I don’t understand. You have the Opus, it works, and does more than the Lii. It’ll cost you more to send the Opus back than the Lii costs most likely. Just use the Opus.
Were those Samsung 25R dead? Did you test that? You don’t say. Seems unlikely that Illumnsupply would send you dead cells. Some cheapo site, maybe. I have not measured IR on a dead cell but I would not be surprised if it was quite high.
IR is NOT simple or easy. If it was it would be on these chargers and be reliable. You are working with….very……small differences. Even the way the cell is put in, or it’s temperature, or charge state all affect IR. There is a way to measure it without a charger. HJK showed a way once. Too complicated for me to bother with. I’m OK with a decently rough estimate.
The Lii does NOT need a better power supply. The Opus could use one IF you are going to push it. Not so necessary if you are not. You CANNOT push the Lii as hard as the Opus so it does not need more power. Ability to charge and discharge batteries at higher amp levels, up to 2A charge x2, and 1A discharge x4, is one of the advantages of the Opus.
What you need is a 12v charger with minimum of 3A, and 5A would be better. Do not use a higher voltage laptop charger. Chargers should have an icon showing the polarity of the connection. Make sure yours match.
I would keep the opus I’ve had one for awhile. And have charged over 1000 cells on it easily by now. Usually it’s charging something day and night. It discharges at 1 amp not 500mah like the li500. Old cells can sag underload I’d rather have the highest load. To be more inline with flashlight use. My wife even uses the opus. Its all around a great charger and would not hesitate to purchase another.
Someone mentioned worry about pulse charging ga cells. I’ve put around 250 cycles on a set charged in the opus almost exclusively and its not again any differwbtm I did unofficial test awhile back over the last year. Keeping a handful of marked cells that go into the xstar or liito. Same amount of cycles as the others just a cc vs pwm. And when discharged tested at certain intervals and even at 250 cycles you couldn’t tell them apart. They are aging exactly the same.
Me too. I’ve had the Opus 2.2 for around two years now. I charge 6 LG HG2’s daily for vaping purposes. (3 at a time) After 1 year, these cells have over 300 cycles are rock solid, and so is the Opus charger. I charge AA’s, AAA’s, 18650’s, 350’s, 340’s, 14500’s, 26650’s, and some 4.35v cells. Button tops, Flat tops, protected. Have never had a single problem.
The opus is free to send back. So no big deal. I wouldn’t have bought it if it wasn’t (going from $10-20 charger to $40ish). The lii for $17 seems to do what I need it to do for less than half the price. I don’t doubt ill return to Opus, but maybe in a year or two when the tech is better and I don’t have to worry about having extra fans/lubing fans/etc.
Yes, the samsung cells are dead. If you charge one with a ‘dumb’ travel charger (its one ive had for forever, it will charge anything) they lose charge very quickly. I was shocked myself, I kinda hope illumnsupply gets to see this and realize they lost a customer who has spent, well, a lot there over a stupidly small transaction. There is seriously something wrong with them. But time and time again their IR test is through the roof(regardless of temp, etc) while my other cells test fine. Seems pretty indicative of a bad cell? (which I kinda knew through my years of using cells, but didn’t have a number to back it up).
Got myself a Lii on the way with the charger, thanks for the link Syndicate
Me 3, the opus has been my go to charger for a good while now. Drilled the bottom for access to the 4.35v charge setting. This works providing the cell voltage is 4.1 or less(if close to 4.2v it won’t charge to 4.35v and instead terminates at 4.2v ). I tend to use bays 1+4 the most with vape cells 1.5a. 2a gets used for 26650 cells(1+4 bays). My fan was pretty noisy so simply swapped out for new and been quiet simce(6+ months). Not had any issue using the 4 bays 1a .
When I need more bays i just break out some of the other chargers
Have more but don’t tend to need them much at home. Work wise I have the vp2 and opus BT c100. The latter simply because I was happy with my other opus and wanted 4.35v support for 16650 cells I use in work. Also for a nice voltage display(my xstar sp1 does not have)For a single bay, the BT c100 has been excellent. I would have preferred a quicker way of selecting 4.35( have to insert cell, wait till charge stops flashing ,press hold mode for a few seconds then wait for the 3.7v to flash, release mode button and press to select 3.8v). Maybe 10s of waiting which is not ideal, but I have got use to it now. Shows the IR when cell inserted (around 100-110 on one 16650 cell). How accurate it is who knows, until my use time/voltage drops I will simply keep using the cell/s.
Might be tempted to try out an lii 500, seem very good value and make an excellent back up charger. It’s more flexible than my vp4 which limits 4 cells to 0.5a……too slow for me! Not to mention Nimh support!
The Opus is on its way back, I feel like I will order another one down the road, when their fans are better and IR readings are more reliable.
I found my old laptop charger but it has an output of
I am assuming that is way too much for the Lii? So I guess I should just order it with the charger it comes with? I have a bag load of AC to DC wall worts but im not sure if the plugs would fit and what not. Since I don’t really ever rapid charge, would the charger that comes with the Lii be okay? Honestly id say 99% of the time I choose 500ma if given the option, because it seems to give a healthier charge if that makes sense?
So should I just order the Li-500 from alibaba with whatever power supply it comes with? Or is ebay/amazon the cheaper or better route when going for one with the power supply (do you get different power supply if ordering from alibaba, ebay, or amazon?) (sorry, I lost track a bit, been sick so sorry if anything sounds off, still foggy headed. A link would be greatly appreciated atm because im in derp mode and need to get something on the way because im about to give away my last spare charger)
Gauss, they were Samsung 25R cells. The way that it died is that I plopped the batteries in for a charge not thinking anything of it, came back to notice they wren’t charging. Now it no longer recognizes any battery to charge. I will do a tear down and take pictures as soon as I get a chance. I mean that thing was rock solid for many years before it met those super high IR cells, maybe coincidence but seems odd considering the timing.
I have been using this charger ISDT SC-608 for RC hobby and been using it also for charging 18650s. for power, price and size it is currently my favorite granted this is not your typical 18650 charger and need a seperate 18650 holder to charge but it can charge up to 8A or 150w at $39 it is a steal. For more power and not much bigger size you could always go for its bigger brother ISDT Q6 Plus
If you have light which uses 4x18650 this will save your time.
Question, since I was starting to look for another all around charger, at what voltage does it terminate the charge for Li-ion and Li-Po? Can it also charge 12V Pb batteries? Is the screen glass or plastic? Have you had any problems with it?
I wish I had saw yours but I went ahead and ordered from the 2nd link I posted because they had sold a lot of units. If it turns out to be not real or something ill reject the charge through my credit card if I have to. $17.25 was my total. If the Lii is as good as everyone says that should be the definition of bang for the buck. Right now my TR-01 is humming away just fine so I am in no rush. Ill be more interested at the $40-50 price point for a charger if it has really precise IR readings and no potential issues with fans or anything. Now, just time to wait 2 or 3 weeks to get try out the Lii . Thanks for all the information in the thread, it has been great!
