Yeah, I consider this to be a ābalanced beamā. Way less tunnel-vision effect than using a thrower like the C8. Perfect for walking the dog, etc. In reality, this is the type of profile that I would use the most.
Not a problem. I only wanted to try the code because I was issued a code for a sample that expired before I got home from work to get the light. Another issued and again no joy. Kinda glad I did not get a light after reading your review. I certainly could not have done as well of a job as you did. Again, thanks.
I also requested the single tailcap SW or the dual SW. :+1:
I bought my SP32 in Sofirnās AliExpress store with the coupon they have there.
It reduced the price in almost 2ā¬ (Ā± $2 USD). It takes longer to arrive than through Amazon, but itās cheaper, though!
SoCalTiger: after this time using it, are you glad with the overall functioning of the light?
Yes! The only real āconā for me is that I have unintentionally entered strobe mode when trying to quickly switch modes while out on a walk. So, my recommendation to manufacturers now is that they donāt use double-click to activate strobe modes. Iād rather have a double-click go to Turbo as that is a less distracting situation between the two. And then a long-press for strobe.
That said, the SP31 is currently on my primary 18650 EDC rotation. For walks, itās usually either this or my C8.
The SP31 has the superior color temp and tint. I absolutely love the XP-L2 V6 3D.
Hum, gotta be careful with possible entering on strobe thenā¦
I got that same problem with my Manker E11 when going up on modes. A faster click and it āstrobesā!
Iād also prefer the double click for turbo, and eventually triple click for strobe or no strobe at all, butā¦not all manufacturers think alike!
Still, the overall appreciation seems nice, what is very good! Iām waiting for mine, hope it doesnāt take long to arrive!!
Saw this on amazon the other day and thought it was interesting.
Do you also have the SP32? And it is on your EDC rotation instead of this one in the review (SP31)?
I really like a 2-switch setup with forward clicky tail, Although Iād prefer if the tail switch had no memory and always starts in high, like my Ultrafire C20 (Crelant 7G3CS clone) a āTactical tailcap high mode switchā as Crelant calls it.
Love that light for those reasons, but itās a bit too long. Sofrin SP31 is only about 4mm shorter but I like that it has the XPL and 3D tint.
I also wish they sold just the base light W/O battery and charger, Iād rather pay $5-8 less, than get stuff Iām not going to use.
I guess you can find just the light here on AliExpress store (https://tinyurl.com/y73gjvf4)!
I bought my SP32 there, without the battery and charger!
Take a look! Of course, it may take longer than on Amazon to arrive, but maybe it worths waiting and paying less in your case!
Great review! Looks like a good value light, nice to see that it has a lot of the key features sorted. I might pick it up at some point. My only gripe is the modes. In my opinion I think they should have added a different medium of about 120-180lm, and consider the ~385lm mode high and ~1000lm mode turbo. Glad it has moon / firefly, unlike the comparable A1S.
The SP31 (in this review) is still in my primary rotation. In fact, itās my default Go-To for a tube flashlight. This despite the fact that I have several other similar tube lights. I really like the color temperature and the Up/Down UI. My only long-term negative with this light is that you can accidentally enter strobe by clicking too fast.
I do not have the SP32 to compare. Howeverā¦ wait to check out my next review that I post in a couple days. Hopefully it will answer your questions. But, in short, I do prefer having the tail cutoff since itās harder to accidentally activate. I donāt need the forward-clicky, though. A reverse-clicky would have been fine with me.
Iād actually prefer no memory and always starts in low. Reallyā¦ I wish that all these flashlights had a hidden programming mode where you could set your preferences (like how Biscotti works).
Yeah. Personally, I would have ultimately preferred 5 modes and I agree that the existing modes are misnamed. The current mores are more like Turbo -> High -> Low -> Moon.
I mainly use mine on the ~40% 1A mode since it has no problem sustaining that.
Thanks for the reply. Iām not interested in the SP32 because itās not dual switch. The reason I asked about it is because in one of your previous post you wrote that you EDC and love the tint of the SP32:
Thatās why I was confused, but I guess you typoād and meant to write SP31.
