB charger. I just recently got a BD06 running on the newest revision of Biscotti and I was VERY impressed. Convoy is just about to list the new larger holsters that fit the C8, BD01, BD06, M1, M2 and a few others. It’s a very rugged holster and the BD06 is an extremely rugged light You could get the switch-direct rechargeable light and holster for under $30…possibly as low as $25.
Here is the new holster for the larger-than-lipstick lights.
Yeah i have been looking at those convoy flashlights, with the build in charger it would be perfect for the car permanent plugged into a 1 A USB outlet when not in use.
It always seem to be the stitching that let me down on the pouches i had, so bad i have been thinking about getting my leather work gear out and make my own.
But those tools are hard to find as i have not used them since 1988 or something so buried deep in my long time storage place, and nowadays i am more into Kydex at least for holsters holding knifes, i really like to try working with that stuff one day.
That new “holster” look sweet :sunglasses:
Picked up a L6 with a N4 1A Emitter. ~6500K. Wanting to upgrade it to a XHP70.2 P4 2C 5700K emitter but I have a question. Does anyone have any comparison shots of a 5700K 2C tint? I find the 6500K 1A is a bit too blueish and I’d like to get closer to a true white w/o any noticeable yellow. Is 5700K 2C a good tint to fit the bill?
I think both 50.2 and 70.2 are going to have the yellow corona regardless of the hotspot color temp.
What part of the swap are you considering to be an upgrade? Higher output, beam pattern, color?
Well 200 more lumens is kinda nice, it would push the l6 closer to a real 4000 lumens rather than the 3500~3800. It would be a little more efficient too. The only tints I can find right now in the 70.2 is a 1C and a 2C. Would a P4 1C @ 6000K be better than the bluish N4 1A @ 6500K? I’m basically trying to hit a tint that when I shine it at something white, it doesn’t show up blueish and something that isn’t too yellowish white. I wonder if a P4 1C would be it?
I can’t help you there. I tried a 5700k xhp50.2 in my l6, but didn’t like it. Much too yellow for my tastes.
The 70.2 are still pretty new so not many people have tried them yet. You might ask this question on the thread for the 70.2. Some of those guys have bought them.
http://www.cree.com/News-and-Events/Cree-News/Press-Releases/2017/March/Cree-Second-Generation-Extreme-High-Power-LED-Delivers-Unmatched-Efficacy-Lumen-Density ” In addition to light output and efficacy enhancements, the XHP70.2 LED improves optical uniformity through secondary optics, enabling lighting manufacturers to deliver better lighting performance. ” Hopefully sans-hole like the XHP50.2!
Ok thank you for the redirect!
Hello everyone
I pre ordered a customized L6 : SMO reflector, dedomed led (colour ~5000k) , thicker copper plate for the led, double springs for better batts contact.
In stock version throw is around 57000cd, in SMO version with dedomed led ~970000cd with a better (for me) colour ~5000k.
Should be interesting
Hello everyone
What do you mean you “ordered” it? Who offers those services?
With all those mods I hope they add an R100 resistor to bump up the output.
What batteries will you be running? Double springs might not work with protected cells.
Is a dealer from my area (Romania) which I have relation from many years (I have lights which are modified by him, example Olight M22 dedomed) .
I will use Keeppower IMR 5200mAh .
3000+ lumens in this configuration I would say that is more than ok (for me) , led is not at the limit, output is decent.
Is just a matter of money (light is ready to be sent ) , I will keep posting after I get the light
I just upgraded my L6 from the stock XHP70 N4 1A 6500K to a new XHP70.2 P2 1D 6000K and loving the tint. Still on the edge of cool white with a little bit of natural sunlight tint. I went camping and took the L6 out for a test run. The L6 lit up a lake all the way to the other side into the trees! Amazing! I have a question. I’m having a hard time trying to get the actual lumens per mode switch listings. All I can find is current draw. Does anyone have the lumens per mode info? Thanks.
Measuring lumens requires a calibrated integrating sphere for good accuracy. A few guys here have homemade versions of those devices but I don’t think anybody has fully mapped out the output to lumens ratio yet.
Theoretically, the 70.2 should put out the same lumens at the same amp draw as the earlier 70. In your case, you’ve got a slightly higher bin number so you should expect that if the amp draw is the same as the old emitter, the new one’s output should be a little bit higher. I could be wrong, though.
A rough estimate of lumen output can be done with a ceiling bounce test if you have a lux meter. You would need to set up a specific location on a table then set the Lux meter at a specific location right near the flashlight. Shine the light straight up and measure the output on all four modes with each emitter. Since we know the lumens of each mode with the stock emitter, we can estimate the new lumen amount based on that.
Thanks for the info. I do not have a lux meter unfortunately. I’ve heard numbers like 3500 on turbo, others 3800. I’m going to guess the 70.2 I have will push it to either 3800 or 4100.
That sounds about right. The real advantage of the 70.2 is that it doesn’t stop at 12 or so amps like the xhp70, it can keep going up to 18 amps! That’s where you get your 7,000 and 8,000 lumen from.
I would recommend adding a resistor and get good unprotected batteries as well. This gave me 2 extra amps and a matching bump in brightness over the protected Keeppowers.
Oh yeah, I picked up my LX1330b Lux meter for about $30 on ebay. It’s very cool to have.
I meant to dig up my records on a stock L6 and forgot to do it. Sorry. Will see if I can locate the lists today.
My black L6 has a zener modified FET driver with ramping firmware and a higher-than-stock binned emitter. It’s pulling right at 12A for some 7200 lumens.
If I recall correctly, the last L6 I got in silver color was making around 3800 in stock trim, it now has an MT-G2 in it. Still though, I’ve got lists of amps and lumens from each level written down somewhere (posted here as well if such could be found)
The Convoy L6 really is a sweet deal of a light, especially with so many easy ways to change up beam profile and tint and easy power level mods. Will have to get a couple of these 70.2’s coming and maybe I’ll be ready to rock some changes by the time they get here.
Thank you Jason and DBC. I agree the L6 is a beast of a light. I equally like it as much as my Acebeam K40M. I may just keep the L6 stock as I feel it’s bright enough for now. I am going to assume one of the added benefit to the new 70.2 is cooler temps on turbo,stock, correct? I’ve never been able to test it with the new swap yet. Mabey tonight fireworks won’t be the only thing lighting up the sky. Happy 4th everyone!
Cooler temps on turbo. Hmmm. It doesn’t seem likely. I don’t know really. They seem more efficient when used with a buck or boost driver.
I think if you adjusted your turbo amp draw lower so the the lumen output matched the xhp70, then it would run cooler for sure.
My guess is the heat will be the same, but you get the extra lumen output.
The 70.2 is still pretty new and I haven’t seen a good amp/lumen output graph yet.
With the buck driver the light should be more efficient (make less heat) at the same current with the 70.2. The lower Vf means lower input wattage with the same (or greater) lumen output.
