Those XHP LED’s are a great deal and a hard to find tint. I would get some for sure if I had the money and something to use them in. I might see if I can find something to use them in…
2pcs in stock.
Just over stock pcb shelf, doesnt matter if it is solid pill-less or brass pill.
Didnt receive any replies, but one member helped me with host drawings and after I saw them I decided to make Mag D sink with adjustable insert.
Last question about it. I gathered to make regular driver place for 17mm driver with retaining ring. But there is enough place for bigger driver (buck?), which should be more usefull with various of host length. Unfortunately, I dont have opportunities to make big retaining ring now, so we need to decide - 17mm with retaining ring or bigger (25-30mm) place for driver press-fit.
Thats a tough choice. Retaining rings are very good but larger drivers are also very good. I see drivers moving to larger form factors as time progresses, particularly if the 21700 cell becomes popular. I am a big fan of moving to 20-21mm drivers myself, they give so much more room for driver features and we need every bit of that room. Although right now most drivers are still 17mm based.
I guess it really comes down to what people will power these lights with, lithium cells or D cells? Unless the voltage matches up with the LED power it will have to use a buck or boost driver.
The best option would be say a 30mm driver with an optional adapter to neck it down to 17mm. I know people have found washer that work for things like this in the past.
If that is not an option then seeing as there are not really any good buck options above 21mm right now (I see that changing in the next year or 2) just stick with 17mm. Most people building a maglight are more worried about simplicity over raw performance I would guess.
If there is enough space, there could be some steps with enough space for each step.
Kaidomain.com has some good boost-drivers with 20 and 22 mm for 6V and 12V LEDs. I think they should fit in the sink.
Perhaps for a 17mm driver with ring and 30mm and lower driver with adapter. You could sell the adapters too.
(I do not plan to mod maglites again, but thats my opinion for a sink)
I like idea with adapters more than step design. Just need to find proper thick brass tube.
What are the inside dimensions? (MCPCB size?)
I’m in the camp that says go with a larger driver and use adapters if the user wants smaller. As long as the sink is copper or brass soldering/press fit works for retaining.
32mm driver would allow use of KX70 boost driver, 30mm would allow use of L6 drivers.
Go as big as possible, easy to make a small driver work in a big hole, hard to make a big driver work in a small hole.
I can get measurements from the L6 30mm retaining ring if you like.
I would not call this inside (pcb is inside reflector, not inside heatsink). I know that stock reflector hole is 14mm, but I want to make it for 16mm mcpcb.
30->22
30->20
30->17
Does other sizes required?
Only other common size is the 21mm. I wish we could just standardize the 20-22mm drivers at say 21mm. That would be perfect for lights based on the 21700 cells.
Anything larger can generally also be had in 30mm.
21mm would still be able to squeeze inside most 18650 lights too when you consider the wall thickness of the tube the battery sits inside of. It would be nice if everyone could move away from 17mm up to the 20-22mm range to give more driver space, allowing for more complex buck and Boost drivers.
I don’t know that any other adapter sizes are needed besides the 3 listed though. Maybe 26mm for some of the buck drivers on fasttech.
I 100% agree. I have been asking jdubs to pitch this to Convoy for some time. If the retaining ring for the driver screwed into the head instead of the pill it would allow a 20-21mm driver to fit in lights with no changes.
That little bit of extra space with a 20-21mm driver is key to making a lot of newer driver designs work. You need every bit of space you can get.
20mm driver can already fit using the current retaining ring design for lights like C8, M1, M2 with the integrated shelf. Just have to modify the driver pocket very slightly. I did it with a C8 to get an XHP50.2 and H1-A driver inside.
For the S series your idea of using the main threading for the retaining ring would be perfect. I actually sent a PM to jdub about a month ago myself requesting larger drivers in any new development lights.
I look forward to seeing what new developments there are when the 21700 batteries begin to hit the market.
I was thinking about this when somebody requested making S2+ pill for 20mm driver.
This idea is not as good as it gets. Regular S2+ pill is good because you can make full assemble outside and then just screw it inside host. My pills even dont have screwing holes, I use those one that are drilled in retaining ring. With 20mm driver place, there is no “meat” to make holes or even grooves to screw separate pill (without ring). Tightening ring after pill is screwed down is not very safety, you need to hold driver from rotating to prevent wires broke. Host threads pitch is 2.5 time more than stock retaining ring, this means that you need to apply more screwing force to reach same surface pressure. But if you will apply it, this “sandwich” will clamp together (same thing can be made with two nuts over one bolt tightened hard to each other) and removing ring may become mission:impossible.
20mm driver place looks more reasonable for lights with integrated shelf and separate head (A6, X2R) or bigger models.
The idea with the S2 series is that you use a pill much like the stock one, only with a larger internal bore in the driver cavity.
You assemble the pill like normal with the driver sitting against the bottom of the pill but nothing actually holding it in place.
You then screw the pill into the light, this is the only have part that is a bit tricky as it would be hard to get to the pill to screw it down with a 20mm driver covering it up.
Then you simply screw down a retaining ring over the top of everything. I have not had issues with the driver spinning in cases like this personally, if that was a problem it would not be hard to hold it in place.
I ordered this - Copper spacer BLF X6/Eagle Eye X6/Astrolux S2 for Ledil Cute-3 triple 8.6mm height
Everything is OK. Thank you :+1:
PM sent
Noob question about Khatod quad spacer for M1: What is the mcpcb diameter for it? Driver diameter? Would it require drilling a hole down the middle?
20mm pcb. It was made for tpad pcb, you can use those that are available now from mtn but you will need to open holes for optics legs. As other spacers, there is no driver place, you just use stock host driver place. Yes, you need to drill central hole in the stock shelf. X5/M1/M2/VG10 kits are pretty similar and easy for build.
